Chain Lube
Chain Lube
I never knew the topic of chains could raise a number of questions. I was looking for a good lubricant after I replaced my chain. I have read posts were guys were having trouble getting off the original lube on the chain. However after reading:
https://sheldonbrown.com/chains.html
I see you are not supposed to remove it. From the Sheldon Brown web site:
"Some people make the bad mistake of deliberately removing this superior lubricant. Don't do this!
The factory lubricant all by itself is usually good for several hundred miles of service if the bike is not ridden in wet or dusty conditions. It is best not to apply any sort of lube to a new chain until it is clearly needed, because any wet lube you can apply will dilute the factory lube."
Anyway, on the topic of lubrication. There seems to be a few recommended brands and I just wanted feedback from anyone you has just them. I currently use Tri-Flow, but other recommended brands seem to be:
Phil Wood Tenacious oil
Dumonde Tech Bicycle Chain Lube
Pro Link Chain Lube
Any feedback would be appreciated.
Pro Link Chain Lube
cyclepath
Bikes: 2005 Trek Pilot 5.0, 2001 Specialized Sirrus Pro, Kona Lava Dome, Raleigh hardtail converted to commuter, 87 Takara steel road bike, 2008 Trek Soho
I've had good luck with Boeshield T-9. I use Tri-Flow for other lubrication needs on the bike.
"Without music, life would be a mistake."
-- Friedrich Nietzsche
I play in the street.
Bikes: 2005 Allez Triple, 1971 Schwinn Varsity Fixed Gear Conversion
+1 for White Lightning.
It wears off pretty fast, I have to reapply every 100-150 miles, but it's nice and clean.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
ProLink FTW.
Phil's tenacious would be a friggin mess on a chain....actually it wouldn't be on the chain, but rather everything else.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Rock n' Roll...follow the directions, wipe it down until you think you will need to redo it, then wipe it down some more. It cleans, lubes and will not attract crud.
Quoted: 15 Post(s)
prolink, dont go for any expensive stuff,
if you dont like taking off your chain to clean just saturate it and then wipe off the excess which will take off a fair amount of the crud, doing this before a lot of crud accumulates will keep it clean
cyclepath
I used White Lightening for a while too. From my experience, Boeshield is cleaner. Not as much build up of crud and wax.
A Little Bent
Location: Struggling up a hillside in Vermont, USA... ..........................................
I have tried Boeshield T-9 and have not had good results...
I have followed the instructions and allowed it to dry overnight...
It certainly keeps the chain clean but I get squeaking after 2 -3 rides...
I have used ProLink for quite some time now and although it does collect more dirt (relatively) it keeps the chain lubricated much better..
+1 for ProLink...
** EDIT **
I have also used Finish Line Cross Country Wet Lube...
It will keep lubricating through a hurricane but collects quite a bit of dirt...
+1 for ProLink...
** EDIT **
When you guys mention you like a lube and say you are “happy” with it, what do you base it on? For example, previously I used Tri-Flow. I never had a chain rust, stick and since I clean it often, it never had much dirt.
Yet I am wondering if there is something better.
Bikes: yes please
Does White Li cause chain wear faster than other lubes?
I though I remember hearing this and it sounded dumb--how could lube wear the chain? OR, rather than wear being part of the product is it just that WI requires more frequent application and most people don't mind their drive train as they should?
another cat...FAB!
Bikes: Merlin Ti Build, Trek Y-50, Bianchi Titanium Build, Custom Cuevas Road bike
Dumonde Tech really decreases chain noise and is very light...I have "officially" switched from Tri-Flo
Change the course of the Epidemic | The Merlin | Merlin XLM | Bianchi Ti | CyclePeople
Don't take it off until there's a cure LIVESTRONG | pay it forward | Cats | NEW Gallery
9
I eat carbide.
Liked 1,306 Times
White Lightning wears off very quickly. It will remain on the plates and surface of the china, but will not actually be in the rollers lubricating like it should for very long at all.
I used to use it a lot until I notcied that sometimes I could end up with heavy chain noise and some squeeking by the end of a century ride after having lubed up right before the ride.
This only really started happening as a chain would wear, but it drove home the fact that White Lightning just doesn't like to hang around.
Double Secret Probation
Bikes: Madone 6 series SSL, Cannondale CX9, Trek TTX, Trek 970, Trek T2000
+1 The best.
I've used plenty, ProLink is the best for me. I tried some Dumonde Tech based on a LBS recomendation. It's ok, and very quiet, but turns black very quickly, making weekly cleaning a pain. Plus it cost about 3x as much as ProLink. Easily getting 4,000+ miles on a 10 speed Dura-Ace chain with Pro-Link.
Time to Ride...
Time to Ride...
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1246 Post(s)
Liked 1,273 Times
I use ProLink, and I like it a lot, much more so than the other lubes I've used (White Lightning, White Lightning Epic, & Finish Line).
But fwiw I think it's way more important just that you do lube your chain regularly than what you're lubing it with
I eat carbide.
Liked 1,306 Times
Lots of truth to that. Kind of like picking a bike. The one you'll ride is the right one.
Bikes: yes please
Yes...
Funny, not much being said about Phil Wood Tenacious oil.
If Sheldon Brown thinks it is the best there is there has to be something to it.
bike fandango
p.s. Sheldon is absolutely correct - ride that new chain with its factory protective coating until you need to apply Pro Link (~:
.. and clean the rest of the drive train before putting on that new chain (but I suppose you knew that already).
I eat carbide.
Liked 1,306 Times
It does not like to remain applied to items that rotate. That said I use it for many other applications - just not my chain.
