Widest tire on an Open Pro ??
How wide a tire can I safely put on an Open Pro rim? I'm guessing 32, but hoping for 35. General purpose, utility use including commuting and general dinking around.
Liked 6 Times
I've run 2.35" tires on rims narrower than an Open Pro (Matrix Mt. Titan, a rolled-down version of an Iso-C II). I'd go for the 35's without a second thought.
lunatic fringe
Bikes: 1980 Schwinn World Sport, 1982 Schwinn Super Le Tour, 1984 (?) Univega Single Speed/Fixed conversion, Kogswell G58 fixed gear, 1987 Schwinn Super Sport
lurking nightrider
This is Mavic's recommended size and pressure chart:
https://www.mavic.com/ewb_pages/p/pis...=3&gamme=route
[edit] You might want to read this thread:https://www.bikeforums.net/showthread...ht=cracked+rim
"If there hadn't been women we'd still be squatting in a cave eating raw meat, because we made civilization in order to impress our girl friends. And they tolerated it and let us go ahead and play with our toys." Orson Welles
Tim
Quoted: 2026 Post(s)
Liked 1,095 Times
Open Pros are favorite cyclocross rims and are typically fitted with 35 and 37 mm CX tires.
If in doubt Fix it
Bikes: All Hand built: Raleigh Record fixed conversion, On-One Pompino, Felt TK2, Look KG451, Rychtarski Lo-pro, Orlowski Lo-Pro, New Hudson, Haro X2
I've got some 38c CX tires on mine
Hypoxic Member
I'm running Mich. Jet 700-30 cross tires on CXP-33s. The CXP33s have just about the same width as the Open Pros. These 700-30s are wider than most 700-35s. (So much for standards!) I would feel safe doing what as you wish.
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
But the main problem with going slightly over isn't any kind of catastrophic failure, it's that the edges of the tire will be "squirmy" from bulging over the rims... this is common on mountain bikes as Sheldon's page points out. If it seems to work okay, then go for it.
Perineal Pressurized
Fixed in the dirt !!
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Now the frame, some frames, are designed for a certain tire limit, and going to a wider tire, will cause it to rub on the stays or the brakes. I would say make sure you have at least 2mm on either side preferably 4mm and the same for the brake and chain stay bridges although you want more like 8mm of room there.
If in doubt Fix it
I agree, check the frame clearance this is what mine looked like with the 38c's on it
