Please Pick A Pedal....for me. :)
Bikes: 1991 Trek 5200
So I am sure you have read my other posts about have I currently have clipless pedals set up on the bike. Well I decided that wearing clipless shoes to school then changing may be over kill so I was considering these as an alternative.
I wear a size 13 shoe,
Will be traveling around 2 miles round trip,
Will stop several times for stop lights throughout the trip
Will be carrying a back pack.
Pros:
Cons:
Which would you buy?
https://www.amazon.com/Avenir-Alloy-P...025423&sr=1-50
https://www.amazon.com/Avenir-Pedals-...025423&sr=1-62
https://www.amazon.com/Avenir-Ultrali...025448&sr=1-75
As always,
Thanks!
Pros:
Cons:
As always,
Thanks!
Bikes: Jim Merz Specialized Allez, 3t bars, ritchey stem, turbo pro tires 130mm rear wheel
my experience has been big feet and toe straps are a bad combo.
https://sandiego.craigslist.org/csd/bik/3498449309.html
speedplays for cheap, I got my time shoes from CL for 50 bucks. So its all good
Thunder Whisperer
Bikes: '06 Kona Smoke
Liked 6 Times
Clipless for a 2 mile trip?? Yah, bro, that is overkill. Get some nice big, grippy BMX platforms.
Edit: These are what my bike came with. I would state the name in the clear, but then it would set the naughty word hounds a howlin' .
Pros:
Cons:
As always,
Thanks!
Pros:
Cons:
As always,
Thanks!
Get MKS Sylvan Tourng pedals;
https://www.amazon.com/MKS-Sylvan-Tou.../dp/B005I6D48G
a quality, durable pedal that has servicable bearings.
also, these are the widest platforms I've been able to find anyplace - an important consideration for big feet
you'll have to get the toe clips separate, probably want MKS clips in xxl size (yes, good toclips come in different sizes)
It will be worth it.
Another vote for the MKS touring. Great pedal that looks good on any bike. Inexpensive too.
You really don't need any type of retention for the riding your describing. If you really think you need some get some power grips.
Bikes: 2007 Schwinn Le Tour
Link: https://www.rivbike.com/product-p/pe2.htm
Bikes: Longbike Slipstream, Bridgestone RB1, Workman trike, Xootr
I've got some dual sided pedals. Good for a short run to the store or in this case a 2 mile trip tp school on the flat side. Still ready for the SPD's and a longer ride.
https://www.amazon.com/Shimano-PD-M32...keywords=pedal
In the right lane
Another MKS model worth considering. It is called MKS RMS Sneaker pedal. It rotates very smoothly and grippy with my Adidas Sambas or even work boots. It's made of aluminum alloy, rotates very smoothly, and said before, serviceable. The best news for me is that the gripping surfaces doesn't have sharp edges so it won't chew up your pants or shins if you accidentally missed or slip off these pedals.
MKS Touring is my favorite, and I used to ride clipless.
MKS also makes Deep Toe Clips for to fit the hight of your shoe. I use the Touring pedals with Deep, Medium Steel toe clips. I love the MKS Touring.
MKS 90 pedal looks wider, I believe if you need a wider pedal. https://www.amazon.com/MKS-Model-Trap.../dp/B007QMVDM4
Watch out for pedal strike though. Test it around corners before going fast just to see what its limits are when you lean the bike.
I haven't had any trouble with the Touring pedal.
Commander, UFO Bike
I'm pretty happy with my dual sided pedals... Please note, I do have to use pedal extenders though (but that is for any pedals I use)
Shimano A530's
PRO
You can service the bearings on this.
CON
Sometimes street shoes can slip off when conditions are bad.
And Shimano, if you're listening... Put some more "bite" into the platform side, and they'd be perfect.
Shimano A530's
PRO
CON
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,047 Times
Pros:
Cons:
As always,
Thanks!
Pros:
Cons:
As always,
Thanks!
Hmmm...seems like the consensus is pretty much the same.
Do you think my Look Carbon Pedals will be worth anything if I try to sell them?
The reason I ask this is because I was considering the dual pedals so I don't have to keep changing them
Pros:
Cons:
As always,
Thanks!
Pros:
Cons:
As always,
Thanks!
J.
Tractorlegs
Bikes: Schwinn Meridian Single-Speed Tricycle
Liked 60 Times
Keep 'em! It really takes little effort to change pedals (unless you're a birdhead like me and forget how they're threaded lol) and after you commute for a while you may want to try a longer distance ride and the clipless will be nice to have
Trikeman
Trikeman
Thunder Whisperer
Liked 6 Times
Put some platforms on your bike, as clipless aren't warranted for such a minimal distance. However, since you already have the clipless pedals, keep them for your next bike, as you'll likely 'outgrow' your current ride in the near future.
I've ridden 30mi. with platform pedals and my pair of good for all occasions Adidas Sambas and kept up reasonably well with my cousin who rides a full carbon bike with clipless. For commuting, platform is the way to go.
"The Veiled Male"
Grip Kings: https://www.rivbike.com/product-p/pe1.htm
Nothing else even comes close.
Same pedal, a couple of bucks cheaper: https://www.amazon.com/MKS-Lambda-Ped...7077685&sr=8-1
What, me worry?
Bikes: Corratec / Jamis
