Fastest 35mm or 38mm tires
If I go with RH it will be the standard casing. I don’t want to push my luck, Good call.
Thread Killer
Liked 1,935 Times
What is “sidewall wear-out?” That’s not a thing I’ve ever heard of, so what are the symptoms and issues to do with sidewalls “wearing out?”
Advanced Slacker
Liked 2,574 Times
I imagine this is a rather unusual occurrence, but RH EL sidewalls are unusually thin. Like tissue paper thin.
If you ride with under-inflated RH tires, the sidewalls can collapse a bit when cornering, giving the tire a squirming sensation. It also damages the side-walls. This is visible, especially on the inside of the tire, and may make it more permeable to some sealants.
Thread Killer
Liked 1,935 Times
Likes For tFUnK:
Ah…underinflation damage. I was thinking that I’ve been riding Extralights the past couple-or-three seasons and haven’t seen any sidewall wear-out, but I definitely don’t ride them under-inflated, so maybe that’s it. I’ve been riding standard casing RH longer, and my 650b are kind of chronically underinflated since they’re tubeless and just don’t seal up all that great. They’ve got the heavier coated sidewalls, of course, but they look fine, although I’ve not pulled them to inspect inside,
Likes For Polaris OBark:
Liked 2,916 Times
Terra Speed roll surprisingly well on pavement and will be faster than your Terra Trail - knobs are smaller
Terra Speed will also weigh less - although difference might actually be minimal ... Terra Speed weights can vary in 40mm size especially - I have 40’s that weigh around 410g and other 40’s that weigh between 450-460g (black wall and cream wall) ... 40mm Terra Trails weighed around 470g
Terra Speed can run small - the 40’s measure around 38mm installed on my bikes ... the 35’s measure around 33mm ...
Terra Speed 35mm is lighter and might roll better than Terra Speed 40 - but the actual width might not be meet your requirements ... they are also not the most puncture resistant tire - but still a good notch above a GK slick (for example)
Veteran, Pacifist
Liked 5,975 Times
Likes For Wildwood:
The 700x38 Panaracer Gravel King Slick+ looks interesting also.
Likes For HTupolev:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Liked 460 Times
Yes, though $103/108 on BTD right now and 445grams.. And I love my 28 & 32c GP5000'S.
Would probably try the $48 35c Grand Prix Urban which are said to be the GP5000 in a 35c, and 335grams.
Liked 2,916 Times
GP Urban runs really small - I mounted one and pulled it off immediately after measuring it @ approx 31 mm
on a wider rim might be around 32-33 mm ?
unfortunate if the 35mm GP5K AS weighs 445 g - the GP4S weight penalty is not as significant (but 32mm is the max)
I too run Conti Terra Speeds. According to testing they're not the fastest tire in that category (still pretty high up there regardless) but I chose them because of the flawless tubeless implementation continental has. That in and on itself for me is worth the few extra watts.
When I use tubeless I use schwalbe or continental simply because they seem to have that stuff figured way better than anyone else.
Thread Killer
Liked 1,935 Times
I too am a Schwalbe fan, and although I probably won't bother to try Conti for a variety of reasons, I'm glad to hear that they've come from way behind and are finally doing tubeless at a high level.
don't try this at home.
I thought the Compass (now RH) Barlow Pass 38 ultralight were great. Fast on paved roads, plush on rough pavement. Perfect for crushed stone rail trails, where it efficiently floats on the surface of the trail. (There's very few gravel roads nearby to ride, so no review of that.)
But one tire developed a bulge. I don't think I ever hit anything with it to cause the failure.
Likes For prj71:
Liked 564 Times
Adding Schwalbe G-One to the mix. They came on a used bike that I purchased and fell pretty fast in a 35mm. I don't ride them because they're too narrow for me but there's no denying they're quick and grippy tires. For comparison, a new 35mm G-One felt faster and grippier than a worn 40mm Terra Speed (and you know how much I love the Terras).
Likes For Breadfan:
Likes For tFUnK:
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Liked 192 Times
This topic is relevant to me. I'm looking to put some faster, plusher, 36-38mm tubeless slicks on my commuter bike. I have some Rene Herse Snoqualmie Pass 44mm on my alternate gravel bike wheels. They are definitely nice tires, but they are pretty porous and seem to lose pressure all the time. Also (and this may seem dumb), but my commuter bike is "murdered out" in all black, as the kids say, so I don't want tan sidewalls. RH seems to only make blacks in the Extra Light casing, which seems like a bad choice for this application.
Any thoughts on the WTB Exposure 36mm? I have WTB Ventures on my gravel bike, and they have been great. But I've read some mixed reviews on the Exposures as tubeless. I also have Conti GP5000 TL on my road bike, and those have been great. Looking for good recs. Thanks.
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Liked 1,314 Times
