Need creative adaptive brake solution
Old 03-22-07, 10:01 AM
Erect member since 1953
cccorlew's Avatar
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times in 21 Posts
I can't grip with my left hand, so all my braking is right hand front wheel.
I'm feeling less lucky lately, and am worried about what might happen if my front brake fails.
I'm thinking I need an right-hand operated "emergency" brake for the rear wheel.
So I'm looking for a Mtn bike style brake lever I could add to the bar that would operate the back brake. I wouldn't ever use it, ( I hope) so it needs to be.
  1. VERY small.
  2. Black is good.
Suggestions for the smallest lever like this that you know of, please. Or another idea entirely.
cccorlew is offline
Old 03-22-07, 10:11 AM
the goal
Bikes: Bob Jackson track
The dia compe goldfinger is a BMX one finger lever, but I think it fits mtn bike bars. It's availabale in black or gold.
Momentum is offline
Old 03-22-07, 10:15 AM
Making a kilometer blurry
waterrockets's Avatar
Bikes: rkwaki's porn collection
Quoted: 37 Post(s)
Liked 91 Times in 38 Posts
You might be able to hook up some sort of a splitter from tandem or bmx parts that will allow the one lever to pull both brakes. Go to an old bike shop that's been there since the Ice Age, bring your bike, and ask for ideas.
waterrockets is offline
Old 03-22-07, 11:05 AM
cccorlew's Avatar
Quoted: 121 Post(s)
I'm going to be in brifter land with the new project, so the tandem lever won't work. But it's a good idea. I had one on my old bike. Th eonly issue is that you can't modulat ethe front/rear balance when you ride.
Thanks!
cccorlew is offline
Old 03-22-07, 11:07 AM
cccorlew's Avatar
Quoted: 121 Post(s)
My bars are 31.8. Maybe I can kind of adapt it. It's not like it's going to be used a lot.
Thanks!
cccorlew is offline
Old 03-22-07, 11:16 AM
Bikes: Aegis Road Bike, Gunnar Rockhound, Specialized Transition Elite, Van Dessel Holeshot, 1989 Trek converted to SS commuter
What about adapting a bar top cyclocross lever?
https://www.excelsports.com/new.asp?p...ajor=1&minor=7
trin2du is offline
Old 03-22-07, 11:21 AM
Parts Guy
Gravity Worx's Avatar
Bikes: several
One thing on the Gold Finger.
As with several Dia-Tech levers, there is a 1" wide perch (mount part) meaning that it will take up 1" of bar space.
Normally this is not a problem. but with 2 brakes on 1 side of the bars, it might be.
I'd aim the secondary brake straight back to work with your thumb too, if it were me.
Then you could sort of modulate both at the same time with out mixing up the 2.
Gravity Worx is offline
Old 03-22-07, 11:30 AM
cccorlew's Avatar
Quoted: 121 Post(s)
That looks promising. Are those standalone brake levers, or some sort of pass-through to the regular lever?
If they can work without routing to the regular brake (which would be on the wrong side for that to work) it would be a good solution. Can they work like that? Anyone know who has the smallest version?
cccorlew is offline
Old 03-22-07, 11:33 AM
Non Tribuo Anus Rodentum and off to the next adventure (RIP)
Stacey's Avatar
  1. VERY small.
  2. Black is good.
Ok, thinking outside the box here a bit.
You say you can't grip. What can you do... Push, pull, etc?
I'm thinking a tandem style 'drag brake' actuation using a bar end shifter, depending on mobility.
Stacey is offline
Old 03-22-07, 11:56 AM
They are passthrough levers. Is there any reason you couldn't mount the traiditional lever even if not using it? You mentioned brifters, so I assumed you would have the lever there anyway. I'm sure a good shop could figure out a way to make them work.
And as for size, most brands (both that I know of at least) seem pretty much the same.
trin2du is offline
Old 03-22-07, 12:08 PM
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
Liked 4 Times in 4 Posts
Coupling both front and rear brakes would be dangerous. Braking force could become highly unpredictable as the pads wear and the rims become differently contaminated by dirt and/or water. And that assumes a good initial adjustment is even possible. Furthermore, it would only protect against a BRAKE failure, not against a LEVER failure.
No, two separate brake systems both mounted on the right-hand side is the only sensible solution. My suggestion is two regular levers (use your left one, for example...) mounted as close to each other as possible, but with the "backup" one mounted so it is angled down more, and out of the way of the normal brake operation. This modification shouldn't take more than maybe 20 minutes or so to complete. You don't even have to touch the cables - only the levers themselves.
CdCf is offline
Old 03-22-07, 12:14 PM
Quoted: 37 Post(s)
Thanks!
Front/Rear modulation aside, I'm talking about cobbling together a solution that would work with any brake lever. Just splitting the cable and having a stop for both housings at the hood. I'd need to mess around with it for a while, but it should be possible.
The modulation loss would be a tradeoff...
Old 03-22-07, 12:33 PM
cccorlew's Avatar
Quoted: 121 Post(s)
That's exactly what I did on my Mtn bike. The two levers are mounted so closely that I can grab them both and do good job of modulating the fore/aft balance.
But on the road I'm actually happy with just using the front brake.
I'm just looking for a bail-out oh-my-gawd thing I can grab.
I really like the look of that 1-finger BMX brake. I'd use that if i could make it fit...
cccorlew is offline
Old 03-22-07, 12:45 PM
Videre non videri
And that's exactly what I described. The main one mounted in the regular way, and the "backup" mounted inside, but angled down so far that you don't touch it in normal braking operation (using the main lever), yet still easy to reach if you rotate your hand down a bit.
CdCf is offline
Old 03-22-07, 12:55 PM
é wot?
Bikes: Gary Fisher Montare, 1973 Bottechia, IRO Jamie Roy,1998 Cervelo Eyre Tri, 1982 Peugeot Sport fixed gear, and some kind of red bike hanging in the rafters
The 'cross lever would be the slickest solution. They can be used as standalone, a lot of fixed-gear bikes these days have their single brake activated by a 'cross interrupter lever on the bar top. Alternatively you could use a TT lever mounted in the bar end under the drop part of the grip.
yairi is offline
Old 03-22-07, 01:01 PM
cccorlew's Avatar
Quoted: 121 Post(s)
I'd been g
"googling" but because of your post I tried "bicycle cross lever" and found this cool thing. It may be just what I'm after. I just need to make sure it fits, or find one like it that's a little less cast
Link tool doesn't seem to work. Here's the url
https://www.thebikebiz.com/PhotoGalle...2DLVR%2DPAUL01
cccorlew is offline
Old 03-22-07, 01:25 PM
é wot?
That's like what I meant, but it looks like it would be better. Tailor made to your application in fact. The cross levers usually have a bit longer lever though. And they pull differently to that one, they move the housing not the cable. I use the Tektro RX 2.0.
yairi is offline
Old 03-22-07, 04:32 PM
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 644 Times in 365 Posts
Used to be commonly done on tandems. I had one set up that way. I didn't encounter any of the things that you mentioned.
If it was my bike, I'd install an in-line cable doubler to operate both brakes from one lever - an STI lever will work fine. You won't encounter clamp size issues with your 31.8 mm bar either. Triathalon sources sell them. Actually, the Problem Solvers cable doubler lists psysically challenged riders as a typical use.
Retro Grouch is offline
Old 03-22-07, 07:56 PM
Quoted: 37 Post(s)
+1 That's all I'm sayin'
My old tandem was braked this way.
Old 03-23-07, 12:36 AM
Bantam's Avatar
Bikes: Trek 1500
Hey, I am interested in why you are unable to brake with your left hand. I have spastic hemiplegic Cerebral Palsy that affects my left limbs. I cannot shift a left hand brifter so I have a barcon on the right side to control the FD. I spent my childhood on bikes with the rear end loose and the bike sideways. I am using the rear brake (right side) to control most of my braking but the idea of being sideways above 25 is not appealing. I am using the STI on the left side as a brake only. I have 2 Specialized shims in it to bring the lever closer to my hand but it is still a subpar braking experience. I am considering a compact aero brake to replace the STI but the idea of a TT brake on the left barend sounds nice. I really want to race so being able to stop is huge.
Bantam is offline
Old 03-23-07, 07:52 AM
Scott
n4zou's Avatar
Bikes: Too Many
A simple spoon brake attached to the fork is a simple and cheap emergency brake option. You can easily make it yourself. More information is available here.
https://en.wikipedia.org/wiki/Bicycle_brake_systems
n4zou is offline
Old 03-23-07, 09:25 AM
cccorlew's Avatar
Quoted: 121 Post(s)
Bantam, you might want to look at https://bikeforums.net/showthread.php?t=255466.
I have no fingers to speak of on my left. I can kind of push or pull a bit, but that's all. I managed to set up my mtn bike like this, (see photo) which would work for you too if you use flat bars. Drop bars -- the issue I'm facong, present a different problem.
Man, get that front brake moved to the right side RIGHT NOW before you skid to your death. You'll be amazed at the stopping power of using your front brake. I swear you don't really even need a back brake. The only reason I'm doing what I'm doing is just in case something were to happen to the front brake when I'm diving down Mt. Diablo. I'll bet you could race without ever touching the rear brake.
Right side brakes:
Holding my left hand on my mountain bars. The strap is just to make sure i don't bounce off when I hit a BIG bump. I don't have anything like this on the bike.
cccorlew is offline
Old 03-23-07, 09:43 AM
Quoted: 37 Post(s)
Interesting solutions. I'm glad you guys are out riding!
Old 03-23-07, 11:00 AM
Parts Guy
Bikes: several
There is one other option that I've been thinking about.
It would put both brakes on the same lever again, but with adjustments on each end so that it wouldn't skid the rear when modulating the front or visa versa. That part is actually a simple adjustment with this system.
The trick part is a cable that splits into 2.
We build 1 into 2 type cables litterally every day for snowmobile throttles.
They are a single cable that goes from the throttle and splits into 2, one to the rack carbs and the other to the oil injection for that application, but the same splitters and all can be set up for bike brakes.
We would put in-line adjusters on each part of the cable after the split as well to give you that adjustability to tune the feel how you would need it.
Just an idea for you to kick around.
The 1 down side though is in losing the ability to operate the 2 brakes seperately.
Maybe something like this would help?
Old 03-23-07, 11:28 AM
Videre non videri
Right side brakes:
That is EXACTLY what I tried to describe!!!
CdCf is offline
