Flo 30 vs Boyd Vitesse
Thread Killer
Liked 1,931 Times
Thread Killer
Liked 1,931 Times
You know with each post you're pushing me closer to the Flo's - you have a good answer for everything. The only other concern I have is that they might be too wide - worried about rub. They're almost 26mm at the bottom of the brake track. It would suck if there was a fit issue.
It's that level of info that makes me want give their product a shot. They've really invested in their own designs, and are not just recycling off the shelf bits. That makes them kind of special in my mind. If that fires your sense of appreciation, too, that's great, but all credit is due to the Flo guys, none to me.
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Liked 142 Times
Well, head to head looks like this:
The FLO 30's are 1624g and the Vitesse (also 30mm) are 1550g. The new one from Boyd seems to be a few grams less.
They both use Sapim CX-Ray. Boyd seems to use Sapim SILS nipples as well, not sure on FLO.
The FLO hub is a pretty standard Taiwan hub. Certainly a good value and generally reliable (and EZO bearings). The BOYD hubs seem to have a lot more engineering going on and use Enduro bearings.
Both seem to offer excellent customer service.
FLO's are 'handbuilt' in Taiwan (that can mean machine laced and hand finished - make of that what you may). BOYD seems to fully hand build in the US.
The FLO 30's and the BOYD Vitesse wheels can both be purchased now. It seems like the other FLO wheels are only available as part of a pre-order?
I didn't check on shipping or warranty terms.
It looks like the Flo 30's are also part of the pre-order; clicking the "buy now" button redirects you to the pre-order sign up page.
Both Flo and Boyd have two year warranties although Flo does not have a crash replacement program while Boyd does.
Not sure about the shipping prices for Flo, but it looks like Boyd's standard shipping is $25 within the states.
Thread Killer
Liked 1,931 Times
Thread Killer
Liked 1,931 Times
The most important difference to me is the shape of the rims. I don't know which rim Boyd uses-- someone mentioned it's a Kinlin rebrand-- but it certainly seems that the Flo is a more aerodynamically advanced rim than the Vitesse rim.
According to Boyd, the Vitesse are 28mm tall x 23 wide (so shorter and narrower than Flo 30).
Thread Killer
Liked 1,931 Times
Yes, I saw the Altamont on your webpage, and it looks like a great wheel. Machined sidewalls, laser etched graphics...this thread really should be about Flo 30 vs. Boyd Altamont, but alas...!
Thread Killer
Liked 1,931 Times
CoachBoyd,
Not to start any trouble, and I don't know if you'd care to comment on this--- but it gets to the point that redlude97 brought up earlier about standard CX Rays-- but to look at a pic of the Altamont on the Bikerumor site, the non-aero section of the spoke at the nipple end looks quite long, perhaps even longer (given the nipple type) than the Flo spokes pictured upthread. Did you spec that particular dimension from Sapim, or do they offer multiple choices in that dimension?
The picture of the silver CX Ray spoke that was posted above is a stock image from Sapim. If you do a google image search for Sapim CX Ray you will see that same spoke pop up everywhere.
The actual spokes that get shipped to us are the standard CX Ray spoke (in black). They do have a longer round section below the threads that what is shown in the stock picture. This is for a couple reasons. The ends of each side of the spoke are thicker than the center piece to make the spokes stronger. A CX Ray is a flattened Laser spoke which is a standard round double butted spoke, so the thin part of the spoke gets flattened down and the thick part remains round.
By keeping a round section below the threads, it allows you to cut down the spokes if needed. We always order the correct size spokes for our wheels, but spokes can be cut down a little bit shorter if needed and if the correct size isn't available. So if you needed a size 276mm spoke but only had 280mm, you could cut and thread it down to 276mm and the threads would then be lower on the round section of the spoke.
Thread Killer
Liked 1,931 Times
Okay, thanks for the reply, Coach!
Thread Killer
Liked 1,931 Times
FLO30(coincidentally showing the uneven brake track wear)
FLo90
The non bladed section on the FLO90 is clearly 2-3" longer than the FLO30. So they don't use the same spokes as you claim.
Thread Killer
Liked 1,931 Times
Ah yes, I can see the difference between them. Thanks for clarifying that.
Bikes: Opus Vivace F1
Altamont - $857
Vitesse - $731
Flo 30 - $670
And yes, it's the US dollar surging - when I said $CAD tanking I meant relative to the greenback for this purchase.
check out https://www.hoopswheels.com/ also. Could go cheaper spokes to save some money.
Bikes: Trek 1.5, Scwinn Sporterra comp, Cannondale Synapse carbon
Decided to "go with the Flo" and ordered up a set of their 30's this morning. Good reviews, great info about their designs (as opposed to rebranding), plus great pricing all combined to make it a pretty easy choice. I thought the rush to order at a specified date/time might be a nightmare but it was smooth as silk.
Can't wait to get my hands on them!
Bikes: Trek CheckPoint SL7 AXS, Trek Emonda ALR AXS, Trek FX 5 Sport
Liked 2,067 Times
I just bought the Boyd Altamont and had my first ride on them today...35 miles and they felt superb. Spin quite well and my Vittoria tires mounted quite easily and look great on the bike. Taking a much longer ride on Saturday and will get a better feel for them then, but so far, very happy with the purchase. I'm 220, so I went with the 24/28 spoke count.
