Handlebar Tape from the Top?
Bikes: Miyata 618 GT, Marinoni, Kestral 200, Soma double cross 2002 Trek 5200, KHS Flite, Koga Miyata, Schwinn Spitfire 5, Mondia Special, Univega Alpina, Miyata team Ti, Santa Cruz Highball, Waterford rs11
Liked 3,064 Times
https://www.amazon.com/Drain-Sealing...108349571&th=1
seņor miembro
Bikes: '70s - '80s Campagnolo
Liked 7,016 Times
It needn't look "ugly" if it's done with a bit of creativity and finesse. I cut mine to exactly 9mm in width and apply with the ends hidden at the bottom of the bar. I normally use the black finishing tape packaged with Fizik. It's much nicer than regular electrical tape. And, of course, I remove all labeling. But here, I wanted to use a bit of a contrasting color to match my toe clip straps, so I went with red electrical tape in two layers.
Liked 3,328 Times
I never knew this was a "thing" until I started looking at this forum. In 35 years, I've never once seen tape wound top to bottom until I saw it done here. Every description of how to tape bars I've ever seen or read through those years has never shown the tape started from the top. I've even seen people put finishing tape on the bar ends--which seems very odd to me. Considering, you know, bar plugs and all.
I once had a guy bring his '57 Chevy in to have the steering wheel wrapped. I'd never been in a '57 Chevy, and my mind was blown at how long the bench seat was! The passenger door was a mile away! Anyway, I don't remember whether I started at the top or the bottom...
As I noted, if one uses the entire bar in their riding, at some point, no matter which end you begin wrapping from, you are going to be pushing against an edge - unless, as one member has suggested in this thread, you wrap separately from the brake lever hoods.
DD
My bar tape wrapping preferences have never put me at a disadvantage.
Your results may vary.
Wrap on.
Wrap on.
Edumacator
Liked 3,597 Times
I have 13 flavors of electrical tape.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
I wrap my bars starting from the brake levers, up to the stem and down to the bar ends. Done it since the early 80's after having problems with catching the bar tape seams and eventually causing gaps on the wrap.
Never had the problem again after doing this method of bar wrapping.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Liked 498 Times
This is almost like an oil thread on a motorcycle forum. But I'll play.
I have wrapped top to bottom since 1970 on every bike I have owned but one. That one has foam based tape and bottom to top was the only way I could get it to look almost acceptable. Every other bike is cotton or cello. Just did one with cotton yesterday. Waiting for it to dry so it can be shellacked. I've never had a curling issue, either.
Liked 3,328 Times
Not true if wrapped properly.
seņor miembro
Liked 7,016 Times
I love how tight he pulls the tape. That's great. But he tapes outside-in. And he cuts off the tape at the lever, then begins again.
I tried twine once. And I've used embroidery thread a bunch. It always looks stylish to begin. But even if I cover it with shellac or clear nail polish, it always comes undone. And I feel myself consciously trying to avoid placing my hand there ever. So I'm back to just keeping it simple.
Dafuq you talking about - what is "wrapped properly"?
If you wrap starting from the bottom you expose the edges on the lower extensions and the drops. Duh. I think you just want to argue.
Hundreds of bars wrapped or not, it seems you don't pay much attention beyond what you want to see.
DD
DD
(This photo was taken just after I did it.)
Likes For P!N20:
elcraft
If it was good enough for Eddie, it was good enough for us
When Tressostar cloth tape was coolest, the standard seemed to be to tape from the top of the bars down to bar plugs ( No finishing tape was needed and any excess was tucked into the bars and secured with a bar end plug . The practical among us were advised to go with Black bar tape as it didnt reveal that you had to mess with your bicycle chain, during your ride. .The black tape became imbedded with dirt and grease. It developed a unique patina that spoke of long rides under less than perfect circumstances, A badge of honor of a sort .
my 75 Raleigh Super Course ( which I purchased new) has just such a patinated black Tressostar taping that is smooth and mildly shiny. They have been in place for better than 40 years. I have had a plan to install Kelly Take-Offs to create Brifters, but I havent been able to let go of this beautifully smooth and comfortable covering. It has an almost leather like quality- reminiscent of the one piece rubber coverings that were once found on Motobecane cycles of that era.
Likes For elcraft:
First time I ever had to wrap my own bar tape, bought it from the local Ames, I read the instructions which said to go from the top to the bottom, took two rides to determine this was a total failure and I've never done it again. Went to the LBS months later and sucked up riding a crap tape job till then, bought new tape, looked at the local bikes, went home and did it right. The difference was obvious. I've seen it work well with cello which I never understood the logic of, no grip, padding, or sweat absorption, and have seen it work moderately well with cloth. With modern tapes, just not the right way to go.
Liked 405 Times
I always thought it looked "neater", plus it's the way I was taught at Schwinn Service School in the Eighties.
Likes For Pogliaghi:
Liked 1,083 Times
Tape doesn’t move if you know what your doing.
Tim
Tim
Likes For tkamd73:
Mr. Fisher, slightly off topic, can you tell me what shade of yellow is used on your Colnago? I have one that's a similar color that I've been trying for years to get a match for touch up paint.
Thanks! Cheers, Glen
Strong Walker
Thin tape that grips on its entire underside like Tressoplast or Benotto tape can be wrapped top-botton for a nice looking upper end without crutches like electrical tape and it can be finished at the bottom end by fixing the overlap inside the bar with the plug.
Thick (cork type) tape from bottom to top. Only the middle of it is supported by sticky, so the edges would roll in the grip area. Also there is no way to wrap the end in an aesthetically pleasing way
Glen, unfortunately I don't know the exact color, as the bike came to me finished that way. I do plan on getting it matched for touch ups, but haven't gotten around to it yet.
Liked 3,328 Times
Some beautiful workmanship there, Bianchi84, Pogliaghi and tkamd73.
Depends on whether you live in the northern or southern hemisphere.
When I was riding / racing in the 70s, all my bars were wrapped top down. I had one set of bars (can't remember the brand) that had sort of a reinforced center where the stem attached. It had square edges that were, oddly enough, about the same thickness as wrapped bar tape (the cloth kind) so the top end of the tape was the same diameter as the center of the bars. Never once did I have any fraying or unwrapping of the tape.
The only reason I wrapped my current bike bottom up (with tape at the top, which I still think is ugly) is because I have a bar end Di2 junction, and it sort of requires taping in that manner.
