Campagnolo Record 8 speed history
#51
Steel is real
Bikes: 40 - accumulated over 40 years
Liked 1,229 Times
For my life I cannot remember from where I got these pictures and info. Please tell me if you know - so that the original source can be credited. I saved it in 2012-2013 but it must be pre 11-speed (pre 2009). I have found it most handy to consult from time to time. 11-speed fits the two last profiles.
edit. This info was found long ago at Branford bike.
Likes For styggno1:
#52
Branford bike ?
Likes For redshift1:
#53
Steel is real
Liked 1,229 Times
Googled it. It seems like it. Thank you Branford bike! (edit - and thank you redshift1) There seem to be some interesting info over there:
https://branfordbike.com/knowledge-base
Likes For styggno1:
#54
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Liked 572 Times
I have two 1990/1991 Record rear derailleurs, and they look very similar to that one, but not exact. Similar cable adjuster. Same hanger bolt. They use an old school hex nut for the cable anchor. The wheels have like 14 ball bearings each. Your faceplate appears more curved than mine. And the inner cage plate is different, with mine having no tab for chain routing. Here is one of them:
The limit screws in the '90/'91 Record are different lengths, with the high limit being shorter. Still, the low limit isn't long enough to use with 7-speed friction, so I had to use one from an old Suntour mech.
Cage tension is adjusted from the outside, with the screw highlighted here:
Likes For billytwosheds:
#55
In addition to Brandford Bike's excellent resource, I have a Veloce Campy hub that happily takes 8, 9, 10 and most likely 11 speed cassettes without any modifications or after market spacers:
Campagnolo 8 Speed Alloy Hub Spline
#56
Strong Walker
As both the old shallow spline freewheels and the ti exa ones were on the market at the same time, some but not all "not ti" 8 Speed hubs can be converted from a donor hub, I believe swapping the axle and the freehub were the steps necessary.
On the topic of gearing range; in my experience a long cage derailleur isn't absolutely necessary to accommodate a triple crank. I rode a racing triple with a short cage record derailleur (albeit 10spd) on 12-26/12-27 for years - it works of you keep in mind to avoid large-large and short-short gearing, which I, being trained old school do anyway.
