Show us your Raleigh Super Course!
#2026
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Liked 1,014 Times
Got around to the tires
I took the time to mount the tires and tubes I bought specifically for this build! A recent purchase also came with red used straps that work perfectly with the other red accents. Went for a spin to clear the cobwebs and get the blood flowing, and it is comfy!
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20210512_152612_abaec2aeb540a3b71d676428bc5bb93c16226f3e.jpg)
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20210512_152816_ae29e6ae10ccdc1c889d47774900a5dbb9688631.jpg)
Look at how the handlebar tape glows!
Likes For Unca_Sam:
#2027
Bikes: Raleigh Super Course, Raleigh International, Raleigh Gran Sport
Liked 329 Times
White Fenders
This is not the first time this bike has appeared here but I have had the good fortune to now possess a pair of vintage, white, Bluemels "Lightweight" mudguards. These came with the Raleigh Pro Mk I that some of you are familiar with and since I refurbed that bike to "catalog-page" appearance I didn't fit the fenders to it. Seeing the fenders hanging in the garage and knowing that there is a generous amount of white on the panels of the Super Course Mk II, I thought I would install them there and see how they looked. What does the Super Course fan-world think?
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/white_fenders_90c22a194f7274d34bd8f7da561a0998b9b951bb.jpg)
Likes For daka:
#2028
Liked 2,646 Times
#2029
Eccentric Old Man
Liked 173 Times
Raleigh Super Course, 1973?
Serial # 0021827
This came to me in a collection of things. I ride a 25'' so it's not going to stay. I hope.The only Raleighs I have worked on were Japan made.
Is this a "good Raleigh"? The kind gugie can't say no to?
Thanks
50cm (ctc) seat tube.
53cm (ctc) top tube.
F&R derailleurs have been replaced.
GB stem.
Weinmann brake levers with release, Carlton hoods.
Simplex DT shifters.
Weinmann 610 front, 750 rear centerpull brakes.
Weinmann Aluminium 36h rims, 27x1/14 , knurled brake track.
Normandy hubs, M. M. Atom skewers. Huret spoke protector.
TDC freewheel. 14-17-20-24-28.
Seat pin measures 26.2.
Stronglight crank, 52-42. 6 stamped on backside of arms.
Raleigh 501 pedals, Christophe D cages marked AFA Brevets the bottom. Lapize straps.
Chain checks as new.
Bar tape & plugs look original.
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1000x750/img_2140_64080c210cae2f40b13323d13a96b0584433e100.jpeg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/650x1301/img_2141_091069e63a4d70e7105cff6896962c0ed4d66b89.jpeg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/700x494/img_2154_6cf32a49f3b87b73908db92e4bfde7c9243824ef.jpeg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/1000x750/img_2155_a5ef23b3f824e26f1f05e07c0d72cdc1c6b591d5.jpeg)
#2030
Liked 329 Times
Looks like a '73 to me too. It doesn't have the Capella lugs that are often seen in 1973 but that may have been dictated by the small frame size. The separation between the seat lug and tube does, however, scream 1973 right out loud. The finish looks great for a 48 year old bike.
#2031
I agree. Only year they made a SC frame this small, and yes it needed Bocama lugs to fit the head tube (I have one in the shop).
#2033
Not lost wanderer.
Double dingle speed Raleigh SuperCourse
Finally got my wheels built, some Suntour sprint hubs, SS spokes, Alex rims with panaracer tour tires. A pair of bastard brake calipers, Dia-comp bodies, springs and pivots with Weinmann long reach arms. Raleigh crankarms, Lyotard pedals, some black 45t chainring with some 42t silver ring. A black Pletsher rack, Brooks C19 Cambium saddle, SR seat post, Nitto Technomic II stem, ??? Bars, ??? brake levers. Surly 17-21 dingle cog and Mabda ind. Dingle freewheel.
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/img_20210623_145838882_cc888bcf620e9e190f4c7dbf55bb7bae64718ce1.jpg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/img_20210623_145829535_c1393ca8797c7f670dc6536c544c18dcf8c125fe.jpg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/img_20210623_145826143_f71ec82c7b5cf60e193434daa7656c13608905d3.jpg)
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/img_20210623_145804932_d436be304d975b0cdd34fc71e646a65ba3752f02.jpg)
#2034
Liked 2,646 Times
@eom if it doesn't have the Capella lugs, it could be a 1974, and yes, it's a good one, especially now that the derailleurs are upgraded.
#2036
Plus a cottered crank, if original, is definitely earlier than ‘74.
#2037
Eccentric Old Man
Liked 173 Times
So a follow up question. Is this seat post workmanship a problem for whoever winds up with this bike?
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/700x494/img_2154_c71bf6b962cd51c4fbc98c3ddf2d79e4260a0ff7.jpeg)
#2041
Liked 329 Times
I would also see if I could find the washer that belongs under the nut on the seat post clamp so that the nut doesn't continue to grind up the lug.
#2042
One of the framebuilders who post here will be able to give you a better answer, but if it were my bike I would drip a little epoxy in that gap to help prevent water from getting in there and causing corrosion. I suspect that there is enough area brazed together to ensure that the seat lug doesn't detach from the tube.
And it's not likely a structural issue - not with the reinforcement of the seatpost, and besides, there's a bloddy great slot through the whole lug right next to it.
Likes For oneclick:
#2043
Liked 329 Times
Well, maybe epoxy isn't the best idea but I would still put something (oil, Boeshield, Framesaver, etc) in that gap to prevent corrosion. Rust has a greater volume than the metal that made it and will swell that gap making it difficult or impossible to remove the seat post in the future.
#2044
Went Campagnolo on my '73. Also hit the aluminum bits with some Mothers Mag & Alu. Polish. NOS Regina chain. Atom 14-24 5-speed freewheel.
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/1960x1069/sc_ngs_1_8a32c5700f3705283ef690beb6afd9a32f7b4858.jpg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1509x1389/sc_ngs_3_a9f2d216208f4575c8d6030c1cb7813806ecc146.jpg)
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/1672x1254/sc_ngs_4_fca20996e17405a0711f086574029060ac7d8c17.jpg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1672x1254/sc_ngs_6_4a6c98dc2a87ac6c7e001e786d6a51175cb5d0db.jpg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/1666x1258/sc_ngs_2_f630d00c988efefeebcdfa04d7dfa2e6289fdd61.jpg)
Likes For BFisher:
#2045
ambulatory senior
Liked 3,681 Times
Just picked it up today!
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20210909_115713_b4166bdfe4cd6e381d5ff122c8cfc8dfa8b7d0ba.jpg)
As bought. I rode it a couple of miles and was pretty impressed even with using the lousy shifters. Brake levers are in the wrong place too and I really should get the hoods to someone who loves that sort of thing as I will be doing an upright 3 speed 700c conversion. I'm quite excited!
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20210909_120724_1d356e4e93820743198b6a091e261c47840031e9.jpg)
Brake bridge clearance with 700cx35
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20210909_120742_25be81bc283fb47a7b51f982400e69d0bcaa2022.jpg)
Chainstay clearance.
Likes For 52telecaster:
#2046
ambulatory senior
Liked 3,681 Times
Trying a bar swap with weinmann north road style levers. Right now the back wheel is 700c and the front is 27 but I will build a dynamo 700c for it eventually. I also will probably replace the crank with a square taper just to have some chainring choices. The stronglight does feel good though. All my stuff is scavenged from other bikes as you can see by the shifter. From a sears Austrian three speed.
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20210909_141706_8efcfdbd8a6d27eb739b186b67187a6932f2784b.jpg)
Sears to the rescue. I bought a basket case for 12$ and got this switch and the cable, pulley and cable stop plus a working Austrian aw 3 speed hub. The frame was even salvageable.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20210909_141651_bdd7c737c424d85913da06a1460baf8849e20d04.jpg)
Fits me real well like this.
#2047
The dropped
Liked 1,014 Times
Likes For Unca_Sam:
#2048
ambulatory senior
Liked 3,681 Times
there are many 36 hole aw hubs out there. Check coops.
Likes For USAZorro:
#2050
ambulatory senior
Liked 3,681 Times
