Belt driven Touring bike
Bikes: Cannondale R3000, Specialized Enduro SL
I'm planning on having a custom bike built for me using a Rohloff hub and I'm really considering using the belt drive system from this company.
On paper it looks great. What do you guys and gals think of this idea?
One bike I was considering was having Spot Brand bikes custom build me one of their Highline's with touring provisions and rohloff droputs.
the uncarved block
Bikes: '13 Surly Troll (touring), '74 Peugeot PX-10E (fixed gear), '94 Mongoose Rockadile (trail)
I have no idea about the technology but I can imagine the lack of a chain would make for a very smooth and quiet ride, I would love to test ride a bike with this system. They look pretty professional but glitz and glamour doesnt prove anything, I want to hear some real feedback about this product.
They say the belts are near impossible to break. At Interbike this year they had a Harley Davidson being suspended in the air by one of the belts.
I don't think I could imagine one of the cogs or rings breaking or wearing from a belt, they look very burly.
However, if something were to break, or you need replacement belts, QBP is going to be one of the distributors.
https://reviews.mtbr.com/interbike/sp...-system-bikes/
They're also just as efficient as a chain.
Recommended replacement of the belt is over 10,000 miles, there's no oiling, it's much quiter and probably smoother and stiffer under hard accelerating.
Bikes: Cannondale Killer-V 900 (Mountain), Jamis Aurora (Touring)
I'd be concerned about getting the belt wet and dirty and then have it wear out fast in the boonies. If you get that thing covered in slimy mud will it slip under high torque? Does it expand or contract when really wet?
The automotive world is moving back to chains for the timing belts and when you see belts in a car they are usually covered with a plastic cover. If you had such a cover for the belt on the bike I'd feel better but I still wonder what the belt would do in high humidity. I bet it's quiet but reliability has to be your #1 concern.
Bikes: Thorn Nomad S+S, Trek 520 - 2007 (out on loan), and a crap Repco MTB
The Rohloff is not a solution, staephj1, it's an alternative. A good one, too.
Sparsely updated blog
My Harley is belt drive. They say the belt will last 100,000 miles, need little maintainence etc. I broke mine in 18,000 miles. A close inspection revealed I had picked up a small sharp rock in the rear pully that acted like a knife against the underside of the belt. The belt works good on a motorcycle, smooth and quiet. I'm sure it would be the same on a bicycle. I will however, never buy another belt drive motorcycle (or bicycle for that matter). A chain can be fixed on the side of the road with simple tools if it breaks. When a belt breaks, you need a new belt. I would check the cost of replacements too. It was almost $200 for my motorcycle belt.
That's only one half of the equation; another question would be "is this technology reliable enough so that the probability of getting stranded is small enough to be acceptable?"
Granted you want to be able to get spare parts, but it's better not to need spare parts in the first place (for anything).
cyclopath
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
- I wouldn't want to be pioneering any concepts on my touring bike. I would only be interested in using proven components that are readily repairable/replaceable. Parts break all the time for reasons no one could foresee so assuming you'll have no problems is overly optimistic. The question is what will you do when you do have problems?
- if you are going custom make sure the company building your bike is heavily into touring. A really nice custom touring bike isn't a cross bike with extra braze-ons or a mtn bike with longer chain stays. Get someone who knows what the bike will be put through and who understands what makes a great touring bike to build it for you. If not take your money to a company like Thorn that builds high end production bikes specifically for Rohloff hubs.
- if you want to try the belt drive out just make sure your bike can be easily retrofitted to a chain drive if things don't pan out.
Enjoy your new bike. I hope the belt systems works great...
I like the idea. On motorcycles one of the problems with belts is the super power aftermarket motors that are being developed for harleys. These have proven to be belt breakers, and are somewhat responsible for the return of chains. Of course the cool thing about bike chains is that they are lifetime oiled and sealed, which doesn't seem to a bike miniturizable concept yet. But I guess the issue would be whether on this scale there are any similar problems 250 pounds guy tearing into a hill with 100 pounds of gear, "snap"? I doubt it if it is designed for mountain bikes.
The only part that looks open to tragedy with this system is the belt itself, and that would be light and easy to carry and replace on the road, so it would be a mater of whether it's a once in a lifetime problem or an every 50 miles problem that the belt gets cut with a stone chip. I have enough excitement of that type with tires.
Efficiency is my main concern. Something that lightens the rotating load on a Rohloff would b a great pitch against the already easier running deraileur system.
Then there is the cost, it can't be cheap? There is also the belt length, how many options is it a delco item or only in a few places on earth. I'm betting on MSC.
Sure looks better than that lifetime lubricated chain in a chaingard option.
The break in the chainstay is going to take a litte thinking over....
The problem that Rohloff/belt drive solves is off-road riding in wet muddy condition. Clay-based mud is really sticky and will soon clog up a derailleur system and add 4 lbs of weight.
The system is also useful for all-weather, low maintenance commuting.
The belts look light enough to carry a spare if you are touring far from courier services.
Pros: very clean, very low maintenance. Fairly easy to carry 1-2 spare belts on tour.
Cons: Belts are less efficient than chains; Rohloff is less efficient than derailleurs. You won't get spares on tour, ordering through QBP could take a very long time. Expensive.
I think it depends on where and how long you're touring. 2 weeks, no problem. Maybe even a few months. However, I can guarantee that no matter how "unbreakable" the chains are, not only will it break, but it will break at just about the worst possible time.
I recommend you do some research on Strida folding bikes, which use belt drives and internal hubs. Check the Folding forum for feedback forthwith....
The belts don't really stretch, they are carbon impregnated and are super strong.
the uncarved block
I was waiting for real statistics... no more arguing about which one is better, they both weigh each other out. So the real debate is about personal preference. Personally I love the idea, chains are hella old school and this belt drive seems like it would feel so good to ride with. But then again I am a starving artist and can only dream of such a thing while lubing and cursing at my clunky chain drive.
the uncarved block
Yeeaa, it does kind of have the "Carbon Drive" logo on the bottom right of the page... What do I know though, I am just like every other American. Put a graph in front of me and I am happy with whatever the results are, even if it is bull. Sad for me.
Bikes: 2008 Specialized Allez Elite, 2007 Trek 7.3 FX, 2005 generic Schwinn Mountain Bike.
Using data gathered from the manufacturer doesn't really prove anything.. that's like believing your used car dealer when he promises you got a great deal.
Looks pretty good to me, how else are you supposed to measure this but by the way it was done? It was also done by an independent laboratory, not by Carbondrive Systems.
Do you think that someone other than Carbon Drive hired them to do it?
Edit: I am not even saying that they are definitely inaccurate findings, but it certainly seems reasonable not to trust testing that was almost certainly commissioned by the manufacturer either directly or indirectly.
The touring community has always been a bunch of naysayers, they still think bar-end shifters and cantilever brakes are greatest inventions of all time.
I posed this same combination of belt and Rohloff hub in a thread a while back and got the same kind of response. Just disregard the whinny old school mentality and move forward.
I think it would be a great combination! How much better is it than a regular derailleur system? Well considering the cost, no Rohloff hub system seems to make much sense, but what a cool set-up it would be. The best part, I think would be how quiet if would be, almost worth it just for that factor.
Sorry old school die hards, I know I always tick your guys off on subjects like this, but someone's got to do it.
