For the love of English 3 speeds...
Bikes: Raleigh Sports
That Eaton Commander is desireable. Many Raleigh like attributes. Unusal lugs, real nice pin stripping, outstanding condition I wish I could reach Toronto shipping costs, too few nickels in my budget. I do need to break out of the 60's and find 50's machines.
Liked 337 Times
Marfield brand? This one looks like a very clean mid to late 60's Raleigh product in Chicago area.
https://offerup.com/item/detail/362438262/?ref=Search
Attachment 584981
Attachment 584981
Picked up this morning. $25 1970 sports very clean
^ That's a very good deal!
Here's a $40 men's 23" coffee brown Sports in the Boston area:
https://boston.craigslist.org/sob/bo...323706834.html
I could use a little help again. So, I've taken the hub apart and laid it out before me. I think I'm missing a couple pieces. As I look at the exploded view and my layout I am missing 2 part # K521 axle washers which are squared in the center and tabed but I do have 2 locking washers that have round centers. I have an extra 1/8 thick washer. Part "X49-2 fitted" sprocket spacing washer 1/16 thick, I have not separated the sprocket dust cap from the sprocket is that where the spacing washers are? and finally part K463 Circlip I don't have one?
This exploded view is of the later splined driver type hub. Wish I knew more about your old style threaded driver hub, but for sure, yours doesn't have the circlip. That holds the cog on a splined driver. Don't know about the spacers. Here's some anti rotation washers (k521). You will need those.
https://www.ebay.com/itm/STURMEY-ARC...U8Z6vameP7Bd2g
Old fart
Liked 3,692 Times
I don't see the anti-rotation washers among your parts:
You do need these. If you're planning on using the hub with vertical dropouts, you'll need the modern version with only one tab:
And yes, the spacers and circlip mount on the driver to hold the cog in place. Pop the circlip off with a screwdriver, and the cog and spacers will just slide off the driver. Unless you have one of the pre-1952 AW hubs with the threaded driver, in which case you need to secure the driver in a vise and use a chain whip to get the cog off the driver.
Attachment 585081
Attachment 585081
I did it again. At least it was cheap, but the last thing I needed was another shifter. This one was a wreck. Bent case, missing it's bolt, clogged up with dirt and dried up grease. Only light rust though. I seem to have a problem passing up basket cases. I soaked the parts overnight in Evapo-Rust, squared up the case, patched up the case finish with Brownell's Action Magic. BTW, this stuff works great for replacing that dull gray finish Sturmey Archer used on some parts like shifter cases and guide wheels. It's a dry lube that burnishes into the steel. I ironed out the faceplate as best as I could. There wasn't much left of the black in the embossed areas of the face plate so I replaced it and gave it a new spring. So it was junk and now it's a bit dinged up but respectable and works great. I hope it finds it's way to an old bike someday.
^ Nicely done!
BigChief thanks for the link and the info and the images of the deluxe. $25 I couldn't believe it. I'm not a bike guy but viewing all the images posted here, I just got caught up in it. It will become my Maine bike.
JohnD. yes it is pre 52, It's off a 49 and has no date on the hub. I emailed a guy in England (forget the name right now) but he's an expert on hubs and couldn't explain this anomaly. It's old. Also the serial number on my "52" is another anomaly #69722 so go figure. Hopefully I'll find those anti-rotation washer on my other hub axle or buy them.
also, I really like the Sprite tires with the two pinstripe whitewalls but I can't find them on line.
[QUOTE=BigChief;19940483]I did it again. At least it was cheap, but the last thing I needed was another shifter.
I would like to take my 49 shifter aparts but what would I do to replace the bolts [rivets]?
Señor Member
Liked 1,195 Times
That's a very excellent example of a cherished 1960's rider. I definitely feel the attraction of earlier times also, but don't feel like yours is somehow lacking.
Señor Member
Liked 1,195 Times
I should note that there was not a single Raleigh engineer who contemplated balmy breezes during winter months, so by rights, you should consider surrendering this steed to someone in the intended geography.
[QUOTE=plympton;19940570]
They are only shouldered pins that are press fit into the back side of the case. You can drift them out with a 1/16" punch. They are tricky to get back together again. I wouldn't take one apart unless it needed major surgery. The picture is fuzzy, but yours looks to be in good condition. You might be able to brighten it up with a de-rust bath.
OA is too strong for these though. Something more mild like vinegar is safer. I like Evapo-Rust. But if you do need to take it apart, I have a few tricks that could save you some trouble. I've restored a bunch of these
Attachment 585081
Attachment 585081
I'm going to hell for sure now for posting this link. I had to look it over a bit. What am I seeing?
RPM - Rimpex Rubber - Bicycle Parts
[QUOTE=johnnyspaghetti;19940912]I'm going to hell for sure now for posting this link. I had to look it over a bit. What am I seeing?
Just so your not delayed on the road to hell buy a few things from them. lets us know the quality.
[QUOTE=plympton;19941011]
I was having difficulties navigating no pricing to be found easily and It looks looks as though parts are bought in bulk. rims sa knockoff.jpg
Attachment 585154
Attachment 585154
Attachment 585154
Attachment 585154
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Liked 445 Times
Phyllo-buster
Liked 2,091 Times
[MENTION=466652]johnnyspaghetti[/MENTION], The Eaton's Company (and Simpsons, Sears etc) sourced bikes from many manufacturers, including Hercules and Raleigh. The Commander has proved to be a Herc model. Canada had more intimate relationships with British bike makers which provided a lot of variety of nice Brit bikes in the market place.
