Tire Pressure question
When I don't ride for a couple of days my tires lose pressure is this a common problem? I was thinking it was due to the high pressure but not sure. Appreciate any thoughts.
Bikes: Kestrel Talon, Trek 1200, Specialized Rockhopper FSR, Specialized Enduro Expert
Yup. I top my tires off at least once a week.
Quoted: 104 Post(s)
Liked 5 Times
If you're using ultralight tubes, you need to top them off every day or two. Standard weight tubes will hold their pressure for several days.
I check pressure before every ride. My current tubes are have been exceptionally good at holding pressure, but I've had others that lost 5psi or so over 24 hours.
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
Tubes will leak. Get yourself a good floor pump if you don't have one already, and you can top off both in a minute or two every couple of rides.
Guest
Posts: n/a
Quoted: Post(s)
Every ride.
Bikes: Trek 7300FX, Lemond Sarthe
My experience has been that the heavier the tube, the better it holds air. I have some Schwalbe's on my hybrid (I run them at 60 psi) and they only lose about 5 psi a week but they weigh 146 gr. My conti race's weight about 100 gr. and I run them at 100 psi but they lose 5 psi a day.
Sounds good....appreciate everybody's help and advice. Merry Christmas (or Happy Holidays, if I've offended) to all.
Bikes: Trek, of course.
One more thing.... if you blow your tube up with CO2 cartridges, count on filling the tire the next day. For some reason CO2 doesn't last as long as good ol' air.
I'm embarrassed to say I am a chemical engineer and for the life of me can't explain why CO2 leaks from tires faster than air. The only thing I can even think of is that filling a tire with a cartridge is done so quickly that rapid decompression triggers ice fragments into the tube that prevents the good seal you get from slowly filling with a floor pump. But that may be a stretch. If anyone has something more definitive I'd love to hear it.
Trekaholic
Trekaholic
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 29 Times
Quoted: 62 Post(s)
Liked 29 Times
Trekaholic
Trekaholic
Originally Posted by bbattle
I believe we've covered this before and I believe it's due to the lower viscosity of carbon dioxide over oxygen and nitrogen molecules. Table here shows that yes, carbon dioxide's viscosity is lower than that of air, or oxygen or nitrogen.
just like pure hydrogen is almost impossible to contain cause the molecules slip thru anything
Quoted: 62 Post(s)
Liked 29 Times
Originally Posted by pedex
viscosity..hmm, odd way of looking at it, molecule size is what I guessed, sort of same idea I think
