Broken spokes...
#51
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Liked 210 Times
That’s just not true. Yes, tension is important but it’s just not the end all/be all of a strong wheel. The article I linked to in post 13 doesn’t mention tension at all. The article is written by Ric Hjertberg who is the founder of Wheelsmith who knows a thing or two about building wheels. ......
... can’t. The parts are just not up to the task at hand.
Hjertberg has been a pretty big advocate of accurate spoke tension measuring for a long time now.
I'd say the OP's problems are twofold: Crappy OEM wheels with dirt-poor spoke quality AND machine building with zero attention to even and appropriate spoke tension.
Rebuild those wheels with double-butted DT or Sapim spokes and achieve proper, even tension, and the OP will be set. Unless he weighs 350 lbs. and bombs rock gardens with flat tires on that bike!
PS And DT's spoke tension meter retails for over double the cost of the one above. Crazy!
#52
Mad bike riding scientist
Liked 4,538 Times
I always took that +/- 20% to be the tolerance for relative spoke tension - the difference in tension between different spokes. I agree that's a wide range, but that just means there's enough resilience in the overall wheel build to accomodate that, as long as you stick to those guidelines. I haven't seen anyone suggest that spoke tension has to be exactly the same, and wouldn't be achievable anyway. It's one of those cases where "close enough is close enough". That spec just tells you what close enough is.
And a spec of +/-20% isn't just a wild-ass guess. There are a lot of things that can operate with that range of tolerance. Depending on where they're used in the circuit, capacitors can easily have that tolerance, for example, as well as many other electrical components. I think some of my bicycle tires might have a wider range of inflation between minimum and maximum.
As to the spoke tension overall, again the common advice is to have even tension. I don’t disagree with that but how even is “even”. The ranges of suggestions from the few manufacturers that provide them are already quite wide…roughly ±10%. If you go ±20% that’s now ±30%. That’s a huge swing and not really all that useful.
Stuart Black
Stuart Black
#53
Liked 4,538 Times
Disagree about tension not being important. It's crucial. And when you quote someone who makes possibly THE most precise and nice spoke tension meter on the market, it's kinda funny:
What’s the biggest overlooked feature in wheel building? Do you use it to your benefit? I bet not, but even still, you could probably use a reminder. Hint: it’s about spokes.
What’s the downside?
Stuart Black
Stuart Black
#54
Good for you! DT Swiss are about as good as it gets. Go with the Alpine III and ride with confidence.
One caveat: Go find an old wheel (check a local co-op) and dismantle it, then use it to practice lacing and tensioning before you build up with more expensive spokes. I used this four part series of articles from Bicycling magazine to teach myself how to build wheels nearly 40 years ago. It’s the basis for a class I teach on wheel building as well. You can pretty much ignore the first of the series which are about wheel parts and selection but the three other parts are still applicable
#55
Liked 4,538 Times
You could have bolded it, underlined it, and put in italics. You are still wrong.
Keep repeating that to yourself all you want. It’s never going to be true.
Yes, I agree. I just see it from a different perspective as to who is shoveling garbage.
Elbows break because they aren't seated, as I have told you many times before. I seat my elbows, and the hundreds of wheels I've built have no elbow problems.
Garbage in, garbage out.
Stuart Black
Stuart Black
#56
Some points that seem to be confusing to some people:
1. Spokes normally don't break on well made wheels.* If anything, the spokes on a good wheel will outlast several rims and possibly the hub.
2. 14 gauge elbows don't break on correctly built wheels. They break on wheels built by amateurs that have never received real instruction, and they break on machine built wheels because the machine isn't able to seat the elbows, stress relieve or balance tension. Thick, 2.3mm elbows are designed to counter poor wheel assembly, and are even advertised for use by machine wheel builders.
3. Butted spokes are more elastic, and are able to make up for under-tension, over-tension and sprung elbows better than straight gauge. A well built wheel doesn't require butted spokes to last, but butted spokes are lighter and ride nicer - so there is always good reason to use them.
4. Stiffer rims flex less vertically, which decreases the tension range that each spoke sees every revolution as it goes past the 'flat spot' on the ground. For a given rim weight, taller rims are stiffer than shallower rims. For a given shape, thicker walled/heavier rims are going to be stiffer than lighter/thinner walled rims. Smaller tension deltas mean less work cycles on each spoke, decreasing the wear and tear on each spoke. This is why you can build a 36 hole wheel on a 270g rim and have it last - the spokes are closer together to minimize the flex of the super light rim. And it is also why 20 hole wheels tend to be built on tall, 500g rims that are stiff enough to have large unsupported spans between spokes.
5. High tension spokes vary in tension less than low tension spokes per revolution. But they have a greater static load on themselves, which is its own source of wear. But low tension spokes get cycled much harder as they approach zero tension at times and then 'snap back' into tension.
6. The correct average tension per spoke needs to be based on both the spoke itself and the number of spokes being used. If you go to high tension on a light weight, 36 hole box rim, it will potato chip as you build it. Use the spoke count and the suggested tension range to suggest a reasonable spoke tension for the wheel you are building. Low count=higher tension, high count=lower tension in the range.
7. Nice rims are those that are extruded, pinned and machined so well that perfect straightness comes at very even tension. Less exacting rims require some spoke tension variation to force the rim into true. That's okay, as long as the tension variations are fairly smooth one spoke to the next. But it is sometimes better to accept a slightly less true wheel (especially near the seam) if you can keep tension more even.
8. Even cheap modern spokes are pretty reliable, and even cheap modern rims are straighter than older rims. So fairly modest wheels can last very well, if the deficits of machine building are addressed by seating the outside elbows and evening tension.
*Modern carbon rims have a tendency to break spokes on hidden nipple rims where the nipple enters the rim.
#57
I wrote that machine built wheels, gone over by the bike mechanic to address tension and seating, will be a good wheel. You ignored the "gone over" part, then kept ignoring that is what I was talking about despite pointing it out to you twice. A total knucklehead move.
The problem with you is that the shear volume of intellectual-adjacent stuff you write will suggest to people that your ridiculous points about tension, rim design, etc, might have some validity. And those unfortunates might act on that wise sounding advice, instead of using time tested advice from people with much more quality experience than you. Many of us learned wheel building from experts. You learned by trial and error, and you didn't learn what we have.
Of course you have a lot of experience with broken spokes. You aren't building wheels correctly, and you are too 'smart' to accept anyone else's suggestions as to why. Instead you think any wheel without oversized elbows is garbage. Redic.
#58
Broken spoke
hi,
I bought a bike from bikes direct and I am having some problems with the rear wheel. it seems after a few rides (not much mileage most from 6 - 10 miles)
I break a spoke and I find it a bit frustrating....
I looked on youtube so I fixed the previous broken spoke by measuring and ordering a set from amazon. was able to fix the spoke then did what I saw on youtube for
"stressing / destressing" the spokes by stressing them laterally, then truing the wheel.
so its been about 5 rides and just today I broke another spoke...
obviously, I need to fix the spoke but what can I do to prevent this problem from re-occurring?
additional information: the spokes break at the J bend...
which end did the spoke break…nipple or hub end? Makes a difference. Talk to a shop that has a wheel builder after you check. SS SPOKES only break if bent. Built many wheels with modern spokes and have NEVER broken a spoke even after a crash.
#59
His spoke broke on a heads out j bend.
#60
it broke at the hub end... the LBS mechanic is not good with wheels (as I have found through experience as my trek 7100 had similar problems...)
#61
broken spokes
Sorry, old school no experience with straight spoke builds only 3 or 4 cross. The tension on a straight spoke build is much greater than the X build. Usually custom spokes are required. My experience goes back to pre 1970's where the spokes were sub par because of manufacturing methods used. Good luck. Deanster04!
#62
#63
I was thinking when the wheel was built the spoke was bent enough to cause weakness. Check the tension on your spokes before you use the wheel. I have a couple of very old rims that are still aligned very well inspite of many miles. Machine built wheels can be a problem with an already defective spoke. I also noted that many wheels with straight spokes have lower counts so the tension is not distributed very well. I know that I have used and tried a variety of straight spoked wheels and always ended up with a sore butt...they look sexy but are a real pain in the ass. Although I have tried MANY configurations and bike materials I now use a steel frame form the 1980's. From a material perspective I like the Greg Lemond bikes built out of Reynolds 853 tubing so I'll probably look online for one of those bikes: Poprad steel (gravel XC) is the best. In my opinion...which is like an A**H*** everyone has one.
#64
spokes
Again no experience with carbon wheels...and don't expect to ever have any. I'm over 80 and still ride pretty old bikes at least 50 miles a week in the summer and when ever during the winter. Boulder is nice W.R.T. snow and cold. I also have a trainer set up in my basement that gets a workout. My gravel bike is a Ritchey Breakaway that has ridden many a pass in the Dolomites, French alps, and Spanish Par... Have slowed down but only a little. Bike riding is still the best exercise...Deanster04
#65
#66
Old fart
Liked 3,692 Times
#67
About 20% is the most commonly seen figure. My wheel guy gets it a lot closer than that, and even gives me a printout, probably generated from the Park Tool app.
#68
Liked 4,538 Times
Maybe - it depends on the application. If something just needs to be "tight enough to hold together but not to strip the bolts" then 16-24 may be perfectly fine. In that case we would refer to 20 foot-pounds as the nominal value, but the actual torque can be within 20% of that and still work for that use case. I might even be able to just use the torque setting on my cordless drill and that will be good enough. Other applications obviously require greater precision, along with a more accurate and precisely calibrated torque wrench.
Stuart Black
Stuart Black
#69
It's not just a wild-ass guess. 20% relative spoke tension is a fairly common standard. It's even the default in the Park Tool Wheel Tension App. I think we can agree that you'd like to come closer than that if possible, but that needs to be balanced with making the wheel true, so variance is acceptable and expected.
You seem to feel that 20% is too wide a variance. How close do you get on the wheels you build?
#70
Maybe you could. A lot of people claim they can do it by ear (plucking the spokes) or using a guitar tuning app. I don't know of any professional wheelbuilders that do it by squeezing or plucking though. Every one I've ever dealt with uses a real tensiometer.
#71
Liked 3,497 Times
Even tension wasn't an issue, because rims were much lighter, and it was difficult to build an aligned wheel with uneven tension. Some rims, including Fiamme Yellow Label, and Araya track rims were so aquirrely that the least error would show. Even with no conscious effort any decent builder was consistently producing tensions within 10% purely through good technique, and calibrated fingers.
When I started distributing Wheelsmith spokes sometime in the 80's I swiped a tensiomerer from stock, and still use it to check my "calibration" taking 3 readings off finished wheels.
Like other old tech builders, I still use my thumbnail and ears to confirm that tension is uniform.
#72
Allow me to.introduce myself. Built my first wheel in 1966. Built countless wheels since, mainly for racers and tourists. Before THE BOOK nobody had tensiometers. The only one around was the Hozan, which was only used as a QC tool in factories.
If I walk into a shop and their wheel guy says he doesn't own a tensiometer and just does it by ear or by feel, I'm not leaving my wheels with him.
#74
Liked 3,497 Times
Let's use pancakes as an analogy. Folks who don't know better end up with lumps in the batter that they need to work out. Experienced cooks know to stir in the liquid slowly, so they get smooth lump fee batter straight off. Saves time, effort, and because the batter isn't overworked, end up with lighter, fluffier pancakes.
So, I must travel in different circles than you, but none if the highly regarded builders I know use tensiometers for anything but final QC.
#75
Liked 4,538 Times
The other problem I have with that recommendation goes back to “all you need is tension” idea. Everyone assumes that the wheel build is bad and that the tension is uneven when spokes break. They never consider that the problem might be with the spokes themselves. My wheels have always been tight and even but even with double butted spokes, breakage was an issue. Going to a spoke with a heavier head stopped the breakage issue. I didn’t change the way I build wheels…they are all built tight and even. The only thing that changed was the spoke. For light riders, they may never break a spoke even on, admittedly, commonly badly build OEM wheels. Heavy riders will likely even break spokes on well built wheels.
Triple butted spokes fix the problem and prevent future problems. I have never been able to understand the resistance to this idea for heavier riders or heavily loaded bicycles.
Stuart Black
Stuart Black
