Pics of fast bikes with triples?
#76
Overdoing projects
Liked 1,304 Times
I might be young with strong legs but my go-fast bike is a randonneur that doubles as a touring bike. You bet I enjoy lower gears at the end of the day, especially if I am hauling some gear up a mountain.
As for the 1x MTB guys, most only really care about getting up a hill and then bombing down one without pedalling or without their chain falling off. And that's simply a lot easier with 1x setups with narrow-wide chainrings and clutched derailleurs.
#77
I can understand the tiny crank/pizza size sprockets on the back MTBs for added ground clearance. That's acceptable, I guess.
#78
(rhymes with spook)
Liked 745 Times
So there's more to the story, imagine that.
TW189 was built for 1979 Paris Brest Paris by the original owner, it ended up being a tad small so he scrambled to have a Davidson built and rode it to a very good result, 27th out of 129 Americans, 502nd out of 2113 overall, pretty fast for 30lb+ touring bike, especially with a triple.![Wink](https://www.bikeforums.net/images/smilies/wink.gif)
Bob Freeman helped Tom with all of this and he didn't really say why he switched to Davidson for the new one, again, fine with me as this is in great shape. He did ride this in STP a couple of times and was fast on it, pretty sure Tom was fast on whatever he was riding.
He also said that after PBP he was feeling very good and rode around Europe for a couple of weeks with the guys he raced with thinking he might race full time but by the time he got done with that it was not to be. He actually quit riding and never went back to it.![foo](https://www.bikeforums.net/vb/cache/ds.jpg)
that's kinda sad he quit. i mean, sorta. maybe it was something significant that changed his mind, or maybe it was merely fleeting fancy to begin with
Likes For thook:
#79
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,659 Times
#80
Bikes: Yes
Liked 4,128 Times
This is the thing that gets me about 1x -- everybody who likes it talks about the simplicity, but the amount of technology that goes into a clutched derailleur that can handle a 10-50 cassette kind of invalidates that in my mind. I guess as long as it keeps working it's simple for the rider. So it's simple in the way an automatic transmission in a car is simple. It's not really simple, but it usually lets you think it is.
My Bikes
My Bikes
#81
Liked 6,587 Times
Agreed, he decided to quit riding if he couldn't up his game another big level.
#82
Those are separate issues. You can build 1x drivetrains with unclutched derailleurs, and you can build multi-chainring drivetrains with clutched derailleurs. Clutches are ubiquitous on derailleurs intended for 1x setups with 10-50 cassettes because these are used almost exclusively on mountain or sometimes gravel bikes, where most riders want the clutch regardless of how many chainrings there are. Similarly, in both their gravel and MTB lineups, Shimano derailleurs intended for 10-speed and above generally use clutches even if they're made for 2x drivetrains.
#83
Bikes: Yes
Liked 4,128 Times
My Bikes
My Bikes
#84
#85
Wide-range drivetrains can have greater difficulties with the drivetrain being slack in smaller sprockets, but this isn't unique to 1x. Wide-range 2x and 3x drivetrains can wrap just as much, if not more, chain. And I can say from experience with the 48-38-24 11-32 setup on my gravel bike that these sorts of drivetrains don't need a super-wide cassette to be super bouncy.
That said, there is one obvious big-cassette-specific risk: when you suddenly stop pedaling, the cassette still has its momentum from when you were pedaling. If you're on a small cog, then:
1-you were probably going fast and the cassette is spinning pretty quickly, and
2-that small cog has a lot of leverage on the chain.
And if the cassette is big, then it has a lot of momentum.
This leads to a situation where your chainring has stopped and won't let any chain through, but your cassette is still trying to push chain from the lower run of the drivetrain to the upper. This happens with all derailleur drivetrains, but is rarely severe when the cassettes are small. Having some extra resistance to chain unwrapping, like a clutch, doesn't hurt in counteracting this.
And with 10-50, I think the technology is a bit more complex even without the clutch.
#86
Bikes: Yes
Liked 4,128 Times
I should note that I don't actually know much about the details here. I'm just reasoning from my lay person's understanding of how the derailleurs work combined with some real world experience with dropping chains on a 1x10 CX bike.
Likewise, I don't know anything about the technology needed for wide range cassettes, except that when they first started showing up I read something about the R&D that went into making it work. It requires a pretty wide range of motion, and I'd imagine you need to maintain a reasonably consistent closeness to the cogs. Can you get all that with just a slanted parallelogram?
My Bikes
My Bikes
#87
Overdoing projects
Liked 1,304 Times
Sprag clutches are some of the most high-reliability monodirectional bearings there are. Sure you won't be making them in your garden shed but neither were those hardened ball bearings.
It's about as complex as a derailleur spring with a tension screw; barely in the back of your mind if it works, a lot of disassembly when it eventually breaks.
![Stick Out Tongue](https://www.bikeforums.net/images/smilies/tongue.gif)
![](https://www.velonews.com/wp-content/uploads/sites/5/2021/01/shimano-rd-2.png)
I consider it a positive optional improvement coming back from the 30+ years of MTB technological development. Manufacturing has changed and often improved. Old musle cars are often smoked by modern family cars and a large part of that is the enormous improvements in tyre manufaturing. The old rubber couldn't put the power down but modern ones are optimized for better handling, wear and acceleration.
As for clutches on bikes; they fit a certain type of usage that is non-existant on road bikes and most commuters. But significantly reduce a problem that was once common on mountain bikes with triples.
Likes For JaccoW:
#88
That's why I pointed out the huge range of my gravel bike's unclutched drivetrain. That thing takes a massive 116-link chain, and even though I generally avoid the smallest couple cogs in the small ring, it still gets asked to wrap up to about 41 teeth in practical usage. It gets pretty bouncy even on the 38T middle ring, and to prevent the chain from going places on chunky descents, I'll often shift into the big ring even if I don't intend to pedal. Riding over big chunk has caused me to throw the chain off the inside all the way from the middle ring a couple times (although I haven't had it occur since I installed a Dog Fang chain catcher).
Most derailleurs have some offset between the jockey wheel and the a-pivot. But front shifting makes it hard to rely on entirely: front shifts alter the chain wrap and adjust where the jockey wheel sits relative to the cogs, which isn't something that you want.
That's why 1x-specific rear derailleurs are a poor choice for multi-ring drivetrains, and why slanted parallelograms are important: the parallelogram's trajectory is unaffected by which chainring you're in.
#89
blahblahblah chrome moly
Or are you kidding, I can't tell.
To be clear, in my post I was aiming for a breezy tone, with just a light hint of nostalgia for when I wasn't such a weakling. If that came across as "so sensitive" to you, then I suppose I should have added a smiley as insurance against being taken too literally.
For the record, I'm pretty much OK with being old and weak. Since there's no reasonable alternative to being OK with it. My philosophy now is "Any day above ground is a good day". Apologies to any coal miners, spelunkers or tunnel diggers who may read this.
Mark B
#90
Overdoing projects
Liked 1,304 Times
Right, but the same issue crops up in wide-range multi-ring setups with smaller cassettes.
I imagine that a lot of effort went into optimizing the shift gates and derailleur geometry. But when I think "complexity" in the context of a consumer setting up a drivetrain, and holding a derailleur in the hand and seeing how it works, I think in terms of stuff like pivots and moving parts. And the wide-range 1x derailleurs are no more complex in this regard than derailleurs for smaller cassettes on multi-chainring drivetrains.
I'm not sure, but they generally don't. 1x-specific derailleurs tend to rely less on slanted parallelograms than multi-ring rear derailleurs do. SRAM 1x-specific derailleurs don't have any parallelogram slant at all. Instead, 1x derailleurs tend to use a lot of offset between the jockey wheel and the derailleur's a-pivot. So when the derailleur wraps more chain, the jockey wheel swings downward away from the cogs.
![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
#91
señor miembro
Liked 6,659 Times
#92
But when top pros, climber specialists even (not the Laughing Group) are using a 28" gear in grand tours, mere mortals should not feel any pressure to keep low gears off their "go fast".
-mb
#93
I find this perplexing. Aside from the issue of having the right spindle and front derailleur to make a triple work, I can't see how a compact double is an improvement in any way. I've tried a compact double (50-34) setup. For extended road riding in works OK. For anything where I need to start and stop, I feel like I'm always in the wrong gear and constantly having to switch back and forth between the front rings. A 46-34 double work a little better for me, because I can mostly just use the 46T ring with the 34 as a bailout, but that's the other problem -- a 34T bailout gear isn't really sufficient as a bailout.
Everyone these days loves 1x setups. The way I use a triple is very much like a 1x with other options. I do 90% of my riding on the middle ring. It has all the gears I usually need for anything from 0-25 mph, and with a 9/10 speed cassette the gear spacing is entirely acceptable. But because it's a triple, I have a serious granny gear I can drop down to when needed for steep climbs, and I have a big ring I can jump up to on the exceptionally rare occasions when I want to go faster than 25 mph and am not satisfied with how quickly the hill I'm riding down is getting me there.
So what improvement does a compact double offer?
#94
Because "go fast" is a purpose, not a rider or a terrain or a specific speed.
I don't think it makes sense to assign any specific ratio as a lower bound to what's needed for "go fast." In the real world, the range of ratios that people need is enormous. Preferred cadence doesn't vary that much with ability level, but top racers fly up hills several times faster than a lot of roadies in the low performance quartile. Some areas have hills that climb at 2% for half a mile at a time, some areas have hills that climb at 5% for a mile at a time, some areas have hills that average 12% for two miles at a time with stretches of 17%.
This doesn't result in a situation where some people are fine on a 39-25 and some people need to use a 36-28. The practical disparities in both ability and circumstance are far, far, far more extreme than that. It results in a situation where some people are fine on a 56-23, and others will struggle on a 26-42, even if both are on "go fast" rides.
Likes For HTupolev:
#95
Some perspective:
The 24/34 combo on the Davidson makes me fast going up the top part of Keiler Canyon and Cypress Mountain...faster that is, than those who are walking their bikes.
So, there’s that.
So, there’s that.
Likes For rccardr:
#97
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Liked 365 Times
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1338x1000/trek400_1_copy_8817f1ddfb1d4926764b3cfebb8fe0a05a1d7316.jpg)
Tagging on Doc's post, above, here's the bike that I rode in two years of the Eroica California. Trek 400, with a triple. I think the low was 28x26 since the hubs were 7400 and I only ever had one cassette for them. I'm not all that fast, but it was a fun bike. It was a touch too big for me, so I converted it to a townie and sold it cheap to a co-worker's 6'6" husband. Kinda regret that now, but what can you do?
Likes For mhespenheide:
#98
![Big Grin](https://www.bikeforums.net/images/smilies/biggrin.gif)
#99
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Liked 351 Times
Campy Chorus triple. It's since been replaced with a Campy MTB triple since I wanted a smaller middle ring.
![](https://cycle.ciocctoo.com/losa1.jpg)
#100
señor miembro
Liked 6,659 Times
