Spokes:butted or straight
I am going to build up my first wheel shortly with a new Phil Wood disc hub to my current Mavic XM719 rim, 36 holes. The bike is a commuter and fully loaded tourer. I am a lightweight. Going from an XT hub to the Wood hub so the current spokes are likely too long. I told the shop I would prefer DT Competition, double butted. They have suggested cutting and threading their own spokes. These would be straight guage. Is there a really strong case to be made for the butted spokes or could I go for the straight ones and count on building a good strong wheel? Are butted spokes far superior to straight guage?
- Mark
Ferrous wheel
Bikes: 2004 Gunnar Rock Hound MTB; 1988 Gitane Team Pro road bike; 1986-ish Raleigh USA Grand Prix; mid-'80s Univega Gran Tourismo with Xtracycle Free Radical
^^ What he said. Especially since you sprung for a Phil hub. Sounds like the shop is proposing the easiest strategy for them.
Over the hill
Quoted: 995 Post(s)
Liked 1,203 Times
From what I've read here on the forums and elsewhere, double butted is more durable and straight is cheaper.
Quoted: 1572 Post(s)
Liked 643 Times
I suspect that the shop doesn't want to buy a wholesale lot of 100 spokes and have 64 leftovers that they'll likely never sell. If the wheel takes different spoke lengths it could require 2 wholesale lots of 100 spokes. That might change the economics of the whole project.
I build a few wheels and I have access to spokes at wholesale prices. For a few recent wheelbuilds I've bought the exact number of spokes that I wanted from wheelbuilder.com.
Making a kilometer blurry
Double butted will build a stronger wheel. The spokes themselves are not stronger, but they are EXACTLY as strong where they are likely to break: the elbow. DB spokes build a stronger wheel because they have to stretch more to reach tension, which means they require a greater wheel deformation to go slack when you hit a bump or crash. So, this also means that their tension changes less in a normal load cycle, which means less fatigue.
If you can afford it, get double butted.
META
Bikes: Gary Fisher Aquila (retired), Specialized Allez Sport (in parts), Cannondale R500, HP Velotechnic Street Machine, Dented Blue Fixed Gear (retired), Seven Tsunami SSFG, Specialized Stumpjumper Comp Hardtail (alloy version)
another vote here for double-butted. The ONLY benefit to straight gauge, as far as I'm concerned, is price. They're cheaper than anything else.
Over the hill
Quoted: 995 Post(s)
Liked 1,203 Times
Something tells me local shops are fine if you mail order spokes. Keeping them in stock just isn't practical for them, and they don't want to buy just a few, so that's one of the things I don't feel any guilt about ordering online.
Thanks for confirming what I am thinking. The shop is a good one and I think the guy knows his stuff but they all cringe when I ask for 36 spokes from a box of 100 with the balance hard to sell in the future. I am sure he is trying to take the easy way out. I will stick with the DT spokes.
Quoted: 241 Post(s)
Zinn has a diferent opinion in his book:
You can try Sapim spokes from www.biktetoolsetc.com
They have better selection of sizes and sell them in bags of 20.
Although 14- or 15-gauge (2.0mm or 1.8mm) double-butted spokes will probably have no more breakage than straight 14-gauge (2.0mm) spokes (because most breakage occurs at the nipple or the elbow, where butted spokes are thick), butted spokes will stretch more, allowing spoke loosening.
drink slinger
Strange that Zinn would say that. According to Sheldon (see end of this quote), butted spokes are not just "as strong" but actually stronger at the elbow because they can fit perfectly into the hub hole, since the nipple threads can be thinner.
Sheldon said:
Double-butted spokes do more than save weight. The thick ends make them as strong in the highly-stressed areas as straight-gauge spokes of the same thickness, but the thinner middle sections make the spokes effectively more elastic. This allows them to stretch (temporarily) more than thicker spokes.
As a result, when the wheel is subjected to sharp localized stresses, the most heavily stressed spokes can elongate enough to shift some of the stress to adjoining spokes. This is particularly desirable when the limiting factor is how much stress the rim can withstand without cracking around the spoke hole.
# Triple-butted spokes, such as the DT Alpine III, are the best choice when durability and reliability is the primary aim, as with tandems and bicycles for loaded touring. They share the advantages of single-butted and double-butted spokes. The DT Alpine III, for instance, is 2.34 mm (13 gauge) at the head, 1.8 mm (15 gauge) in the middle, and 2.0 mm (14 gauge) at the threaded end.
Single- and triple-butted spokes solve one of the great problems of wheel design: Since spokes use rolled, not cut threads, the outside diameter of the threads is larger than the base diameter of the spoke wire. Since the holes in the hub flanges must be large enough to fit the threads through, the holes, in turn are larger than the wire requires. This is undesirable, because a tight match between the spoke diameter at the elbow and the diameter of the flange hole is crucial to resisting fatigue-related breakage.
Since single- and triple-butted spokes are thicker at the head end than at the thread end, they may be used with hubs that have holes just large enough to pass the thick wire at the head end.
Five is right out!
Five is right out!
Quoted: 241 Post(s)
If you want strong spokes, buy the Strong spokes.
Sapim Strong: https://www.sapim.be/index.php?st=pro...&detail=butted
A spoke manufacturer usually uses technologies to make sure both straight and double-butted spokes are worry-free.
I see a problem with custom-cut spokes - they are expensive.
Excell Sports will sell you what you need.
https://www.excelsports.com/new.asp?p...jor=1&minor=30
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
Geek Extraordinaire
Also, oddsandendos.com has pretty good prices on individual spokes.
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
Using straight gauge does not eliminate or render unecessary these two critical wheelbuilding skills. Less windup because of straight gauge spokes should not be used as a crutch.
