Birdy thread
#151
I felt very similar the 2 days, and the weather was very similar as well. I only clock time in to work, then the wind is very low.
I also pumped both the Swift and the Birdy to 100psi. The Swift has a Conti GP at the front, and a Primo Comet Kevlar with a Slime liner on the back.
The Birdy, weighed this morning sans luggage, is 12.6kg. I must guess the Swift at 9.5kg sans luggage (both cases luggage is a backpack).
So, the times were 56min for the Swift, 57min for the Birdy. Both cases the HRav was 129bpm. In the Birdy run, the HRmax was 213 so it picked up some interference somewhere, which might alter the average a bit, if anything it might then be lower without the interference. the Swift max was 167bpm, that is probably real.
I think the 1 minute difference can easily be explained by the extra mass for the Birdy, since there is a not insignificant amount of uphill. There was also 1kg extra luggage on the Birdy in the backpack. Plus the Swift gearing is more suitable, and the derailer runs slightly more efficiently. Plus on the Swift run, there was another roadie cyclist in front of me for a few minutes which often has the effect of putting in more effort, although I tried not to. That may have made a few seconds difference.
The Birdy sure is a whole lot more comfortable. The Swift sure feels a whole lot faster.
Seems to me that tiny difference in speed (less than 2%!) is not worth it on the Swift.
![Frown](https://www.bikeforums.net/images/smilies/frown.gif)
On the plus side, the Birdy is a whole lot faster now that I have the tires sorted. I doubt that the Marathon Racer will have a significant impact over the Plus.
#152
I'm wondering about getting a rear rack too. I already have the front lowrider which covers my everyday needs. I would only need the rear rack for occasional short tours - hence I'm wondering if the $140 is really worth it, since I won't use it that frequently. ThorUSA has a Pletcher seatpost mounted rack for $45-ish (that he tells me can easily be adapted to the Birdy's 35 mm seatpost), and it's rated for 18 lbs which should be enough for my tent, sleeping bag and sleeping mat (stove and other stuff in front panniers). Ok, it won't fold with the bike, but on the other hand since I won't use it that often it'll be easier to take on and off than the Birdy rear rack.
Any ideas on pros and cons of either approach?
It may be possible to attach the stays for the Pletscher rack to to same point as where the Birdy stays go, and so minimise unsprung weight. I'd say the luggage capacity would go down a bit but not by much. You'll need to see how much pulling back the top swiveling attachment point can handle.
#153
Bikes: Brompton H6, Schwinn Mirada, Cruzbike Sofrider. Used to own: ICE B1, 2 F-frame Moultons, Koga Myata Elevation 5000 mtb, Challenge Hurricane, Riese & Mueller Birdy Silver, Actionbent Tidalwave 3
![Wink](https://www.bikeforums.net/images/smilies/wink.gif)
I hadn't actually considered mounting the Pletscher suspension rack to the Birdy mounting point... hmm, that's an interesting idea. I'd have to say I think the suspension rack looks a bit.. <cough> dorky.. but maybe the ability to fit panniers, should I have to, is worth it?
#154
The Pletscher Quickrack Suspension might actually allow you to fold if mounted on the Birdy points. I'm just not too sure about the pannier hanging ability, but it looks a whole lot better than the Orion to me. If you did hang a pannier, you always have the option to take the stays down to the axle points, or you would need the rear mudguard stays for the pannier support.
#155
Bikes: Birdy Red 8 speed, Birdy Blue 21 Speed, Birdy Monocoque 24 Speed, 2002 Devinci Desperado, 1996 Rocky Mountain Hammer Race
The Marathon Racer and the Kojak are each rated at 6 bars for speed whereas the Marathon Plus is rated at 3. (The rating system is: 6 is outstanding for class and 3 is average. I'm not sure what that translates to in rolling resistance)
If you open "Comments" on the Marathon Racer, The most recent comment is from someone who reports noticing a big difference when they changed from Plus to Racer on their recumbent.
The weights are:
Marathon Plus 510gm
Marathon Racer 260gm (250gm less)
Kojak 185gm (325gm less)
David
#156
Yes, I have read those; I suppose what I mean is, that "other factors" are beginning to dominate the commuting time, in this case, weight, wind resistance and such-like.
I am thinking along the lines that while the racer will be faster than the Plus, I suspect the difference is now likely obscured by those "other factors."
For one thing, I will need to be more accurate with the time keeping - I have been rounding to the nearest minute since stopping for lights slows me down a bit and that is unpredictable. So the commute won't cut it for accuracy.
![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
#157
Of course I got a puncture on the way home in the "puncture-proof" Marathon Plus.
Ordinary small piece of glass. I was completely unsuccessful in finding the puncture, so gave up in the end and walked to the train station and caught a train home.
![Mad](https://www.bikeforums.net/images/smilies/mad.gif)
#158
I fitted Stelvios last night, can't wait to go for a ride! I would have taken the Birdy to work today, but the forecast was for rain. They were quite challenging to fit, very tight on the rim - and I really shouldn't have been a cheapskate and reused my original 18x1.5 tubes, they're bigger than the tires! My only concern with the Stelvios is that they'll lower the already low top gear still further... I haven't measured, but they're visibly much smaller than the Maxxis.
On an unrelated note: my chain keeps falling off at the rear when I fold. That happened every time at first, but then I seemed to solve it by folding fast. I don't think I'm doing anything different now, but the last few times the chain has come off every single time. Could the chain be too long? This may well be my lack of practice, rather than a technical problem, but any advice much appreciated.
#159
I wouldn't have thought falling off at the rear was possible... is it falling off the smallest cog to between the cog and frame?
Is the derailer pulling properly to the back?
Looking at chain length is not a bad idea. Put it on the biggest sprocket and make the chain as short as possible.
#160
Bikes: 2X dualdrive Mezzo folder,plus others
"I fitted Stelvios last night, can't wait to go for a ride! I would have taken the Birdy to work today, but the forecast was for rain. They were quite challenging to fit, very tight on the rim - and I really shouldn't have been a cheapskate and reused "my original 18x1.5 tubes"
I doubt that will work, not recomended from my experience as the tyres get pulled of the rim with oversized tubes.but is you got them to work OK with 1.5 , then fine.
#161
It is apparently possible, sadly...
No, it falls off the derailleur jocket wheel/chain retainer. I couldn't find any clear pictures of the folded bike, so have used a non-folded pic from Flickr. Don't know if it makes sense?
Not quite sure what you mean, but it seems to shift normally.
#162
Car free since 1995
Bikes: M5 Carbon High Racer, Trek Emonda SL6
Liked 10 Times
Now, when you fold, it should catch the chain and keep it on the bike. You have front chainguards, right?
#163
Car free since 1995
Liked 10 Times
I have done 2 commutes with the HRM... not enough to get some averages, but enough to get an idea.
Seems to me that tiny difference in speed (less than 2%!) is not worth it on the Swift.![Frown](https://www.bikeforums.net/images/smilies/frown.gif)
(Also, without a power meter, the error is much greater than the point estimate.)
#164
Actually, the chain catcher will only work when it is in the highest gear. This is what I would do: 1) shift it to the highest (hardest to pedal) gear; 2) adjust the chain catcher so that it is riding about 1mm above the chain.
I do have front chain guards, yes.
#165
Car free since 1995
Liked 10 Times
Yangmusa, yes, try adjusting it. Jur's excellent advice about the chain is good, perhaps taking a link off will help. The only other advice I have is to be Zen and quick when folding it.
#166
![Stick Out Tongue](https://www.bikeforums.net/images/smilies/tongue.gif)
Now that I know where the chain is falling off, well I have the same. In my case it is caused by me replacing the long cage derailer (Alivio) with a medium cage one (XT), which doesn't gather the same amount of chain, so the chain becomes slack and if I'm not careful about making sure it stays hanging on the catcher, it will fall off.
I'm putting a long cage RD (LX) back on this weekend; I need the medium cage XT for another project.
![Innocent](https://www.bikeforums.net/images/smilies/innocent.gif)
#167
I also cured a very persistent click on my Birdy... it would go click at the front wheel with every wheel revolution. I looked at the bearings, the speedo magnet, little rubber bits sticking up off the tyre, the magnet again, felt all spokes for a broken one, the valve locknut... nothing.
Then I noticed it gives 2 clicks every revolution, plus it gets worse if I tilt the bike over... OK that's spokes! So I plucked all the spokes and there was one that's lost tension. Comparing mine with my workmate's his spokes are a lot tighter. There is no threadlocker on the nipples; I will have to do the entire wheel to make sure it doesn't happen again. I am speculating it happened during the rough touring, or my wheels are simply more used than his.
#168
Sizing help please... Interested in a birdy, but cannot get sizing info. Searched and found that effective top tube was 58cm but position of bottom bracket made the bike a "medium" size.
On road bikes, I ride 58cm (C-C) seat tube; 57.5 cm top tube, and 110cm or 120 cm stem. I'm 6 ft. Would I be cramped on a Birdy (sit too upright)? Are their options on stem/handbar to stretch out a bit?
Many thanks in advance.
#170
Bikes: HP Grasshopper, Brompton, Claud Butler Tourer
I am the same height as you and have recently purchased a birdy with a comfort stem, just couldn't get it set up right, felt too cramped and too upright. AVC in Bath swapped the stem for the standard stem and its a different bike, feels very similar to my touring bike now
Hope this helps
Hope this helps
#171
#173
Jur,
I was looking at some of your pictures.
https://members.iinet.net.au/~jdekter...sentr2008.html
You are going over some rough surfaces. What kind of tires are you using?
I am avoiding going over surfaces better than that but maybe my Marathons can handle more than I expect.
Kam
Kam
#174
These were the cheap original tyres on the Mini.
I think tyres can handle anything that won't actually cut into the tread surface. The question is more one of grip on said surface. Last weekend I took my Moulton out for a bush bash MTB ride over some pretty stony stuff, and I was running high pressure Continental road tyres! They handled it surprisingly well.
In the early years of the Tour de France, much of the race was on badly-surfaced dirt roads, but those chaps raced with their skinny tyres on it.
So you could ride over almost any surface with the Marathon Racers as long as you can maintain balance and the tyres won't get cut. That's really all what tyre tread is for - getting a grip on the surface.
#175
I think Jur is right - the main problem might be grip. We were both fine going up. My fatter Maxxis tires were more confidence inspiring on the way down - but we were both a lot slower than the MTB folks who were bombing down the path!
If you do lots of offroading, it might be worth getting knobbly tires. But for the occasional jaunt offroad your Marathons will be fine, just take care on any loose surfaces.
