I am not sure if I need a new jacket
This is the first year that I have ridden at night or in the cold. I have chosen not to purchase any long sleeve jerseys because I want to layer and have flexibility not to mention the added cost of duplicating jerseys. I tend to need less clothing than most people to keep warm under normal conditions. I rode a ride recently when everyone else was wearing long sleeves and tights and I just wore my normal summer attire. The only time that I got cold was at one of the rest stops toward the end of the ride and I immediately warmed up after starting to ride again. I would have been sweating if I had as many clothes on as the other riders.
For cooler temperatures I wear my Bellweather short sleeve polyester jersey.
Next level is a DeFeet UnDeShirt for a base layer under the jersey and and DeFeet Armskins.
Finally I have a Profile brand windbreaker that I originally purchased for snow skiing. I do not remeber where I purchased it or the cost. It has a nylon liner and nylon shell. It is solid in the front except for a collar zipper that ends at chest level to loosen for putting on and taking off the jacket. It has plenty of zip pockets front and back.
The jacket does a great job of keeping the wind off. My first ride started in the morning with low to mid 40 degree temperatures and sunny, windy conditions. I was warm at first and felt that I had dressed perfectly for my first cold weather ride. Then got cold as the ride progressed. I discovered at the end of the ride that my UndeShirt and jersey were soaked in sweat which explains why I got cold.
My next cold weather ride was at night at around 35 to 40 degrees. I kept warm when I rode but got cold when we stopped and took awhile to warm back up after we started riding again. Again, base layers were wet and my jacket was wet as well on the back.
I am wondering if I need a different jacket that is made with material that breathes? I think as long as I can keep dry, I think just the jersey, armskins, and undershirt is all I need to keep warm at even lower temperatures.
Any thoughts on what type of material is best or jacket to recommend? Do I just need a different combination of layers and ditch the jacket unless it is much colder? Any suggestions will be appreciated.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
You might look into getting something that is "waterproof breathable" and has long pit-zips, and back vents. MEC has at least one like that. REI might too.
Your "winter" temps are quite warm, so I can see why you might not want to get a long-sleeved jersey, but have you considered armwarmers?
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Faster but still slow
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
At that temp you don't really need a jacket if you have the right base layers. Long sleeves and a wool vest is perfect. Wool is very breathable and even keeps you warm if it should happen to get wet.
Mmmmm potatoes
In Real Life
Bikes: Lots
Liked 596 Times
Perhaps something along the lines of these:
https://www.mec.ca/Products/product_d...=1162581462974
https://www.mec.ca/Products/product_d...=1162581573521 I've got one very much like this one - an older model, I think - and I've been extremely happy with it. It's good in fairly chilly weather and especially good if the weather turns rainy.
You might also look into vests. I was very skeptical about them for a long time, but then I got one and I love it! For cooler conditions, but not cold enough for one of the jackets mentioned above, I wear something long sleeved (I've got several merino wool tops, several polypro tops, two long sleeved jerseys, and one long sleeved jersey that is really sort of a jacket - fleecy material with a full, jacket-like zipper to choose from), and then I put my wind-breaker vest overtop, and that can be quite comfortable.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
The lined jacket is your problem. You just need a shell to stop the wind. Waterproof isn't necessary unless you plan to ride in rain or very wet snow. Most jackets are somewhat water repellant if they are nylon.
Experience has taught me that the jacket is usually the thing that people focus on and spend the most money on. It has also taught me that it is the item that you can probably acquire the cheapest. ANY nylon unlined jacket will serve as a decent shell.
The more expensive jackets have things like pit zips and water repellancy which are sometimes nice but not absolutely needed. YOu just need to block the wind. In addition, you need to get rid of the heat you are generating, at least most of it. That is why a lined jacket is a bad idea, it will interfere with that part.
This morning I rode 1 hr. 45 minutes in 34 F with 20 mph and gusting North winds. Here is what i wore on my torso.
https://www.performancebike.com/shop/...isearch=true##
https://www.ems.com/catalog/product_d...45524442590916
The jersey is about the weight of a long underwear shirt and the jacket is very, very lightweight. LIghter than the average jacket.
Everyone, thanks for your comments.
I did not realize that the liner in my current jacket would be making that much difference. I went to the store the other day and did not feel confident at all regarding what I might need. I will now consider a jacket with the arm pit vents and/or back vents or a vest since I think my armskins will keep my arms warm.
Portis, further thoughts please!:
I believe my under layers would be equivalent to what you are wearing.
My LBS shows the Zephrr vest online. They may have the jacket in the store. Do you think the vest would be enough?
https://bgindy.com/itemdetails.cfm?catalogId=1&id=8098
They have the Louis Garneau Stratos jacket that might be close to the Pearl Izumi Zephrr.
https://bgindy.com/itemdetails.cfm?catalogId=1&id=8585
Gone, but not forgotten
Bikes: spicer fixie, Haro BMX, cyclops track, Soma Double Cross, KHS Flite 100
Conversely, your arms can get very cold if windchill is significant. I do use an unlined vest but I use it as both a wind shell and sometimes as a light mid layer/shell. In the 40's I will wear the jersey shown above with just an unlined vest over the top. That is sufficient.
In the 20's I will use the vest under my jacket above or perhaps under my Gore tex jacket. (i wear the gore tex jacket in VERY cold temps)
This is MEC's best jacket i think for just a shell.
https://www.mec.ca/Products/product_d...=1162602812071
It keeps you dry for quite a while when needed, breaths great, has pit zips, thumb loops, is priced cheap, has reflective strips, and can be jammed into a jersey pocket.
Edit: if you need any more minimalist in a shell, look for a houdini jacket, but be prepared to pay 3x as much
In Real Life
Bikes: Lots
Liked 596 Times
I have a whole closet of choices ... I've got a vest, a light windbreaker, a waterproof/breathable jacket like the one I mentioned above, and a winter cycling jacket ... plus quite a few others ... all (including the vest) with venting, of course. Some were quite inexpensive (i.e. on sale at Nashbar), some were more expensive (i.e. the waterproof/breathable one which I must say has been one of my best cycling purchases - no regrets there!!)
I ride all year round in conditions ranging from very hot to very cold, and dry to soaking wet ... so I just pick the item I think best suits the conditions.
So don't feel you have to limit yourself to one choice.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
In the temps you're riding in, I think a vest (combined with wool and/or polypro) would be enough.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
You also don't say what your head and hand coverings are. Often these can have an influence on the rest of your body. I find that I don't need a head covering but only something for my ears down to 16 F or so. I also wear what most would consider light gloves down to those temperatures. When I need to shed heat, I'll change to cooler gloves and remove the ear warmer. It helps a lot.
Stuart Black
Stuart Black
https://www.pearlizumi.com/product.ph...color_code=021
I have just been wearing some light cotton glove liners that I bought a long time ago for skiing and they have kept my fingers nice and warm. I have ski mittens to wear if it gets really cold. I looked at cycling gloves the other day but opted to stay with what I have for now unless future experience dictates otherwise. I liked the gloves that had mitten hide away covers for really cold temperatures.
It looks like the ideal jacket would be water resistant, breatheable, have arm pit and back vents, removeable sleeves, and fleece neck lining. I would specify removeable liner also but I have not seen one with that feature. As you can see, I would like to have only one coat that does it all which may not be possible.
My wife drives me crazy because my son has 5 different coats.
Liked 4,218 Times
I, like you, have just been wearing a headband to cover my ears. It was warm enough for the temperatures that I have been riding but it was too thick to wear with my goggles(Bolle's with optical inserts so I have to have them). There was not enough room between my helmet and goggles for the headband so the goggles were being pressed down on my face and were uncomfortable. I also could not use my third eye. I purchased a Pearl Izumi Microsensor facemask to use in cold weather that I hope will accomodate my goggles and possible the third eye. I have not tried it yet. I may just wear my regular glasses.
I mount my mirror on the helmet because I can't stand the extra weight on my glasses.
Stuart Black
Stuart Black
Biscuit Boy
In Real Life
Bikes: Lots
Liked 596 Times
Originally Posted by Cosmoline
Above zero? That's not cold. That's shorts weather! Just stay dry and you shouldn't have any problems in those temps.
And the OP has indicated that he is a warm rider (whereas I'm a cold rider - I feel cold the moment I get on my bicycle in all but really HOT weather unless I have several layers of clothing on) .... which is why I suggested a wool layer or two, and a vest to block the wind.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Good to know
(I use Rudy Project Kerosenes with Rx insert)
