Your century bicycle(s)
#51
Bikes: Specialized Roubaix Comp, Soma ES
Originally Posted by stapfam
Depends on you and the mountains but Can you change the rear cassette to something lower? I know of a regular century rider on hilly routes that use a double compact crankset, and he has changed his rear cassette to a 12/34. This did require a long cage rear derailler so adding to the expense but a couple of centuries a month is his norm.
My Giant has a triple and on our hills I would not contemplate any thing else but When I do road rides on the MTB I have a crankset of 44/32/22 and I can assure you that I do use the lowest gear of 22/32 at some point. So why is it that on the same hills on the road bike- I can sail up hills in 30/26? I think it is a mental thing- It starts hurting so change down- but when you run out of gears- you have to put up with the pain.
Yeah, I have a short cage derailleur so the largest I can go (according to Campy) is 13/26 which is what I have. I took a ride today on the compact that has a nasty hill and it kicked my butt. So much so that 49 miles into the ride (65 mile ride), I had to call SAG support. That's the wife. Pretty bad as that's the first time I've ever had to do that....
I switched to the triple tonight, but need a front derailleur. Hope this is what I need...
#52
don't try this at home.
Originally Posted by fastturtle
...It could also be that the manufacturer (despite his great reputation and undisputed experience) laid the cables in an inadequate location along the bar, meaning that my hands don't rest on the nice flat surface that is normally provided by Campagnolo levers. One of these days I will probably try redo the cable routing and taping - I hate that - and see if it improves.
#53
Chief Chef
Bikes: 2005 Fuji Touring, 70s Motobecane Grand Record, Sekai 2500, crappy mountain bike from dumpster, cyclone cycles titanium road bike
Originally Posted by Spudmeister
IRO Mark V - Single Speed, built with 650B wheels
#54
Old enough to know better
Bikes: On One, Surly, Gunnar, Lemond
Originally Posted by BearsPaw
Is that a light on your rear fender, or just a reflector? It looks fancy.
It is a light & reflector. Here's a link...
https://www.peterwhitecycles.com/spanninga.asp
Look just over half way down the page.
#55
Chocolate and nap
Bikes: Old Peugeot PX10, '1974 custom Gemini racing bike, custom Singer randonneuse (Levallois, France) and Randocycles mountain bike w/rear panniers
Originally Posted by Machka
What bicycles have you ridden your centuries (or brevets, or double centuries) on ?
https://abeille-cyclotourisme.chez-al...is_luchon.html
Steel frame (Reynolds), hand prepared Brooks saddle, Speedplay frog pedals, Maxicar hubs, alu fenders. I normally remove the front racks on long distance rides for more comfort (they increase rigidity).
I never use my racing bike (vintage custom Gemini '1974) except on races (!), even on 200 km rides or brevets. Comfort and required equipment are more important to me than weight.
#57
My bikes followed by the number of centuries done on each in roughly chronological order:
Falcon Black Diamond: 2
Paramount P13: 4
Paramount P15: 5
Falcon San Remo: 15
Nearly all centuries were done on 27mm tires or larger, all on Brooks saddles, and most with fenders. Since organized century rides go rain or shine, fenders make an all day ride in the rain a lot more comfortable. I think tire size is a much greater determinent of ride comfort vs frame material.
Paramount P13: 4
Paramount P15: 5
Falcon San Remo: 15
#58
Edit: Or maybe get my lazy ass in the gym.
#59
Bye Bye
Originally Posted by knobster
Couldn't agree more. My Trek 520 has 32's and is very comfortable. Problem is the weight. When I get done with a long ride I am beyond tired. I don't hurt, but can barely function. My other bikes are not as comfortable, but I am nowhere near as tired, but my body hurts. Wonder if putting larger tires (already have 25's) on the faster bike would make up for the comfort issue on longer rides?
VBQ / Bicycle Quarterly had a good testing article on it a while back.
Depends on the materials in the tire, tread thickness, tread hardness, pressure etc.
I'm riding 25's at the moment. Had some Schwalbe Marathon 28s on it but they were really slow. Looking forward to my UPS of Continental GP 28's. I like their 25's but want a little more cush for the long haul.
So long. Been nice knowing you BF.... to all the friends I've made here and in real life... its been great. But this place needs an enema.
#60
If you keep riding the heavy bike it will make you less tired at the end of a long ride. You will adjust. You can probably run your 25's at 70 psi if you look where your going all the time. I can ride 23's at 70 all day.
#62
#63
Bikes: 88 Schwin Voyageur, 84 Schwinn World Sport, 85 Univega Alpina Uno, 85 Fuji Espree, 09 Novara Strada, 06 Jamis Durango, 03 Specialized Expediton Sport, 09 Surly LHT, 12 Novara Gotham
All on my 1988 Schwinn Voyageur steel frame...
#64
Bikes: gaint crx 2 2007
#66
Bikes: 2008 Turner Spot, Berg Ti Cross, 2011 Karate Monkey
Ciclo
2006 Marioni ciclo. 50/34t rings, 12-25 cassette, Columbus steel frame
Just Riding Along
Just Riding Along
#67
Bikes: Specialized Allez cromoly, Fisher Paragon 29er
Same as my non-century bike! 06 Tarmac Pro
06 Tarmac Pro.
Actually do have a steel Allez that a friend is borrowing that I might turn into more of a century rig. It is a triple with a fairly upright position and has 28s. I might add more cushy bar wrap and maybe aero bars?
I know, bad quality pic..oh well...
#68
just another gosling
Liked 2,006 Times
First centuries and first double on a mid-70's 12-speed steel Mercier, purchased used. About 27 lbs. What a POS. Slow, hard to drive, flexible so that it felt like I was about the tear the bars off when I got out of the saddle. A double on that bike took 16 hours.
After that, many centuries, doubles, long mountain rides, and now brevets on my '99 Trek 5200 carbon OCLV bike (purchased new). Low end Rolf wheels, 23c Vredestein Tricomps pumped to 145 lbs., Terry Fly saddle. 12 hour doubles on this bike. 18.5 lbs. naked. I notice no discomfort from the fast tires and wheels or from the Trek racing geometry. On the contrary, a good handling fast bike is more comfortable. The Vredesteins are durable and have good road feel.
Triple in front 52-42-30, 12-25 in back. Perfect gearing for LD work. I can run the whole cassette from the middle chainring and seldom use the granny or big ring. If I were going to do a mountainous 1200, I'd go to a 12-27.
The lighter your equipment and the faster your wheels and tires, the bigger gears you can turn and the less time you spend in the saddle. That's what I think so far. I'll let you know if I change my mind after I do my first 1200. But I don't think so. This is pretty much what my rando buddies do, except that most of them run Litespeeds. Around here, a rando rider can be defined as someone who would take a $5,000 TdF capable bike and hang a trunk bag, lights, and fenders on it.
#70
Liked 674 Times
Personnally I am not clear yet how "aggressive" a position I prefer. I have ridden quite a few centuries on bikes where the handlebars were a few cm lower than the saddle, a setup I would qualify as "rather aggressive". I have recently bought a dedicated randonneur bike which is less so, with bars almost level with the saddle. I am not actually sure I prefer this more relaxed position. It could be that because my hands are higher I put more weight on them, it is hard to explain. It could also be that the manufacturer (despite his great reputation and undisputed experience) laid the cables in an inadequate location along the bar, meaning that my hands don't rest on the nice flat surface that is normally provided by Campagnolo levers. One of these days I will probably try redo the cable routing and taping - I hate that - and see if it improves.
One advantage of these highish bars is that I can ride on the drops without feeling too cramped.
You might not like having the bars higher than you are used to.
Road Fan
#71
My 2000 Lemond Buenos Aires has been with me on my only 3 century rides, with more to come this spring and summer. The first two it was 105 equiped and the most recent was with the 10s upgrades. It's comfy.
#72
As of yesterday I can add this bike to my century list. It was my first fixed century and longest ride of the year (110 miles, 7:03 ride time). Straping the jacket on with the seat bag really freed up jersey pocket space for food. Some steel or carbon would go along way, that aluminum frame and fork worked me.
That makes 2 unsupported solo centuries in 12 days for me. The Cream Puff training is coming along nicely.
#73
Bikes: ANT Club Racer, 2004 Trek 520
My current brevet bike has the handlebars and saddle at about the same level, and I found that the pressure on my hands was greatly relieved, and the nerve issues in my hands have become a complete non-factor. Riding in the drops has also become much more comfortable.
The only niggling thing about the raised handlebars is that it makes me feel more upright and less aerodynamic, but I suspect that's more of a psychological bugbear than anything else.
#75
Crankenstein
Bikes: Novara Randonee (TankerBelle)
Well, now that I've got my first century done (and second, AND third! Three weeks, three centuries!) I guess I can post my bike in this thread!
1988 Raleigh Technium... Since the photos I've added clipless pedals, fenders, aerobars, and a better light. I currently have about 8,500 miles on it Gets me where I'm goin'!
