Explain to me, gear inches
Old 03-21-07, 01:55 PM
Traffic shark
Bikes: 2 fixies, 1 road, 29er in the works.
A really stupid thread, it would seem.
I'm the last man out of the cave.
SD Fixed is offline
Old 03-21-07, 01:58 PM
Because tires and wheels are different sizes so simple ratio doesn't provide as much information. Some would argue that gear inches don't provide enough information either.
dutret is offline
Old 03-21-07, 02:00 PM
Quoted: 8 Post(s)
Liked 501 Times in 397 Posts
makes it easier to compare bikes with different sized wheels without having to do very much math
pedex is offline
Old 03-21-07, 02:02 PM
nothing but a gnab gib
Bikes: The Heart of Gold starship bicycle
it's another way for people to be vague.
moe sizlack is offline
Old 03-21-07, 02:03 PM
Traffic shark
right, I think you are.
SD Fixed is offline
Old 03-21-07, 02:26 PM
Oh god it hurts!
why do thermometers have numbers on them?
j-lie is offline
Old 03-21-07, 02:42 PM
current member
Bikes: some- variety is good..
How else to make a schematic comparison of ,say 44x17 and 50x19. Which is bigger? How would you measure if not in distance travelled?
cphfxt is offline
Old 03-21-07, 02:44 PM
well if the wheel size is the same it's easy
2.58 vs 2.63
dutret is offline
Old 03-21-07, 02:45 PM
domestique
squeakywheel's Avatar
Originally Posted by William Karsten
Perhaps I'm getting old an onerous, like 165.
But really, why do gear inches matter to people? I can't for the life of me understand why it @#$@# matters. It seems people obsess over it. I started 42x16. It got easy. I bumped up once to 44x16. Things weren't hard. I built some stamina, some speed, got comfy and went 48x15. Which seems plenty. How would gear inches play into this? It seems to me that it really superflous information.
Or, I'm the last man out of the cave.
Other people obsess over it? Seems you're the one changing your gearing all the time.
squeakywheel is offline
Old 03-21-07, 02:46 PM
Quoted: 383 Post(s)
Liked 133 Times in 91 Posts
Its a way of expressing how easy or hard a gear is. Since there are many equivalent gears, for example a 51/17 is exactly the same as a 48/16, its easier to talk about gear inches, which is the number of inches the bike travels with one revolution of the pedals, than it is to talk about specific CR/cog combinations.
In general, a 70 inch gear is a pretty easy around town gear for the flats. The 42/16 gear you started with is about 70 inches. Track racers usually ride something in the 88-92 inch range. Your 48/15 is about 86 inches, so you are getting up there with the track racers.
Easy to calculate, Cr teeth divided by cog teeth times 27 gives you gear inches.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
San Rensho is offline
lunatic fringe
Dogbait's Avatar
Bikes: 1980 Schwinn World Sport, 1982 Schwinn Super Le Tour, 1984 (?) Univega Single Speed/Fixed conversion, Kogswell G58 fixed gear, 1987 Schwinn Super Sport
There's nothing vague about a system that measures exactly how far down the road your particular set-up will carry your butt for each turn of the crank.
Dogbait is offline
Old 03-21-07, 02:49 PM
All this means nothing without tyre/wheel size factored in. hence gear inches.
and some will say that gear inches is useless without taking crank length into account. hence sheldon's gain ratios.
goldener is offline
you=wrong.
goldener is offline
That's not exactly how gear inches work and it is still vague compared to gain.
dutret is offline
Old 03-21-07, 02:50 PM
Quoted: 8 Post(s)
except gear inches doesnt equal distance traveled per crank revolution
circumference= Pi * diameter
gear inches = gear ratio * wheel diameter
actual distance traveled per crank revolution is gear ratio times circumference
pedex is offline
Old 03-21-07, 02:52 PM
a 72 inche gear is equivalent to riding a highweel bike with a 72" front wheel.
goldener is offline
Old 03-21-07, 02:54 PM
blah
onetwentyeight's Avatar
Liked 5 Times in 3 Posts
read this: https://www.sheldonbrown.com/gain.html
onetwentyeight is offline
oh sorry, was i being vague?
Old 03-21-07, 03:06 PM
jack of one or two trades
Aeroplane's Avatar
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
One valid reason I can think of is going between offroad 26" and 29" wheeled bikes. In order to keep your gearing consistent, you figure out the gear inches and keep that the same.
I agree with you for on-road stuff though, not many folks go between 650c, 650B, and 700c at all.
Aeroplane is offline
Old 03-21-07, 03:15 PM
Run What 'Ya Brung
bonechilling's Avatar
Totally OT, but you know that you spelled "Szyslak" wrong,
right?
bonechilling is offline
Old 03-21-07, 03:53 PM
Perineal Pressurized
dobber's Avatar
right?
You're both wrong
Sleestaks
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
dobber is offline
Old 03-21-07, 04:02 PM
But people do go between different tires often enough. When it snows I put a 32C xcross tire on my rear wheel, which increases the gear inches of my bike.
Yoshi is offline
Old 03-21-07, 04:10 PM
hello
roadfix's Avatar
Quoted: 195 Post(s)
Liked 128 Times in 56 Posts
I need at least 80 inches to stay with my Sat morning geared group ride.
roadfix is offline
Old 03-21-07, 04:18 PM
while we're on the topic:
can someone sum up the advantage/disadvantage (if any) of 2 different combinations that have the same gear inches?
Aves is offline
Old 03-21-07, 04:47 PM
hateful little monkey
jim-bob's Avatar
Ahem.
jim-bob is offline
