Want to save $1000 or more on your next bike buy?
Old 07-30-11, 10:42 PM
Oldie
Again's Avatar
Bikes: Lance Exodus Europe, Univega Sportour, Motobecane Cafe Latte
If you expected to find a marketing ploy in this thread I have to disappoint you, or maybe relieve you.
I am not trying to sell you or point out a special sale.
What I am trying to get across is that it is quite simple to save that much money on the purchase of a top level bike. Independent of sale specials!
For argument's sake lets say that a quality road bike that weighs 2lbs less than the next model may cost you an extra $800 to $1000.
If one 180lb rider bought a 24lb bike for $3000 the total weight of bike and rider is 204lbs.
If the same rider went on a low-carb diet for a month and dropped 2lbs in weight (which is real easy to do over 4 weeks, and will stay off!) he could buy a 26lb bike for $2000, at a $1000 saving.
These numbers may be arbitrary, but that is not the issue, and hopefully, you still get the point.
Again is offline
Old 07-30-11, 10:54 PM
esldude's Avatar
Bikes: 1981 Motobecane Mirage, 1987 Peugeot Tourmalet, EZ Racer recumbent, 1994 Trek Singletrack 930, 1999 Canndondale SuperV500SL, 2001 Gunnar Crosshairs , 2009 Gunnar Roadie.
Okay, but if the buyer dropped 2 lbs, and got a bike 2 lbs lighter, well he would be 4 lbs better off. Instead of $500 per lb less it would be down to a much more affordable $250 per pound. Just saying........
esldude is offline
Old 07-30-11, 11:00 PM
Come on you Spurs!
renton's Avatar
Bikes: Trek 2.1, BMC Roadracer SL01
But I needz the carbz.
Valid point otherwise, except for riders that can't loose any more weight. (Not my case)
renton is offline
Old 07-30-11, 11:01 PM
Oldie
Again's Avatar
Is that better than losing 4lbs over two months for a $2000 saving?
Your methods aims to spend extra $$$ for a lighter bike, while mine aims to spend less $$$ for a heavier one - and the total weight of bike and rider would be equal with either method.
Again is offline
Old 07-30-11, 11:05 PM
Middle-Aged Member
MikeyBoyAz's Avatar
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
or you can just buy the bike you want, and weight whatever you want.
MikeyBoyAz is offline
Old 07-30-11, 11:11 PM
DessertS
Kurogashi's Avatar
But does 1 pound of the belly = to 1 pound off the bike?
I remember someone saying it's not because weight on the body can be used to help one pedal, while wait off a bike is really a win-win situation. Not sure if this is entirely true or not, or if this fact justifies forking over $1000+.
Now would aesthetics be enough to justify a bit of my overspending?
Kurogashi is offline
Old 07-31-11, 03:21 AM
esldude's Avatar
Nope, not the same weight. Losing 2 lbs off body and bike at same cost is twice the weight loss at the same $1000 price.
Look I was just funning anyway.
These discussions are pointless really. How heavy a bike will you ride and enjoy? A common limit mentioned is 40 lbs max for bike and gear. Even subjectively other things come into play. I have a 30 lbs MTB that rides much lighter or so it seems. Had a 34 lbs MTB that rode, well at least all of its 34 lbs though it was still fun to ride. Just not as nice once you have been on something better. Have a 25 lbs MTB that rides pretty darn well, but not as well as the 30 lbs bike (the heavier one is a susser the lighter a rigid).
Road bikes, I have an old bike that is 27 lbs. Frame fits well, and I like the way it rides. It does ride a bit less well than my newest 18 lbs. road bike. Though the difference is not all that great. Lighter is better all things equal (which they never quite are). If money were no object, I would have a 10 lbs bike if its possible. Money being a concern changes he equation. A strong low end frame with modest entry level components that fits is still pretty darn good. If I have the money I can move up from there. It is diminishing returns for sure.
So in short, no I don't get your point at all. Is it that we all should save money and lose a couple more pounds? Is it that considering money lighter bikes at another kilobuck are evil? Should I lose 6 pounds and pick up a heavy old bike at the thrift store for $15? Really, what is your point? This is without even mentioning that also while small differences the more expensive bikes also have higher end groups and wheels etc. that feel a bit nicer. You are buying a bit more than just weight. Really, what is your point?
esldude is offline
Old 07-31-11, 06:31 AM
Liked 474 Times in 281 Posts
That's nothing. I saved $15,000 on the last car I bought. I just bought a Honda Fit instead of an Odyssey. I guess the point is that there's always a cheaper alternative that someone else will tell you meets all of your functional needs.
asgelle is online now
Old 07-31-11, 06:58 AM
These Guys Eat Oreos
Creatre's Avatar
Bikes: Yes
What happens when you are less than 140lbs like me? Guess I need a 50lb bike to make it fair.
You are paying for more than the weight of the bike. Components are better, frame material is stiffer/lighter, and everything will be a bit nicer.
If you want to just straight up get a cheap bike that is decently light, get it used, go to bikesdirect.com or neuvationcycling.com and then you won't have to lose as much weight and you saved money.
Creatre is offline
Old 07-31-11, 07:08 AM
Liked 16 Times in 10 Posts
Age old argument at bike shops and it has some validity. It doesn't change the fact that a light bike just feels better regardless of rider weight.
jdon is offline
But if you buy the expensive bike and can't afford to buy groceries for a few weeks afterwards, you'll probably lose more than 4 lbs anyway. This is the BF solution.
MKIV987 is offline
Old 07-31-11, 08:08 AM
Bikes: Felt AR1, Cervelo S2
Liked 4 Times in 3 Posts
Clearly the OP is smarter than everyone who has ever bought a bike ever.
Inertianinja is offline
Old 07-31-11, 08:13 AM
WhyFi's Avatar
Liked 9,462 Times in 4,673 Posts
Don't you love it when "enlightenment" hits someone?
WhyFi is offline
Old 07-31-11, 08:21 AM
Bikes: 2009 BMC SLX01/2016 Santa Cruz Bronson
Liked 3 Times in 1 Post
Just buy whatever the hell you want and ride.
jesspal is offline
Old 07-31-11, 08:50 AM
tagaproject6's Avatar
Liked 278 Times in 146 Posts
tagaproject6 is offline
Old 07-31-11, 08:56 AM
Oldie
Again's Avatar
Of course, if money grows on trees for you!
Again is offline
Old 07-31-11, 08:58 AM
Should Be More Popular
datlas's Avatar
Liked 9,565 Times in 4,422 Posts
Lookit, I agree that spending 1000 bucks just to shave a pound or two off your bike may be silly.
However, the "higher end" components, besides being lighter, can often provide better performance.
For example, continental GP4000s tires give a much better ride than the stock tires that come on an entry level bike. Maybe they are a smidge lighter but that's not the goal.
Same goes for better components, drivetrain, etc.
So I respectfully disagree with your premise.
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Old 07-31-11, 09:01 AM
WhyFi's Avatar
There's nothing respectful about my disagreement with it. It's completely false - if you can lose two pounds of gut for the heavier bike, you can lose two pounds of gut for the lighter bike.
WhyFi is offline
Old 07-31-11, 09:02 AM
Oldie
Again's Avatar
Of course, if money grows on trees for you, too!
Again is offline
Old 07-31-11, 09:06 AM
Oldie
Again's Avatar
How about the aesthetics of your trimmer body? They are an additional side benefit.
Again is offline
Old 07-31-11, 09:11 AM
You can save even more by not buying a bike and find an alternative means of exercise.
Old 07-31-11, 09:24 AM
WhyFi's Avatar
Not to mention the huge savings on your rider/bike combined weight.
WhyFi is offline
Old 07-31-11, 09:25 AM
I like beans
eippo1's Avatar
Bikes: Tarmac Pro, Bianchi Zurigo, Raleigh Gran Sport, Fuji Del Rey, Ironman Centurion
My weight is right where I want it and my bikes are right where I want them. I had a heavier steel bike recently and hated how it felt to ride. If I don't like riding it, it's not worth any type of money. I'll starve myself so that I can ride that which makes me happy out on the road rather than throw good money at something I do not enjoy.
eippo1 is offline
Old 07-31-11, 09:26 AM
Oldie
Again's Avatar
Agreed, at least for some people they are. For others, they may be valuable. I made my point for the others.
How heavy a bike will you ride and enjoy? Road bikes, I have an old bike that is 27 lbs. Frame fits well, and I like the way it rides. It does ride a bit less well than my newest 18 lbs. road bike. Though the difference is not all that great. Lighter is better all things equal (which they never quite are). If money were no object, I would have a 10 lbs bike if its possible. Money being a concern changes he equation. A strong low end frame with modest entry level components that fits is still pretty darn good. ... So in short, no I don't get your point at all.
Ah, it looks like you *are* getting my point, after all!
That of course, is up to the individual. And his or her needs/priorities/abilities, or will power. What do you weigh? Would it do you any harm to shave 2lbs off it and would you have trouble spending $1000 on some other luxury?
We all understand that you pay for component groups as well, although much of that also concerns weight savings. However, the overall logic still applies. I am sorry, but I can't make my point much clearer than I did. You neither have to understand it, nor agree with it. I brought it up for those people who do.
Again is offline
Old 07-31-11, 09:28 AM
Bikes: Cervelo S3, Pinarello Dogma F8, Santa Cruz Bronson
I'd say get the lightest / highest quality bike you can afford AND lose as much weight as possible..that way you are likely to end up riding it even more.
EnellCH is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
