Chain lube
Chain lube
I know, I know...discussed countless times.
But, what about motorcycle spray chain lube? Obviously a motorcyle chain is under more stress than a bicycle chain. It's a spray so presumably is diluted with a thinner (as in Homebrew).
A large can is about $10 at my local motorcycle shop.
Is this the ideal chain lubricant?
Double Secret Probation
Bikes: Madone 6 series SSL, Cannondale CX9, Trek TTX, Trek 970, Trek T2000
I'm guessing MC lube is much thicker then bike lube. The best is Pro Link. Plenty other out there, but Pro link is the best.
Time to Ride...
Time to Ride...
Erstwhile Trogon
I use 4 parts clear mineral spirits to 1 part synthetic motor oil.
It's essentially the same concept as Pro Gold, Rock and Roll and the other lubes that are based on a thin oil diluted in an evaporative carrier solvent.
I've used them all, this one works the best and is far less expensive than similar boutique lubes.
Bikes: 2024 Specialized Tarmac SL8Pro, 2022 Specialized Epic Evo, 2021 Framed Alaskan Fatbike,2019 Trek Emonda SL6 Pro, 2018 Trek Stache 9.7, 2013 Specialized Roubaix SL4 Expert, 2009 Ritchey Breakaway Cross, 2016 Lynskey ProCross, 2008 Trek T1000 Tandem,
Quoted: 18 Post(s)
Liked 5 Times
I second the Dumonde Tech Lite, simply amazing stuff . Supposedly 10X more slick than teflon. Your chain and cassette will always look clean and will last at least twice as long compared to other lubes.
Bikes: Too many to list!
It is.
My thoughts also. Since I switched several years ago, I've never even thought of going back to any of the many choices I've used. Just give it a try, and you'll understand.
... Brad
... Brad
Light Makes Right
Bikes: Gianni Motta Criterium, Dean Hardtail
I like Pedro's extra dry on my bike, but if I was going to use moto lube I'd use what I use on my motorcycle:
Maxima Chain Wax.
Maxima Chain Wax.
