'72 Schwinn World Voyageur 650B - Finally!
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Liked 8 Times
I finally finished up the '72 Schwinn World Voyageur I've been slowly working on since about December. There was a lot of rust cleanup, much sanding and polishing and a goodly amount of swearing. Everything is hunky-dory now though.
so shuddup and get to the pictures already.
as purchased, looking rough
I was determined to keep as much Orange as possible....athough as you can see a lot was lost.
in the end its a sexy lookin beast. Just lookit the size of that front hub!
Deore SP in lovely condition.
Sugino Super Mighty with a little drillium
old butchered Wrights
Time for a ride
here's the full rundown:
Panasonic Made Schwinn frame
Velocity Synergy rims (Offset spoke bed in the rear)
Double Butted Spokes
Rear Shimano FHR-700 hub, Miche 7 speed cassette 16-22
Front Sturmey Archer XL-FD hub
Grand Bois Hetres 42mm x 650B tires
Sugino Super Mighty Crankset 52-42
Wrights Saddle unknown model
Cane Creek SCR-5 Brake levers
Shimano Deore SP derailleurs and shifters.
MKS Track pedals.
Schwinn Approved Stem
Time for a ride
MKS Track pedals.
--Don't Panic.
--Don't Panic.
Very cool! I'll be it rides like a dream.
Neal
Neal
Nice! How about a ride report??!!
What kind of clearance do you have with those fatties? How do the roller brakes work? How do they feel with road levers?
Liked 8 Times
just got back from the first ride. Just a quick 10 or so miles.
It certainly does ride like a dream. I think I've gotta put a little more pressure in em than 50psi though. They definitely stretched a bit over the course of the first ride just as Anton had mentioned in an earlier thread. I've got about 3-5mm clearance at the chainstays, which is close but I've cut it closer on other bikes.
The drum brakes take a bit of time to brake in (<--see what I did there? ) so the rear is grabby right now and the front needs to be adjusted tighter.
The gearing is very nice. I really like the 16-22 (7 speed) straight block. Pairing it with the 52-42 Crankset is a bit ambitious for me though so I'm gonna swap it out for a TA Cyclotouriste 48-28 until I can get my hands on a set of triple chainring bolts and a 38T ring and make it a 48-38-28. I still havent ruled out swapping the 22T big cog for a 26 or 28T. There's big hills around here.
The Deore SP drivetrain is a work of engineering perfection. No lie. I freakin love it and its not just new gear lust. The RD has the same capacity as a Cyclone GT but Its smoother operating and has a cool mechanism built into it that eliminates the need to overshift and then trim the derailleur back on shifts. Its a little spring loaded arm that attaches to the derailleur cable. When you shift you shift until the gear changes and just let go of the shifter and you feel it spring back a tiny bit in your hand as it releases a tiny bit of extra slack it took up, thus trimming your shift for you and eliminating the need to overshift and trim it back. I dunno if that just made any sense so I'd just recommend going and getting a Deore SP derailleur and trying it out. Its super cool.
--Don't Panic.
--Don't Panic.
How was it getting those Hetres on the synergies? I practically tore my skin clean off getting those suckers on.
I can't remember how long it took mine to stretch out a bit and settle in, but I'm finding that 50psi for road use is on the high end for me, but I'm only 160lb. I've found the "sweet spot" at about 45 rear, 40 front for road riding. Higher than that, and the ride approaches that of narrower 700C tires (still not bad, just firmer), and lower than that I begin to feel a little drag, and the front end feels heavy. But for gravel and woody tails, I've found 35 rear, 30 front just about perfect. How do you intend to ride this bike, primarily?
Liked 8 Times
actually the tires were quite easy to mount. I was surprised.
I'm not entirely sure what kind of duty this bike is gonna see yet. I'm kind of thinking its gonna be a comfy all-day rider kinda thing. It might displace another bike of similar purpose, or it might end up that I just really like the wheelset and drive train most and move it over to a different frameset. Time shall tell. The main purpose was to experiment with 650B, and to try out a straight block cassette. So far I like both.
I just finished switching the crankset around, gonna go try the 48-28 and see how it is.
--Don't Panic.
--Don't Panic.
Bikes: 76' Centrurion Pro-Tour, 86' Specialized Rock Hopper, 88' Centurion Iron Man, 89' Bruce Gordon "Hikari", 95' Rock Hopper Ultra.
Well done Sir!!!
I have seen one other World Sport/650b conversion, it had really long brake arms that just didn't look right...Your bike looks GREAT! (I have a thing for high-flange/big hubs) I've also seen lots of pics of Herse and Singers with straight block freewheels, and Triples up front, should be pretty cool! Is there room for fenders?
Cheers,
Chris
Cheers,
Chris
Dropped
Where did you get that frame? There was a woman in Sparta selling an orange World Voyageur in that size a year or so ago. I was tempted, but left with her husband's Specialized Sequoia only.
Liked 8 Times
Thanks folks Its nice to have something like this, warts and all where its a handsome thing and a bit of a head turner but not a showroom queen where I'm constantly worried about scratching it or whatever.
The frame came from ebay as a frameset w/headset and BB. I probably overpaid based on the condition (spent around a hundred bux on it) but, hey its a full chrome Panasonic.
Chris W, Cool to hear about the old constructeurs with the straight blocks. I can see the appeal. I can also see that a Triple crankset would be optimal on this.
There's plenty of room for fenders, and I do have a pair of stainless 650B fenders I'm considering putting on. Just not totally sure because I'm really liking it in its current, kinda minimalist splendor. Also its surprisingly not heavy. yer welcome to come ride it any time Colonel!
--Don't Panic.
--Don't Panic.
Bikes: 1969 Raleigh Sports: The Root Beer Bomber
At first glance I thought the tires WERE the fenders, because they were so smooth and lovely looking. What a gorgeous bike! Nicely done.
Bikes: I hate bikes!
Liked 864 Times
I like it! You have to put those chrome fenders on...they match the lugs & paint scratches! I had an orangerWV I put an Nexus 8 speed hub in, sadly too small for me but it did get a good amount of "nice bike" comments.....
Liked 8 Times
I'm so torn about the fenders. Its funny too because I traded a Nexus 7 rear wheel to get the fenders and now I'm having doubts about using em Its kinda silly but here's my thought process. I've got 3 bike with fenders. I've discovered that I have a love-hate relationship with fenders. I'm getting better at installing fenders but it seems my penchant for fat tires cramps (quite literally) the fender style. Tire rub is my mortal enemy. Before each ride I need to pick up the front and rear wheels one at a time and spin them listening for any tire rub on the fenders. It might change from day to day because I leaned the bike up against something or another and the fender stay bent ever so slightly, or a nylock nut has magically worked itself loose despite decades of engineering telling it not to.
Also I've got some kind of psychosomatic thing going on where when I put fenders on a bike it instantly feels 2mph slower. I dont ride with a speedometer so I don't really know but it was the case with my Super Course, my Austro Daimler and my Centurion Pro-Tour...they just feel slower to me with fenders. Oddly enough my Dawes feels great with fenders but those are plastic SKS jobbies....maybe there's something to be gleaned there, but I think that's more just validating that I am clearly insane.
I wish I could get past that, but its like a crazy mental block or something and I'm afraid to make it ride less awesome. I know it would look more awesome though. No doubt about it.
Its so surprisingly lightweight right now too.
I am very torn about the crankset as well. It needs a triple for around here, but I think i'm gonna go back to the 52-42 for now and just htfu.
--Don't Panic.
--Don't Panic.
incazzare.
I saw one of these yesterday--same color--for sale at the flea market in Fort Greene, Brooklyn. I don't know what the guy wanted for it. It had been converted to a single speed (or maybe fixed), and it was really very nice looking. If you're so inclined and in the area, the same guys are always at the flea market in Fort Greene on Saturday and Williamsburg on Sunday, so it's probably up for sale there right now as I type this. My guess is he would want $400 or so for it. I'd guess the size was 53 or 54.
Decrepit Member
Beautiful! With the orange frame, white tires, and white cable housing I think you should call it Dreamsicle, or maybe Dreamcycle.
Liked 8 Times
far as I know they only made 2 sizes. Large (23") and small (21") so 53 or 54 like you said would be the small.
I've only seen em in Yellow and Orange. excuse me, International Danger Orange.
I gotta find an appropriate 26.8mm seatpost for this bike. I snagged the one on it from my Centurion.
@scooper - I like it!
I want it to stop raining so i can go ride it more.
--Don't Panic.
--Don't Panic.
Liked 8 Times
if that was my bike in the photo those striped shorts would be on the ground.
--Don't Panic.
--Don't Panic.
