DIY bag making
#176
Liked 1,110 Times
This is a slight diversion, more like DIY bag customization. I like to have a small bag for packing extra layers into or for carrying my picnic lunch on charming days. I also keep finding "handlebar bags" that seem the right size but I don't like the dangling design with two straps around the handle bar, next to the stem, that leave the bag hanging and bouncing against the control cables. I've had some success with taking that basic bag and changing the attachment methods to suit my purposes. I'll move straps, lengthen straps, change ladder lock straps to hook and loop, fabricate stiffeners, add tie downs, etc,,,,, as needed. Works for me.
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1440x1920/img_1073_086cdeac5d72cf9e2201d83d54db1a85726aab1e.jpeg)
^^^ is a Canondale bag with a nice size and shape. I fabricated a simple "rack from electric fence wire and a bit of cherry hardwood. I then made a wooden stiffener for the back of the bag, replaced the original straps and attached them wider to clear the center of the handlebar and added a tie down to wrap around the HT, stabilizing the bag under load. Good enough for a sandwich, carrots and some chips.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/1656x1703/img_1074_56c1b6a7a1ebb15bbf174a7469afc29781dc9b05.jpeg)
^^^^ Sunlite barrel bag that, again, was a useful day trip size but would not play well with the cables on the front of my Y2K Cannondale. I'd made the wooden package rack years ago and found that, by removing the original straps, making and then turning a new one and adding a bit of hook n loop to the bottom it mounts on that rack well and is stable. Room for a tool roll and picnic lunch.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/1440x1255/img_1075_465f2e72943b3d88049e4af393aee5cfd18c3a60.jpeg)
^^^ another simple barrel bag what would never suit me lashed to a handlebar. This one needed an internal stiffener which I made out an empty (and washed) kitty litter jug. I then removed the original straps and fabricated quite long hook n loop straps that are fastened on one side and long enough to wrap around the bottom (and the luggage rack its sitting on) and up the other side to close across the top. This one sits along the rack like a trunk bag, either on the rear of one bike or the front rack of another. Good for a day trip or even as a bit-o-extra when I have the panniers on the front rack. Suitable for purpose
Likes For Prowler:
#177
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/0962a979_5149_48b3_937b_24c65faf4708_04949bde286f94d4bd16ebc76147215ddf6da04f.jpeg)
When you see the Southern Cross for the first time you understand now why you came this way
Likes For seagrade:
#178
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1978 Richard Sachs, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial, 1971 Fuji Finest
Liked 655 Times
Hand sewed tool bag
Made this tool roll to take advantage of the loops on the saddle. Hand sewed with a leatherworking needle and then used pop rivets for the snaps.
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/1440x1800/1f8279e2_01b3_43bd_bd4b_58003d5fbc15_f16be09d1f3666ff90b8cb9a0fb0d0293516c67b.jpeg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/3d5d8ef8_9754_45c8_8863_a878a13b0fa6_d7747b8256cf7f82f2b1c4424367f916d157d442.jpeg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/a3e51bf0_e471_403a_9dd6_0e6dcebceeb5_66244fe2b4aaab92c2236dc0a2937f7201c7de26.jpeg)
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/b01ee49f_6e57_4db8_818c_fa8b6f0c3c2f_3035a86f714cbb1d5c498815c6bf6f7281aad8f0.jpeg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/e15db63d_5719_4c88_811e_4d91cee95783_4074f37b1bf20c85772ba037eb321a550572e3e0.jpeg)
Likes For Sactown_Albert:
#179
#180
All that said I did enough research to decide upon a Stronglight roller bearing headset, and with that and weight more over the bars than perhaps anticipated by the designer, it rides perfectly well as is. In fact, the Tange Prestige frame/Infinity fork seems to suit me at c. 180lbs when I sporadically muster what little power remains.
All that said I'd probably trade it towards a 650b Jeff Lyon/L'avecaise were one to surface in anything near my size...
Likes For seagrade:
#181
So Sactown Albert, where did you find the wrenches in the tool roll? Been looking for some like that but have hesitated to buy on line as I doubt I will find something as solid as what came with the 3 spd I had as a kid. Thanks!
#182
Happy banana slug
Liked 1,597 Times
#183
Liked 655 Times
Found them on Etsy
I put in a search for “bike tools” on Etsy and these came up used. I did a search today and I saw a number of similar tools.
#184
Liked 655 Times
#185
#186
Cheers thanks, I do, although you'd hardly know it looking at the setup - a randonneur masquerading as a race bicycle with its near-14cm stem and seat to handlebar drop. I bought it a few years ago in a Soma factory clearance, knowing virtually nothing about such machines. I intended for it to be an overnight tourer with a handlebar bag, but such escapades have yet to materialise.
I have bent a couple of aluminium Stronglight crown races before (too much play/float? too much weight on the front? not sure) and now run a 1" ITM Sterzo bottom half with a beefy steel crown race.
Likes For Schlafen:
#187
Freewheel Medic
Liked 2,267 Times
My latest saddle bag design. This one is slightly smaller than my last bag and has a single arched zipper for the closure. This presents an interesting challenge in that each side of the arch presents a different circumference. Since it is just two pieces (not counting the straps), I had to fudge a little when I stitched them together. Look at the center bottom of the closure, the pucker is where I had to make up the difference. I'll make adjustments for my next one.
The use of the alligator pattern leather was inspired by this thread from last week. "Cool and Interesting Bar Tape."
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/1319x1226/gator_bag_rear_ac79172637d1858613d468397d1324349c087b71.jpg)
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/1599x1226/gator_bag_r_side_8dc7ed722275691bf251cb6f058a7b579b850d65.jpg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/1265x1225/gator_bag_r_diag_8f5df38b7482bf20ae519b347572eb171d4784b6.jpg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/1684x1226/gator_bag_left_f865c3a42cfd377a5b41b8109b4a2b9f428c75b5.jpg)
Bob
Bob
#188
Freewheel Medic
Liked 2,267 Times
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/944x1225/voygeur_gator_bag_1_202ac6612c88b6a01ed9a1729d32cf6b9ba17331.jpg)
Mounted on the bike.
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/1012x1226/voygeur_gator_bars_7f5eaf705152f7f5e05af7e2a59c70901cfb13f1.jpg)
While I was making the bag, I also made matching bar covers and hoods.
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/1600x1225/voygeur_gator_bike_82a24b8fe5679b546ca672f4ac4537625c85297b.jpg)
Bob
Bob
Likes For pastorbobnlnh:
#189
Freewheel Medic
Liked 2,267 Times
It is hard to imagine that over a year has passed since there was a new post to this great thread. I'm a little embarrassed to be the one to refresh it--- since I was the last member to add pictures.
For the past month I've worked on a leather handlebar bag. I utilized a steel cradle which came with many vintage Cannondale and other bags as my support. I designed it around a rechargeable battery with a built-in solar panel to ride in the top pocket (which incorporates a window for the panel).
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/1656x1218/full_paramount_6b79dbd54df9d93e88cf5046b25697637e8af6eb.jpg)
As mounted on my '71 P13 Paramount with other leather projects.
Originally, I planned for it to be made from all red leather, but I miss-measured the top piece with the window for the solar panel. I had used all the red (and my supplier no longer had this hide), so I resorted to the black which I had on hand and used the contrasting red stitching.
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/1014x1218/front_of_full_bag_bd36cf4514259855c711989f219e466a9d490222.jpg)
Front pocket with magnetic closure.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/1406x1218/bike_side_back_eb3a57f064bfba37e50fae600048d39bb24e69a0.jpg)
Cockpit side. Double zipper for main compartment. Single zipper for top battery compartment. The zippers were repurposed from an old backpack.
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/1140x1218/side_of_bag_bfaa1623a87882fc0fc968b73d87ed79f6978ef7.jpg)
Side view with rings (behind brake lever) for a shoulder strap.
If you look closely, I added two wide elastic straps to the bottom panel to carry a spare tubular tire, which sits between the tie-down tabs. I also made a leather sleeve to help secure the tire. Finally, I made a tool-pouch to fit in the front pocket.
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1737x1218/tubular_tire_holder_65c2328feaf342b4319700f8fca7c3455afa32bf.jpg)
Tubular tire holder and sleeve.
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/963x1218/tool_roll_in_front_pocket_c900f26e0ef14ec29c173416ecc7b8a03efae6a7.jpg)
Tool-pouch in front pocket.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/1052x1218/open_tool_roll_d7d21d7a31a91a708c700a60f2a4b4d9adc965ee.jpg)
Open tool-pouch.
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/1167x1218/open_main_compartment_b64a8e0885a77707daeab9feb84863c645c62547.jpg)
I lined the interior with white leather.
Thanks for letting me share my latest leather bag project. I'm glad to answer any questions. I also took additional pictures as I made the various pieces prior to assembly (including my mistake).
Open tool-pouch.
Bob
Bob
#190
pastorbobnlnh not sure if you mentioned it before but, which sewing machine are you using?
Been thinking of giving it a go myself as I can never find the bags that I want and xpack is relatively inexpensive to play around with.
#191
Freewheel Medic
Liked 2,267 Times
People ask all the time (especially about the purses I make for my wife, daughter, and MIL), "Why don't you use a sewing machine?" My answer is simple: I like the contemplative action of hand stitching.
I realize I could speed-up the time it takes to make a bag, but I'm in no hurry, and I'm not trying to earn a living with my leather crafts. They are just a fun way to spend time and make functional pieces which I and others enjoy.
Bob
Bob
#192
Liked 1,110 Times
I do all my stitching by hand with Speedy Stitcher Sewing Awl. I've never used a sewing machine.
Likes For Prowler:
#193
Freewheel Medic
Liked 2,267 Times
Well done, Bob. I’ve resorted to a speedy stitcher a couple of time but Ima no good at it. Back in December I finally took a good look at an “old” sewing machine my wife bought a couple of years ago for repairing horse blankets. Old? Turns out it’s a 1920 Singer 96-10 industrial machine driven by a more recent clutch motor drive. That should be interesting for a DIY project. It looks like it could sew aluminum sheet, let alone leather strapping. Cool. DIY is not dead.
- I use .030" twisted waxed cord from Maine Thread, from up in top506 and 1989Pre neck of the woods.
- I don't bother to wind the cord on to the Speedy Stitcher bobbin. I just use the cord as it spools off the original cardboard tube.
- Using a leather pricking/punch iron/tool is essential! I have an inexpensive set I bought on Amazon. I use 6mm spacing on most of my leather projects.
- When stitching, do your best to keep the needle in the same orientation as you stitch from hole to hole. As you pull the stitch tight, try to be consistent with the tautness from stitch to stitch.
- Like anything, the more you do the better your craft.
![Stick Out Tongue](https://www.bikeforums.net/images/smilies/tongue.gif)
Below is a good example of how my stitching technique has improved. I completed the red purse for Christmas 2022. The turquoise one was made for Christmas 2023.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1036/turquoise_and_red_purses_3d7b4d97148480aac067fdba5c6b9ce519becfed.jpg)
Bob
Bob
#194
Pedal to the medal
Thanks for these tips, pastorbobnlnh ! I've yet to try my hand at bag making and I'll certainly be referencing your post when I do!
Likes For romperrr:
#195
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Liked 370 Times
Not a great pic of a large seat bag I made out of an old Boy Scout Yucca pack years ago.
![](https://i.imgur.com/t8qVJbMl.jpg)
Likes For bikamper:
#196
I've modified a cooler into a front bag and it was an unpleasant hand stitching experience. The material may have been the cause actually, it did put me off trying again. The bag turned out ok and usable but not what I envisioned before embarking on my first ever hand stitching adventure.
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20240308_224432_83467d5e773bf503445a03ee62077607842a34ad.jpg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20240308_224222_2455f089c228140873781c5209249ade8c116d12.jpg)
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20240308_224230_4b243989080cb93beb37e0fb43233707760a148d.jpg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20240308_224250_42f3d6bddfc25ac082460f2a17526e4c72be0b49.jpg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20240308_224304_180946b1244d1255f24249390cc51cd33294c126.jpg)
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20240308_224344_b7484105026dc507d57a318bb7c73ccec540bfca.jpg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20230625_110345_bade7f38f2931320101552680ef5e451b8bc4b3a.jpg)
However, I have just bought a cheapo Singer sewing machine off eBay and some xpack fabric.
Looking forward to delivery now, hehe.
Likes For Schlafen:
#197
Freewheel Medic
Liked 2,267 Times
Schlafen great job on your first adventure in DIY Bag making! Well done!
Just look back through this thread and you can see how some of my earliest attempts were real disasters. When I first started I had the not so brilliant idea of repurposing old tubular tires into bike bags. I created some real turds!
I then attempted to convert purses and women's bags into bike bags. One turned out okay while the others were real hack-jobs. However, through all the failures I learned more and more.
Even this morning I happened upon a YouTube video which taught me a new technique for enhancing the edges. I hope to incorporate into the next purse I make. Mrs. PB has an order in for a black version of the bag I pictured above. Hopefully she will let me give it a try.
Bob
Bob
#198
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/800x473/pxl_20240310_173949966_20b1b4729aea9122b5389a735bb10366408fd7df.jpg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/800x703/pxl_20240310_174202079_512bcc018016f12d0e221dde48d31f2cf7983e3d.jpg)
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/767x1200/speedystitcher_dir001_001_9b8aab80781b811b07083c4e8bf9e02fa7425ebc.jpg)
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
Likes For Schreck83:
#199
My issue was that I've been struggling to find decent bags, for which I don't have to sell a bicycle in order to afford it and which fit my bike/handlebar constraints. For whatever reason (I'm assuming for a lack of front rack) all modern bags seem to open away from the rider, which is silly really.
Messing around withe the bag pictured above made me realize there's not much to their construction and I can probably make a better one to suit me.
Likes For Schlafen:
#200
I don't know.
Liked 926 Times
I bought a Speedy Stitcher decades ago for backpack repairs, and never used it. If anyone here wants it, I'd be glad to mail it to them for the cost of shipping in a padded USPS Flat Rate envelope, which is $10.70 right now I think. IM me.
Likes For RB1-luvr:
