Tubeless rims with no bead retention/bead trapping ledge
The OP appeared to be using the word ledge to refer to the raised beadlock, not the raised area that the bead seats over - which I called a "shelf". So the three sections you posted miss one that is between the first and second - having a center channel but not beadlock lip.
Likes For Kontact:
Liked 471 Times
front and
Yeah. I'm already eyeballing the Alexrims AT470. It seems to be the only silver rim with bead retention ledges. Still, there must be a LOT of you out there running tubeless on Velocity Quill and A23's, Pacenti, DT Swiss R460, etc rims with no bead retention. I can't be the only one who notices these things. How are the rest of you dealing with this issue?
My other road bike has tubeless Hutchinson 23 front and 28mm rear tires with DT Swiss R460 rims. Same story here, 2 layers of tubeless tape a few millimeters wider than the tubeless rim interior width is a best practice. The Secteur 28 rear is the only one that might require deflation before removing the wheel. I will pull the presta cores out for different reasons when doing wheel and tire preventative maintenance and sometimes due to rapid deflation, one of the beads will dismount. This usually won’t ruin your day though if you mount your tires with the valve cores out using the little high flow Adapter that comes in the box with the Airshot. If you have your presta core premounted in your core removal tool you can time it to where you let out the initial high pressure blast, push some sealant in with a Park Tools sealant syringe then reinsert the presta core in a workmanlike manner. Again, once re-inflated with the core in I usually overinflate for the first ride and the recheck pressures at the conclusion of the ride.
Likes For masi61:
