Do you balance (not true) your wheels?
#51
Interesting point. I'm starting to think I've been incredibly lucky with bicycle wheels/tyres for all these years. I've never given ANY of this stuff a second thought (actually not even a first thought) and had zero issues with wheel "roundness", balancing etc. Maybe it's only a problem if you actually think about it?
As to balance, never been an issue that I've ever seen and I've ridden my own wheels at 45-55mph down hills and mountains hundreds of times racing against others riding stock and custom wheels and the wheels being out of balance wasn't an issue.
Likes For Russ Roth:
#52
Disco Infiltrator
Liked 2,150 Times
Some part of me wants to willfully add length to all your rosaries saying it matters more for lighter wheel sets because of reasons I just made up
Dynabeads! I hadn't thought about that in a while. Years ago I poured a whole package of Airsoft pellets into a motorcycle tire following the advice of someone on ADVRider, thinking to try it but not wanting to spend the money on the actual product. I have no idea if it accomplished anything but it sure sounded funny pushing the bike out of the garage. Sold the bike almost ten years ago... I wonder what the next guy who changed the tire thought of me.
Genesis 49:16-17
Genesis 49:16-17
#53
dot dash
Bikes: Shmikes
Liked 6,167 Times
I have an old set of Ksyrium Elites, which came counter-weighted, and it's effective in making them spin at constant velocity on the work stand (provided the valve length is right ). I thought it was very cool when I got them.
#54
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Liked 1,458 Times
...from the factory?!?! i.e., were all new Ksyrium Elites counter-weighted?
'cuz I've got a 16-year-old pair of Ksyrium Elites on my Synapse and I've never noticed anything inside or outside the rims that could be a weight. Is the weight somehow integrated into whatever joins the rim at its seam, opposite the valve hole?
#55
Likes For Seattle Forrest:
#56
pan y agua
Liked 893 Times
What is the relevance of this test? One cap and one nut weigh 1.5g together. Adding that to a balanced wheel makes it still far more balanced than 99% of stock wheels out there.
When I hammer down my local climbs, I prefer my wheels to be balanced to remove one source of oscillation I can easily control. This does not mean that this is compulsory to do so in order to be safe, or that it can be specifically felt.
the point is if you’re balancing a wheel, it’s a pretty small aomount of weight. Look at your car wheels/tires. The combination of the wheel and tire on a car is ,20, pounds or more. The little lead balancing weights are a tiny fraction of that.
The nut and cap on your bike wheel are at least as large a percentage of the total wheel weight as the balancing weights on your car wheel.
if it actually made a difference, the cap and nut should be perceptible and they aren’t
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
#57
Happy With My Bikes
Liked 2,753 Times
Perhaps an experiment would be to add weight to the heavy portion of the wheel until the imbalance would become noticeable at a reasonably safe speed. I'd wager that the weight required to be noticed at road conditions would be far greater than that to correct the imbalance on the work stand.
#58
should be more popular
I know from my weight finding exercise that the 1.5g of the cap and nut would indeed be enough to get the wheel out of balance enough for it to fall to the heavy spot, however, obviously not as drastically as before.
But I never made an argument that one could feel the difference even between 13g unbalanced and perfectly balanced - or that there is any significant amount of energy to be saved in the scheme of things - so the cap and nut obviously will not register. It is more about principle and the assumption that there could indeed be a reduction in system imbalance on high speed descents with no discernible downsides to something that is easy to modify.
Seeing the difference of a bouncy bike vs a smooth running wheel on the stand is the most significant impact one will actually see and feel. People spend so much time and money optimising their bikes to the highest degree in so many areas but a $3 and 15minute wheel balancing is too far out even though the small amount of weight added does not matter due to it's rotational energy being conserved and it's arguably one of the most important parts of the bike that can only benefit and not be harmed by a bit of optimisation?
#59
dot dash
Bikes: Shmikes
Liked 6,167 Times
#60
Bikes: Ibis Hakka MX / team machince alr2 / topstone 1 / Cervelo zht
Liked 278 Times
I thought a speed wobble was more like a tank slapper on a motorcycle. More like something upset the bike ( something in the road, etc.. ) then the bike
starts to resonate back and forth.
#62
pan y agua
Liked 893 Times
The weight I needed to balance my wheels was almost 13g per wheel or almost 10 times the amount of the cap and nut weight.
Show me one pro tour mechanic that balances his or her rider’s wheels. You’re obsessing over something that just doesn’t matter.
#63
Likes For yaw:
#64
dot dash
Bikes: Shmikes
Liked 6,167 Times
Ah, just so. Mine are 2014ish. Nice, indestructible, wheels, but relegated sadly to the trainer bike these days.
#65
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Liked 1,324 Times
Those mavics - that's the rim seam. It's bumped out there because that's where the join is made. The decals cover the joint because it isn't as pretty as the rest of the extrusion. There's lots of methods for joining but many times it involves a sleeve that is added to help reinforce the joint and help keep the joint aligned during pinning or welding.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#66
dot dash
Bikes: Shmikes
Liked 6,167 Times
#67
Heft On Wheels
Liked 561 Times
That video with the aussie;;;;;;;;
This guy has serious OCD issues LOL . I imagine that wheel that is shaking when just spinning won't have that with the weight of the bike and rider on it. I still can't believe this is a thing. there is no way pro teams are doing this.
#68
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Liked 201 Times
Apparently, Fulcrum has been been incorporating this in their wheelsets for a while. They either use 2 oversized spokes opposite the side of the rim joint, or they add extra weight on that opposite side. I have 2013 Fulcrum Racing 5's and they have 2 silver spokes straddling the valve hole, opposite the rim joint, with the rest of the spokes aero and black.
Fulcrum Dynamic Balance
Likes For momoman:
#69
Ahh come on you know you want to do it!
#70
I eat carbide.
Liked 1,324 Times
yup - because it's not.
Still...it's on my list to come up with some sort of justification for it, etc. I spent a semester in college studying a field that I can not remember the proper name for. It was roughly "machine reliability". During that course we studied the obvious reliability and preventive maintenance calculations and theories. We also used an extremely expensive, at the time, accelerometer to take vibrational readings off operating machinery to detect imbalances, bearing issues, etc. Enough to know anything we even remotely attempt with a bike is pretty stupid but... "marginal gains" amirite?
During that course we got heavy into the the mechanics of balancing. Static, dynamic, multi-plane, etc. I then went and visited my girlfriend at the time (wife now) company her family owned. The made every flywheel that went on every engine that Caterpillar assembled in North America. As a part of the heavily automated line that was set up to do high volume on-highway flywheels for semi-trucks they had automatic balancing machines. Being in the middle of the theory involved I asked them 3 or 4 questions about the type of balancing required, etc. The response was, "What I know is I put it in the machine and it spits it out with a green light and I can ship it to CAT and get my money."
I ended up working for them eventually and was there when the economy collapsed in '08. Leaving there was what started PSIMET as a company.
All this means that I get really bored reading about bicycle wheel imbalances. ...but like I said I will put it on my list, dig out my old books and get back into the theory and will come up with a product and method that will end up being all over the marginal gains people's lexicon.
Likes For Psimet2001:
#71
Liked 888 Times
r.e. -- 2nd bold -- could always squeeze this through the valve core >>
https://www.hofmann-powerweight.com/...lancing-powder
