Clydes appproved seat post?
Destroyer of Wheels
So, I'm riding my new folding bike with an al seat post and tonight when I tried to put the seat down it got stuck. Looks like the post is bent
Should still be under warranty so once I get [out the bfh and use it to get] the seatpost out I should be able to send away for a new one. It has me wondering if a new one will do the same over time. I probably have less than 60 miles on the bike.
So, any thoughts on a beefier seatpost? Weight is irrelevant to me (well the weight of the bike anyway!). The post was not near the warning mark though a lot of it was out of the tube.
If this should be in mechanics someone can move it - figured this would be a good starting point.
Thanks!
Thanks!
The Almighty Clyde FAQ || Northeast Index
eTrex Vista References || Road Reference
It's the year of the enema!
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Well what brand and model was it? I' ve had no problems with Thomson. But paid $80 bux!
POWERCRANK addict
I use a Deda Metalstick which seems plenty strong so far - you may also want to try downhill specific seatposts that have internal reinforcement
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
+1 on Thomson. I still have the original after 8,000+ miles. In that time I've broken rails on 2 different saddles.
Bob
Bob
Senior Curmudgeon
Bikes: Varies by day
Quoted: 5 Post(s)
Seatpost DIAMETER is more critical in avoiding bending than brand, IMHO. The larger the post diameter, the more resistant to bending. "Cruiser" bikes with 22.2mm diameter seat posts are sure "benders" when I rode on them. That's why I sold my cruiser!
In my experience any seatposts that are 27.2mm diameter or larger handle my 275# weight without bending.
There's another consideration to be taken into account with seatposts other than bending - what happens with really large impact-stresses? In early June of this year, a rear rim blew on me. I was thrown into the air a foot or so and come down on my 31.6mm seat post. The post didn't bend. The one-bolt seat-holder, though, snapped that single bolt into two pieces! The seat came completely off the post and dumped me (and the seat) onto the pavement at high speed. I was lucky I wasn't impaled on the remains of the seat post itself!
I now use a two-bolt seat post (Thompson), and I've spent some time bouncing up and down on it to make sure I get no surprises. So far, zero failures. I don't plan to ever use a one-bolt seat post again.
Nishiki road bike, Raleigh road bike, Electra Cruiser Lux 7d, Electra Townie 3i, Electra Townie 1, Whatever I find today!
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Senior Curmudgeon
Quoted: 5 Post(s)
Originally Posted by Tightwad
Call Worksman cycle about one their SOLID STEEL seat post. www.worksman.com
The Worksman posts, however, ARE significantly thicker and stronger (but not significantly larger in diameter) than the average cruiser bike seat post. Thick enough to resist my bending them? I don't know - I haven't tried them.
Thompson. They're amazingly strong, first and foremost. Every serious mountain biker I know swears by them, so that should say something about durability. There are seat posts that are just as good, I'm sure, but Thompson has the best rep and great service.
Bikes: Giant Trance 4 & Jamis Satellite
Ken
Bikes: Lots
+100 on Thomson. I've used their Elite seatpost on all my bikes in the last 8 years without one problem.
Although expensive, you can usually find a deal on Ebay or even used.
The thing I really like about Thomson and any others I've considered buying (but haven't) is the double bolt design. Single bolt designs will strip out. Especially for us heavier riders.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Bikes: GT Edge for the road/Specialized Hopper (well the frame and the bb, everything else is new) for the dirt
I have a seatpost on my MTB which has reinforcement ribs inside. (Viewed from the base it looks like a Mercedes logo...)
I used to bend posts on that bike all the time. That one is ten years old and from the college days, so it couldn't have been too expensive. If you want me to check brand, just let me know.
Destroyer of Wheels
Thanks Hambone - I appreciate it! I like the idea of something reinforced. The solid steel design sounds like a good idea too. Is this the Thompson?
There is a ton of NOS stuff like this on ebay for like $15. But I couldn't tell if it was the kind I have with the rib/reinforcement inside. I'll leave that research to you...
IM me if you want me to look for serial/model numbers tonight.
Bikes: Lots
That's it. No "P" in Thomson.
You can usually find them on ebay for around $60.
I picked one up used for $40 that was still in great shape!
Perma-clyde
Bikes: '05 Stumpy FSR 120, REK TEK Blitzkreig (Commuter)
There's no single rule about which material is better for a seatpost. Steel has a higher breaking strength and greater resistance to fatigue than aluminium, but if the steel is not processed properly (wrong microstructure) it won't work for us clydes. I remember trying a ZOOM post in the early 90's; it was ultra-light steel but within a week of commuting, it was bent back like a banana. Replaced it with an aluminium Syncros post that was still straight, true and on the bike when I sold it ten years later.
Destroyer of Wheels
Update: After a while with a plastic rod and my hammer I finally got it out. It's funny, was keeping that around just in case I had a use for it. Turns out it was the perfect size and hardness to fit inside the tube and be able to wack it out from the bottom. Now that it's out I can tell how bent it is; couldn't tell as much when it was on the bike. Oh well.
Needs to be 27.2 in diameter and have at least 340 mm from the top of the frame (or the min line) to the seat rails. Thomson has one 27.2 but only 410mm long. I can't find on their site how much of the post has to be in the frame but I'll assume at least 100mm? A little too short
Anyone have any history with Thudbusters? They have an extra long suspension seatpost (look halfway down). While I don't like the idea of a suspension seatpost my seat (with springs) on my mtb is quite comfy plus the Thudbuster is adjustable to a fairly firm setting. I fired off an email to see what the weight threshold is.
Also checked out Worksman. Very, very helpful - though what they carry won't work. What he suggested though was to take a tube that will fit inside and tack weld the bottom to give it extra strength. I'm hearing that 25.4 will fit inside a 27.2 Thudbuster but am trying to find some more information on that. Ideally I'm thinking a steel rod inside will corrode a bit and basically fuse to make one superstrong post. Thoughts?
Hambone: Looked up the Tahomas - as far as I can tell they don't come that long but if you think yours is than I'd love to know the model number!
Man, wouldn't think this would be such a process! Thanks all!
Keep in mind, many seatposts are not cylindrical on the inside. They "ovalize" them to make them stronger... You need 13.6 inches of post? I've never measured my MTB but that seems like a lot.
I'm no engineer but I was going to tack weld something inside, I'd try and go with angle iron first. That would be even stronger. Keeping in mind that you really need protection from bending in primarily one direction.
Destroyer of Wheels
Thanks Hamone! It is a lot - but it's a folding bike so it's meant to be long so the bike can fold up.
Bikes: Pedal Force QS3
Ritchey Comp.
15% Hammer Nutrition Discount Code
I'll check tonight.
Destroyer of Wheels
I'm not the most important thing in your life? I'm insulted! Glad to hear you got that fixed!
When you get a chance, I've resigned the fact that that bike will sit for 2 weeks - another day isn't going to hurt
Destroyer of Wheels
Originally Posted by Dial_tone
Ritchey Comp.
Gorntastic!
Thompson Elite - I've been riding it for 8 yrs.
I just got a new bike that came with a carbon seatpost and I immediately replaced it with my Thompson.
Destroyer of Wheels
Do you know what the minimum has to be inside the frame?
