Pine needles in brake caliper
Bikes: 2022 Kona Dr. Dew, 2022 Specialized Vado
Liked 110 Times
Living in the southern US, we have a few pine trees. And the paths, trails I ride are always littered with pine needles. I know that some debris will always get into my brake calipers and I have been diligent about cleaning them after rides, but lately this has been getting ridiculous. Typical path:
Pine needle path
I had a Kona Dew with the Clarks M2 hydraulic disk brakes, and now have a Dr. Dew with Shimano Altus brakes and a front fender. Specifically, the rear caliper is mounted horizontally on the chainstay on both bikes. The Clarks got so packed with pine needles that the rear stopped working altogether and had to be rebuilt. And this weekend, I had to stop a few times to unpack the needles from the Altus caliper; then do a full cleaning when I got home. As in the picture above, I am not riding through bales of pine needles, they are just unavoidable here.And I am running 650bx47mm Specialized Pathfinder Pro tires.
My other bike, a Specialized Vado with Shimano BR-MT200 brakes, has never had this issue in 2600 miles.
Anyone have clever ideas to prevent the pine needles from getting pulled into the rear caliper while still allowing airflow? Again, I expect some debris, it's natural; but that they get so packed as to stop working is confounding. (Aside, the jockey wheels also get completely wrapped in the needles but those wheels seem to chew the needles up and not impact their movement.)
Pine needle path
Old fart
Liked 3,675 Times
Maybe something like a flint-catcher mounted on the back of the rack to knock the needles off the tire before they get near the brake?
Likes For JohnDThompson:
THey are probably climbing up the kickstand...
Likes For wheelreason:
Liked 4,331 Times
Edit: read the OP. Rear wheel. Sorry JohnD, my comment wasn't right. And being a rear caliper, you could mount something like the glass catcher on the seatstay, only instead of a wire, it should be say a half dollar coin of lightweight aluminum with a narrow slot just wider than the disc. Maybe bent into a "V" to shed the needles off to the side instead of piling up. R&D time. (There are probably grants out there to fund research on best disposal of used needles that could be had with the properly worded application. )
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Liked 356 Times
I had problems with the rear derailleur and cassette clogging up when forced to ride through piles of leaves. I started riding with a spoke hidden on the bike, bent to yield a handle on one end and a hook on the other. The next time I used that spoke was to pull the chain thrown off by a twig that got caught. The spoke might be too crude for your needles, but still, you might need some instrument for them, before and even after you develop some protection.
Likes For 2_i:
You could take a small dia. bottle brush, bend the end into a U shape that would lightly touch the disk brake surfaces and use zip ties or tape or ??? to fasten the brush handle to the stay with the brush positioned over the disk section before it rotates into the caliper. If it works you could make a more elegant setup but try this first.
Likes For Crankycrank:
Liked 110 Times
The Dr. Dew does not have a kickstand, I no longer have the bike in the picture. I do take some small needle-nose pliers and a piece of small diameter coat hanger to get the junk out during rides.
JohnDThompson and Crankycrank thank you for the suggestions - gives me something to try this evening. If I get this resolved, I'll post the solution.
Happy With My Bikes
Liked 2,753 Times
Looks like a pretty place to ride a bike.
Do you have a picture of the needle cloggage? It might help folks get some more ideas to run up the flagpole.
Liked 2,710 Times
we’ve run through areas with heavy pine needle accumulation and no issues
multiple times
hmmm … will need to pay more attention next time
multiple times
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,973 Times
Liked 1,844 Times
Even without disks its a good idea ta check your bike after a pine needle ride. But what a ride. Although at times kinda slippery our single track through the pine trees was nice, soft, and quiet.
I miss them as they are no longer around. They were destroyed by ebike riders trying to play like dirt bike riders (motorcycle) and now they belong to dirt bikes only...
Liked 2,710 Times
Likes For t2p:
Liked 356 Times
My particular situation was of a pile of fluffy leaves blown by the wind into the passage. My wheels were buried maybe 10" deep. In situations like in your photos, I usually just get twigs in the drivetrain or leaves under the fenders. I learned that I still should stop and get them out, not only to get rid of the mild nuisance but to prevent the situation from escalating.
Likes For 2_i:
Liked 2,710 Times
we almost always kick it down a notch when we are riding through heavy leaves - regardless of the surface … crushed limestone, dirt, or black top / pavement … actually MUP / rail trail paved surfaces can be the worst when there are heavy leaves over raised areas or cracks (due to roots under the surface or heaving / breaks from freeze / thaw)
they do make a cool sound though when they are dry
Liked 110 Times
Here is the bike in question, since it seems I confused some folks. The orange-ish bike in the previous photo is a '23 Kona Dew Plus, again I no longer have that bike. I am now riding a '22 Kona Dr. Dew - similar geometry to the Dew, but steel frame, different drivetrain and brakes (brakes mounted in identical location). This picture is prior to swapping the Maxxis DTR-1 tires that it came with for the tubeless Pathfinders on it now.
Liked 2,710 Times
maybe the pine needles are transported from the ground to tire to rack (as the tire rotates) and then down onto the caliper ?
maybe if you rode slower the pine needle journey / trip would be shortened ?
different tire ?
do you have a go pro to mount in that area ?
different tire ?
Liked 2,159 Times
I usually deal with leaves, and like [MENTION=553936]t2p[/MENTION] it's usually stuck in a fender. On those rare occasions when it gets into the brakes or chain, the leaf of interest usually becomes dust pretty quickly.
JustaJoe how long does it take to jam up your brakes? Could you stop every 15-30 minutes and swipe an index card through each side of the disc? Or if the card folds, go by a hobby shop and get a piece of sheet metal, cut and file the edges, and use that instead.
Alternatively, perhaps get some slick tires to reduce the lofting lugged tires do to the needles?
Liked 2,710 Times
maybe you can fabricate something small that will sit over / near the caliper … to catch the pine needles … so they are not ‘ingested’ …
sorta / kinda like the rear part of the disc brake protector on the motorcycle (pictured above) … just the rear portion of the protector where it sits over the caliper
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Liked 480 Times
Leaf debris was an issue, lately it’s been water and construction.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Liked 110 Times
I was thinking a dork disk on that side of the wheel might help, but I don't have one. I tried a few mock-ups last night with card stock - made different shape "shields" for the area, but none did it for me. I'll do more mockups and if one looks promising, I'll re-make it out of thin aluminum sheet. Now that I type this, a design has come to mind....
Bikes: 1995 Trek 990 (configured for road), Hotrodded Dahon folder, Trek 1400 (not ridden any more), Iron Horse 3.0 homebrew e-bike, 1984 Trek 770 (trying to resurrect)
Liked 190 Times
Yeah. They might also be getting tossed up by the front tire. If so, a front fender that drops down further might help. Figuring out what is the most common way the needles get to the caliper would help. If you know where they are coming from, you could fabricate a shield of some sort.
Liked 2,710 Times
Liked 2,710 Times
could not find pics of heavy pine needle accumulations
but did find pic of mrs t2p standing next to a small white pine …she’s a white pine fan girl
Liked 1,844 Times
Likes For zandoval:
