I picked up a 1988 Ironman Carbon frameset with crankset and derailleurs last week, for a "parts bin build"*. From the ad:
He handed me a bag with a Tricolor RD, 105 FD and a 42 chainring. I didn't notice that the left crank was some mid-level MTB part, not even a close match, so that challenge remains.
Partial build:
Rear wheel stolen from my '89 Circuit; I've since found a 32-spoke wheel with a 105 hub and Araya rim. Front is a 600 hub / Matrix rim from a Trek I bought earlier. I only have one Tricolor brake, so I installed a pair of dual-pivot Ultegras. As expected, I did not have a 25.0mm seat post on hand. I do have a 24.0 from one of those internally-lugged Carbolite 103 Peugeots from 1980; shimmed it with a yogurt tub for the shakedown.
Def''ly light and fast, "feels faster" than my Circuit or my '86 IM.
Will I get used to the squirrely front end? I mean, I can make the frame flex just by pulling the handlebar left/right. Standing on a curving ascent was.... anxious. Does that sensation pass after a while? The back end feels solid / stable underneath me, it's just the front end that feels like its in two places at once.
More pics after I install a seat post, coming Wednesday courtesy of Insidious C. (thanks man).
* (Okay, "parts pile" is more like it....)
Partial build:
And a not so friendly price for a Cinelli/Centurion . Didn't even post a lousy picture .
https://orangecounty.craigslist.org/...655058402.html
Likes For jetboy:
Bikes: 86' Centurion Ironman
Liked 317 Times
His price would be a bit much for a actual Cinelli . IMO . Not to mention he says it needs a major over haul .
I have the same bike and had to shelve it because the glue came undone at the head tube. Sucks 😞. So that squirrel that is yelling at at you might be a dire warning. Sorry to be the bearer of cautionary news. I have contemplated trying some sort of drill and pin situation..
both! I think once one goes, the other follows. its still attached but the CF tube can twist in the lug at both top and down. sadly i found this out after I built it up and put all new decals on! first ride I was like... wtf?
This is why I tend to apply an IT principle known as "work iteratively with feedback". First thing I did was put a spare wheelset, saddle/post and bar-stem on it, even with no driveline (just the crankset as shown), and kicked it, boneshaker / balance-bike style, down the street, to get an overall sense of the size. Then threw a chain, RD, rear shifter, one brake, and pedals on, just to be able to pedal it for a mile or two on the large chainring. And so on. I doubt I'll replace the missing decals (it only has the downtube and "Made in Japan" decals), and I'm running a bar/stem that had an existing tape / brake cable job, so basically no work that I can't undo. I'm still not convinced it's not just the noodly nature of the frame. I am running 700x28Cs on it (interesting how much tire headspace there is on this bike); I don't know if that has any impact on the ride compared to 23s or 25s.
EEK again, thanks for the intel. I guess it make sense, as one joint flexes in one direction, the other will probably flex in the opposite direction.
(snip)I'm still not convinced it's not just the noodly nature of the frame. I am running 700x28Cs on it (interesting how much tire headspace there is on this bike); I don't know if that has any impact on the ride compared to 23s or 25s.
Not either of those gents but will weigh in here to say that, yes, they did tend to be somewhat noodley.
Said noodling could be somewhat reduced with a better front fork but not completely eliminated.
OK TY that's helpful to know. And, er, uh, wiping some egg off my face, turns out the headset needed tightened about 1/8 turn. Another shakedown ride after that adjustment, it feels less twitchy on fast turns. Still a bit noodly but less so. And there's no shimmy, even with no hands (BRIEFLY) at 25+ MPH on a descent.
Here's mine.
You definitely get what RT described as a "gyro effect". Similar to the bike called the sling shot. It's as if the front fork flexes then pulls back. Added to that the bottom bracket tends to move when you stomp on the pedals making the chainring rub. However it is the lightest of all the Ironman.
The thing you don't want to do is over tighten the the headset ala RT. He kept tightening it thinking it kept getting loose but actually the headtube had split.
Likes For texaspandj:
Likes For PanYAgua:
Sweet. You sure it's a 58cm? Looks smaller. I have my purple one in the classifieds and it looks like the same size.
2019 Salsa Warbird
2019 Salsa Warbird
Here's mine.
Included a bag with a Tricolor RD, 105 FD, the other chainring and the chainring bolts. The 88 serial number and the graduated thickness of the lettering tell me that it's an '88 Ironman Carbon, not an '89 Carbon-R. Does not explain why the few bits it came with are Tricolor and not DuraAce, as the seller assures me it's original (shrug).
As I'm riding it now:
Oddball 25.0 seat post is courtesy of Insidious C. , everything else is from the parts pile. Wheelset is a close mis-match; 105+Araya rear, 600EX+Matrix front, the black ano and profiles are about the same. Cockpit is a take-off from... somewhere (thus the joint in the middle of the rear brake cable housing). HG Cassette and IG chain are NOS. I *think* the shifters are Tricolor; they're that familiar gunmetal-ish blue color. Somehow I have only one (front) Tricolor brake caliper that color, so I opted for a slightly later pair of dual-pivot Ultegras. Continental 28s, since the kids these days are all into their super-fat tires. No, I have not cut the shift cables yet; I have another bar/stem already taped up for bar-ends, so I may go that route, esp since this bar is too wide.
Ride-wise, yes, it's a different experience. I think I've worked out the kinks in the overall ride, and it feels more "natural" with each ride. I think it's just something new to get used to. It definitely likes to get up and go. And for a quasi-Frankenbuild, everything just works. Braking and shifting are tight and crisp, took almost nothing to dial in. It's so good, I'm almost reluctant to try the bar-end shifter swap.
Edit - the other nice surprise - 172.5mm cranks. I think it my first bike with 172.5s. I have a few 175s and they feel "too long". I sense that 172.5 is just right, a la Goldilocks.
The Carbon Ironman was equipped with tricolor while the Carbon R was equipped with Dura Ace.
The Carbon Ironman was a one year release '88 while the Carbon R was two years, both '88 and '89.
One thing I would caution against is replacing the fork. To reduce the flex some (RT) have tried replacing the fork with a more rigid one and had disastrous affects. I think the flexy sexy fork helps prolong frame life.
Wondering if texaspandj and/or seypat would have a moment (and the inclination) to weigh in. Are these frames noodly even when everything with the bonds in normal? Or is that a warning sign? I'm not able to detect any movement between any of the tubes and the head lugs.
I heard from He Who Shall Not Be Named over the weekend. He's doing all right and getting good grades. His future's so bright, he's having to wear shades. Living large, cycling like a mad man and (for texaspandj) getting back into running. I think he'll be hunting for a Boston Qualifier in the coming year.
Bikes: Miyata 618 GT, Marinoni, Kestral 200, Soma double cross 2002 Trek 5200, KHS Flite, Koga Miyata, Schwinn Spitfire 5, Mondia Special, Univega Alpina, Miyata team Ti, Santa Cruz Highball, Waterford rs11
Liked 3,052 Times
All the lugged composite frames I've had have had that flex to them. Never had one fail but I've heard the stories. You could really feel it on fast downhill corners.
Speaking of which... I actually looked at one of these, same price, a year or so ago. Post your Centurion Ironman.. For the love of 80s paint jobs! . It may well have been the same frameset. Completely forgotten about, when I was tracking on the one I just bought.
Meanwhile, I decided to take some time off from working out and letting my injuries heal. I know better now but it was a bad decision to do that. My back that I've mentioned here quite a few times got really bad. It was literally debilitating. I could barely walk, let alone run. I never tried riding because I was afraid I wouldn't be able to...then what. I couldn't stand without pain. Sitting for prolong periods wasnt much better. I had X-rays and MRI which revealed I had several things going on. Suffice it to say I thought the good times were gone for good. I thought I could defeat it with my mind so I never let my wife tell me specifically the 5 issues that were going on with my back. Instead I decided to sign up for 1 triathlon. I convinced my wife I wouldn't run and that it was the motivation I needed to lose some weight.
I biked 2 times before the triathlon and hurt my knee. I limped 2 weeks prior to and leading into the triathlon. I limped 2 weeks after triathlon too. The funny thing is during the knee issue my back stopped hurting... so much.
Now I'm on the mend , moving some and biking joy rides now and then. I went to see my martial arts teacher and he said " You got yourself in this mess, you can to get yourself out of it". That's what I'm doing.
Keep the rubber side down Ironkids.
I had taken a break from the forum when He Who Must was suddenly no longer to be named. Glad he is doing well and pass along my respects if you have a chance.
for IM content: I am jealous your frames are not damaged: here is a pic of mine that I rode once and then started crying. heh. it was gonna be my mountain climber with crazy gearing. it was so very pretty. (note, the decals are probably incorrect as a Carbon-R- but they were what He who Was not had on hand and sent me)
Sorry if this pic has been posted but it is pretty cool so here it is just in case.
Likes For smallfrontwheel:
My heart had stopped and they showed me this picture and I came back to life! This is the coolest Centurion picture I have seen.
Which model of Centurion bicycle is this? I do not remember seeing it.
Victoria Principal, who starred for nine years as Pamela Barnes Ewing on the CBS nighttime soap, Dallas,
mounts a Centurian 10-speed. Principal authored several fitness and health books, including
The Body Principal in 1983. Also in the early ’80s, Principal had a Top 100 hit: a
duet with Andy Gibb, a redo of the Everly Brothers’ “All I Have to Do Is Dream.”
Bikes: 82 Medici, 85 Ironman, 2011 Richard Sachs
Liked 2,236 Times
smallfrontwheel NOT IM!
