Totally Tubular
#101
juneeaa memba!
Bikes: Crap. The box is not big enough...
A trick - when you get to that last fifteen inches, fasten one side to the wheel with an old toestrap. Pull it up tight...like having three hands! Now you can stretch, curse, sweat and struggle with both hands, instead of one only.
#102
Bikes: All 70s and 80s, only steel.
Originally Posted by Everest
Are there any detailed directions for this patching process anywhere online? The Wolber just didnt want to go on te rim no matter how much I tried about 15 inches didnt want to stay on.
here: https://www.sheldonbrown.com/brandt/tubular-repair.html
#103
Bikes: Lemond Alpe d'Huez, 03 Gary Fisher Tassjara, Quattro Assi Scandium
Well I got the wolber on using your trick Luker except with tightly wraped ellectrical tape instead of a strap, I'm hoping it holds air. As for the other tire with the leak it is a Vittoria Competition Nuovo Pro does anyone no what kind of tube this has according to the above link there are two kinds latex and butyl. If it is latex does anyone have an old latex tube they could cut a few patches from for me? Also will a regular sewing needle be allright or do I absolutely need the rare triangular needle suggested in the article? If the old thread is unusable what kind would reccomend resewing the tire with? Anyone have any tips for finding leaks? With clincher tube I submerge them in water and look for bubbles will this work with a tubular? Should I scrape the old dried glue off the rim or leave it? When I deflate and pull up on the front tire the glue begins to sepereate should I reglue this tire? When I glue the tires do I apply glue to the entire surface of the base tape and rim or just the edges? Any other tips of the trade you can offer a total novice would be greatly appreciated thanks.
Road: Quattro Assi Scandium w/ SRAM Rival and Rolf Echelon's
Mountain: 2005 Specialized Enduro Comp
2003 Gary Fisher Tassajara
#104
Elite Fred
Submersion to find the leak will normally get you to the vicinity of the leak.
Get the old glue off the rim. "Goof Off" works well for me.
Reglue that tire! If you can pull it off that way you will roll it off when cornering.
Glue the entire surface.
#105
Thanks for the dental floss tip. I still have some needles that I picked-up back in the 70's that came with a sew-up repair kit. Over the years I have added and used relitively light weight "sail repair" needles and thread to the kit & tool box. Bob
#106
Thanks for all the help now if I can just find some latex patches, can anyone cut me some from a dead tubular or know where to find some? Also is Vittoria good glue to use?
#107
juneeaa memba!
vittoria tubasti is what you use to join tire to rim. As I recall, that glue is red, and that's my only complaint. Wolber and Panasonic (and some others) make a tire glue that is clear, and that is my personal preference, because I always seem to get a little on things that really don't need any glue.
Use tire patch glue to put patch to tube (like what comes in the little metal tubes in the little patch kits. You know, the stuff that is always dried up when you have a flat and you are 14 miles from town with no cell phone.)
#108
Bikes: Too Many
Originally Posted by jim-bob
Yeah, I've seen a bunch of 'em on ebay and the like, but was hoping to get feedback from people who've used them.
(And yeah, fixed is a definite consideration for this one.)
#109
Bikes: Too Many
Much prefer Vittoria or Clement.
#110
Bikes: Too Many
I was in my woodshop one day putting on a tire and looking for something to hold it. Grabbed a vice grip spring clamp off the workbench and Voila - worked like a hot damn.
#111
juneeaa memba!
Originally Posted by toomanybikes
Luker, Tubasti is actually that HORRIBLE white stuff that never sets up hard and gets all over everything..
you are right...in my feeble mind I was confusing mastice gutta with tubasti (plumbing today, sewer fumes must be destroying brain cells). As it turns out, I was not right about what mastice gutta means either. Nor even what language it is in. Attached is a picture of the kinds of glue that I currently have in the garage. The Tubasti in that tube is red, I'm pretty sure, but it is nasty stuff. All of the other ones seem to work fine. I have been using the hutchinson lately and it is pretty good...
#113
Will tire patch glue even work on latex patches? The vittoria glue I'm asking about is this stuff any one have any expierences?
https://www.nashbar.com/profile.cfm?c...eid=&pagename=
#114
Well the tire dosent appear to be leaking there is a stedy flow of bubbles from the valve however one about every 1-2 seconds. The valve is all the way tightened and the leak appears to be in the body of the valve (see graphic) any way to fix this? Also what do you glue down the base tape with its coming up a little in one area?
#115
Señor Member
Liked 1,191 Times
I'd try opening the valve and dunking it in mineral spirits for about 10 minutes. Let it dry and try to inflate again. If it's just some gunk keeping it from sealing all the way, this might clean it out. If you need some latex tube for patching, I can send you some bits.
#116
Thanks for the tip I will pick up some mineral spirits monday. I sent you a pm about the patches.
#117
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Liked 11 Times
I've been using Conti glue with great success.
I did just pick up some Panaracer which is also clear and
has a tenacious hold (so I'm told).
Everest, see if you can find a velox tubular repair kit on ebuy
has everything you need, needle, thread glue patches etc.
Marty
Marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
#118
Elite Fred
#119
Originally Posted by mollusk
I had exactly the same problem with exactly this brand of tubular this year. I fixed it by unscrewing the valve core, applying some blue Loctite, and screwing it back together.
#120
Liked 11 Times
Everest,
The valve core should have flats on it to allow you to screw it either in or out
of the main valve housing, the whole area that you have marked should screw out.
Marty
Marty
#121
Alright I've got everything compiled to do my first tubular glueing but have a few final questions. I still need to know what to reattach some seperated base tape with, sheldos site says latex emulsion, where would I get this? Also try as i might I just cant get the old glue off the rims. It is completely hardened with no tack at all. I tried Goof Off goo remover and mineral spirits. What else can I try to remove this as from my understanding it must be removed before re-glueing?
#122
Señor Member
Liked 1,191 Times
Steel wool takes old glue off pretty well. It needs to be sort of coarse. Be sure to wear heavy duty gloves, and clean up all the pieces of steel wool that come off.
Also, there may be other viable options for latex emulsion, but try googling "jevelots". I think that would qualify.
#123
#125
If I own it, I ride it
Liked 694 Times
