Group Advice
cyccommute, what is it about the higher line of shimano FD's that makes them useless or at least not as forgiving ? Is it simply the width of the cage ? I've never sat down with a mic and compared examples.
but we are talking touring here, so with any sort of touring load, and going from the short or long climbs I've been touring on for the last 30 years, my personal experience just doesnt fit with your comment.
but maybe you ride in more flattish areas or you're a tractor stump pulling sort of build guy.
Clark W. Griswold
Liked 4,292 Times
I agree that 1x isn’t difficult to figure out...I wasn’t saying otherwise. But 1x has other issues, most specifically a lack of range. You can go fast down hill and struggle to go up hill or you can ride up hill in a good gear and spend a lot of time coasting.
I don’t agree about SRAM front derailers, however. At least not for mountain bikes. From top to bottom of the line, SRAM X series works wonderfully. Same can’t be said for Shimano. Their XTR carbon fiber E-type derailer has to be the most useless expensive derailer around. If you had one, I can see why you wouldn’t want front derailers. Their expensive road and mountain derailers are about the same. When I have Shimano systems, I don’t go above Tiagra for road or above Deore for mountain. And, in mountain, I avoid using bottom swing as much as possible. Oddly enough, SRAM bottom swings work fairly well and are on the same par as SRAM’s top swing.
Maybe their MTB stuff is better for the front. I haven't really had many problems at the front with Shimano now I haven't used the E-type stuff at all personally but their road stuff is fantastic and haven't yet had issues mechanical or Di2. I do know people who have run the modern Shimano MTB stuff and haven't had issues but I have no personal usage as my MTB is 1x11 and a 3x9 vintage set up that I am working on.
To start, I have to say sorry for the thread hijack, cs1.
I mountain bike as well and I don’t see the appeal of 1x there. It’s okay if you ride loops around the bike park or if you are racing a circuit, I suppose. But I ride over long enough distances that having a wide range of gears is worth the (slight) complication of the triple.
So number one is the elimination of chain drops and chain slap. Clutch rear mechs are awesome but they don't work with front shifting. Also a big thing eliminating chain issues is the narrowide tooth profiling SRAM uses or the weird shape Shimano uses.
also since I ride trail I don't need the tighter road gearing a triple would give me. If I did fire road marathons tighter gearing would probably be handy. But for the typical up down of our trails the looser gearing is actually a benefit.
I have enough low range to go up a tree. With 500% I'd need to ride a seriously steep and straight road down to spin out. It has never happened on my mountain bike.
3x is more efficient but again efficiency is a road thing. Doesn't really matter much in mtb.
I once read something in Adventure Cycle magazine from the guy at SRAM who is the force behind going to 1x. He said that changing the chainwheel on a 1x completely changes the character of the bicycle. I fully agree. What if you carried along the chainrings and had the is nifty little device that switches between those chainrings? It would completely change the character of the bike. Why has no one invented such a system?
For quite a while, the only additional gears were on the high end. Thankfully the current trend is to add more low...and lower...end gears. That’s a plus but from what I’ve read, the longevity of 11 and 12 speed chains is greatly diminished.
Mad bike riding scientist
Liked 4,343 Times
The one mountain bike that has Shimano on it is in Tucson and I’ve had to replace a stick shifter...never had that problem with SRAM.
I’ve noticed similar differences in the mountain bike line. Shimano tried to be even more clever on mountain bike front derailers like the XTR with the inner and outer plate moving on the derailer. That one was a nightmare to get to work right.
Stuart Black
Stuart Black
Liked 4,343 Times
I guess it depends largely on what and how you ride. I see multiple positives with 1x on mountain bikes and no real negatives. But I ride almost solely trails so if I had a double or triple it'd be chain drop and slap galore as it was when I actually had a double. Even shadow mechs slap something horrible when the going gets even moderately fast.
I seldom see chain drop or chain slap when off-road. Avoiding chain drop is fairly easy. Just set up the derailer properly so that it doesn’t overshift. That’s something I learned how to do about 30 years ago. Chain slap is avoided by upshifting to the middle ring on downhills. That tightens up the chain and keeps the chain from slapping around. Again, something I learned 30 years ago.
Your statement about narrow wide does point out one of the problems with 1x. You have to do something to avoid chain drops as well. I don’t necessarily see that as a possitive.
I probably have a lower low than you do and a much higher high. I have a range of about 720% from around 15 gear inches to 100 gear inches (1.1 to 8.5 meters development). I have had ample places to use all of those gears on a single ride. I have spun out that 100 gear inches often. I do use my mountain bikes in a very wide range of conditions, however. Single track is nice and fun but there are other places here in Colorado where a mountain bike shines.
swapping chainrings is usually easier with 1x but it's still a chore.
I dunno. It seems to be a manufacturer thing rather than how many speeds. Some 9-speed chains wear significantly faster than some 12 speed chains and vice versa. Sram typically only lasts around 2000km's no matter shat speed.
Stuart Black
Stuart Black
come on a ride with me Papa and you'll get out of that mid ring.
However, riding in Western Canada with the Rocky Mountains etc... there are long stretches where I never get out of the granny gear. For example, there is a 60km sustained climb out of Hope towards Alison Pass in Manning Park. That's an all day uphill grind.
3x is more efficient but again efficiency is a road thing. Doesn't really matter much in mtb...
On the road, where I see 3x systems having the most benefit, is in the back and forth of rolling hill terrain where one spends enough time either going up or down to appreciate finding the best possible gear.
Liked 1,508 Times
Liked 1,508 Times
Do not get me wrong, I am a firm believer in triples, have triples on my rando bike and two touring bikes. And in some ways I prefer a wide spaced triple for a lot of things over an IGH. But, where you are shifting several times a minute, minute after minute, for hours, a single shifter is pretty nice to have.
I ride trails and long range off-road tours as well as often riding to trailheads. A triple isn’t an impediment off-road and offers speed both on- and off-trails. I have had places where I’ve done 30 mph on dirt roads and I can pedal most of the way to that 30 mph. There are places where I’ve done 15+ mile downhills and being able to pedal down those is far better than having to coast for that same distance.
You might wonder why I'm discussing downhillers. The reason is that you don't actually need all that much speed on a hardtail on any trail of even moderate difficulty to face the exact same issues downhillers face with significantly higher speeds on more difficult trails. You ride bumps fast enough your chain is flying off if you're using a double or triple. The beauty of clutch rear mechs is the fact that they don't actually move all that much when they're engaged. That in and on itself pretty much eliminates chain slap but then the narrow wide tooth profiling physically prevents the chain from flying off as the profiling holds the chain in place.
I don’t know why you think I have a tighter gearing on a mountain bike. I have 11-34 and 11-36 cassettes on my mountain bikes. I wouldn’t call that “narrow” nor “road gearing”.
My point is that I agree that changing chainrings completely changes the character of the bike. Carrying along the rings and having a mechanism for changing those rings on the fly does change the character. I can grind up one side of a hill and fly down the other. I hate to coast more than I have to.
I’m not sure what you are doing to your chains but I get closer to 5000 km (3500 miles) on 9 speed chains. I have a couple of 10 speed chains that seem to be lasting just fine as well. I don’t keep strict track of my chain wear but I don’t replace them all that often. I did do a mileage check on one 9 speed chain because I know when I had installed it and kept track. It was replaced at just about 3500 miles. 1500 miles of that was done on a mix of dirt roads and paved roads while on tour in the eastern US. It was certainly put through its paces as the hills there are short, steep, and mean. I did a lot of shifts over that 1500 miles and put a lot of stress on the chain.
Liked 4,343 Times
It’s the width between the cages and the width of the sculpting on the cages themselves. Both make for a narrower range of gears that can be used in the back without rubbing. I’ve had rubbing issues in the large ring and the 4th cog (from the inside) with Ultegra. They are more difficult to set up than the cheaper ones
Stuart Black
Stuart Black
just another gosling
Liked 2,006 Times
Nothing wrong with used on ebay if the item looks good and is returnable. I'm running quite a bit of 20 y.o. components, still work fine. That MTB stuff is well made and tough. I run 9 speed Shimano MTB RDs with Shimano road brifters, both 9 and 10 speed.
Results matter
Results matter
Liked 4,343 Times
To be clear, you need the triple to pedal down roads? I get that. However it really isn't a trail if you're able to pedal when going downhill. Except if there's a quick lull in action so to speak. 30mph on our trails would be a death sentence. Most I've ever managed has been 40km/h and that was with snow making gaining speed actually easier.
To be clear, the 30 mph downhills are on the road sections of my rides. I’m not shamed to say that I ride single track as well as dirt roads as well as gravel roads and even a few paved roads. Frankly, riding single track all the time bores me to death.
You must either be doing something revolutionary no one else has had the foresight to try or you must be using some revolutionary gear because that's not how front or rear mechs work in mountain biking. You can't avoid chain slap by just shifting to the middle ring. Not even the stiffer Shimano shadow rear mechs can avoid chain slap no matter what chainring you use. There are pretty good reasons why downhillers and the more rowdy mountain bikers still used chainstay protectors just a few years back. No need for that anymore with clutch rear mechs.
Downhillers have used chain guides for a long time because they do put more force on drops than most people do but the chain guide isn’t there to prevent chain slap but to prevent derailment.
Also on that point adjusting the front derailer doesn't matter when the chain physically lifts off the chainring due to momentum.
The narrow-wide chainring is needed on a 1x because there isn’t anything to keep the chain in place. On double and triple bikes, the front derailer acts like a chain guide and keeps the chain from being thrown off the ring. Without the narrow-wide ring, the 1x system tends to do just what you are claiming triples do...i.e. dropping the chain on impacts.
When talking about dropped chains, I thought you were talking about doing that during shifts. I’ve never had a chain fall off while on a downhill unless I’ve botched a shift.
I don't understand this statement. I'd get it if using narrow wide or other tooth profiles was a compromise or detriment of some kind. But to my understanding narrow wide doesn't have any negative effects at all. Using chain guide pulleys would add friction so that'd be a compromise.
I use 11-32 on road and 11-36 on my touring bike. I use 10-50 on my mountain bike so I do consider 11-34 to still be quite narrow. I've never understood anything below 11-28 if you don't live in flatlands or if your chainrings aren't particularly small.
I actually don't mind coasting in places where pedaling is impossible. But I hate collecting pieces of broken chains or fishing the chain from between chainrings or lifting the chain back to the chainrings mid ride even more than coasting.
With SRAM chains you only really need to ride them in perfect conditions and they'll last you 2000 klicks. I've had better luck with other brands. KMC and Shimano both make chains which last significantly longer and the PNY brand my LBS stocks seems to be nigh indestructible. I also have one wipperman that's been on my touring bike for a few years now and no noticeable wear yet. 11 speed chain that. My point was that in our household we have chains from 9 speed to 12 speed and the brand matters more in terms of durability than the speed count of the chains.
I don’t use Shimano because of their silly pin system but have used a few in the past. I have used a few KMC in the recent past on bikes that were used primarily for winter riding. None of them have worn faster than any other.
Stuart Black
Stuart Black
it is interesting to note how for some, shifting techniques , or perhaps I should say, "technical" aspects of it, come more naturally and instinctively. One of my kids surprised me very early on in her riding, where on a three day family tour, I noticed that she was instinctively upshifting one gear when going down to a smaller chainring at the start of climbs. I had never "taught" her that, but either from observation or simply having a good feel for things and using common sense, she figured it out on her own.
Other folks daydream and regularly don't know what ring they are in or whatever, and in the thread recently about 1x9 system, the european guy who was vigorously defending 1x systems at one point said something along the lines of "for the experts, shifting a triple is fine" (paraphrasing on my part) but it showed that for him or her, gear changing with a triple is a challenge, either with knowing what gear they are in or not doing it properly and causing chain drops (both things that they mentioned they suffered from and as negatives against triples).
so the whole "keeping chain tension" through proper rd tension, through proper chainring position, is something that for a lot of us, comes naturally and also comes from lots of riding practice and remembering/learning techniques to reduce chain slap etc.
Its not to say that gear advancements are bad, but for lots of us who have ridden a lot for a long time, this stuff is engrained pretty much.
I almost relate it to automobile ABS and Traction and Stability control stuff found on nearly all cars now. For those of us who grew up sliding cars or motorcycles around on dirt and snow, we had to develop and learn the techniques of "feel" for gear selection, front wheel direction, throttle control, braking control, how to hold a slide for a given surface traction and speed--basically a whole crapload of info that we learned, and some people had the aptitude for it, while most drivers/riders didnt.
Cue forward to computer driven safety controls, and hell, dont get me wrong, this stuff saves lives and damages up the ying-yang, and is nothing but good, but it is weird for those of us used to controlling and reacting to slides etc ourselves, and I always remember the first time going out in a car with stability control etc in a snowstorm and goofing around in a roundabout, purposely trying to put the car in to a long powered slide--and the stability control stuff of braking opposite corners and cutting the power even though I was deep in the throttle and countersteering by instinct, practically put the car off the road because it countered the big slide I had swung the car into, but my "old" reactions werent necessary and messed things up.
does all that relate to modern rd's ? Probably not, but I guess my examples are more to show that a triple can still be very useful and effective, moreso if one has the right techniques---but yes, technical advancements generally are successful because they are improvements, and thats great.
I guess all my blah blah is more as a defence for triples and their real world advantages for touring, while acknowledging that new stuff has a place too....
Liked 1,508 Times
I was still using friction downtube until 2004, shift front or rear but not simultaneously. When I built up an indexed shifting bike that was not downtube shifting, I was quite impressed with the concept that you could shift front and rear simultaneously. I often do that, but I have several bikes with different drivetrains so I have to think about it first, what works on one bike might not on another.
Width of the gap for the chain in front derailleur cages, I have often bent the cage to the width that I wanted it to be. That said, most of my bikes have friction front shifters, not indexed, so the precision of the front derailleur is not that critical. I have front derailleurs for a double on a couple of my bikes that have triple cranksets.
re shifting both simultaneously, I actually dont do both exactly at the same time, but with a slight slight delay. I used to shift dt shifters teh same, with my right hand doing both levers. Part of my hand would do the front downshift and then the other half of my hand would do the one or two upshifts at the rear.
I'd describe the two shifts as overlapping each other in a slight way.
with STI or trigger shifters, I do the same, shift the chainrings and then a fraction of a second later do the rears, to make sure that the chain tension is constant for the front shifting, which I find to be better overall.
but its all about timing with this sort of stuff isnt it?. Kinda like back in the day shifting a motorcycle on track without using the clutch, it was all about exact timing of backing off the full throttle for that fraction of a second, and timing both the upshift and back on the throttle again in a smooth yet super fast way.
and you aint gonna learn all this stuff or get good at it reading about it on the interwebs, you have to have a feel for it.
Liked 1,508 Times
And on my road bike with brifters front and rear, compact double (50/34), when I shift the front I often have to make at least two shifts in back, sometimes three.
Rando bike has brifter for rear, friction downtube for front, that one I always shift one at a time. I never got in the habit of shifting the brifter with the other hand off of the bars.
I always used the clutch, but I did not race. And with four speed transmissions and a very wide power band from about 3000 up to the horsepower rating at 7850, little need to shift often. (No published red line, so I treated the horsepower rating as the red line.) But if you were racing two strokes with narrow power bands, I can see lots of shifts and looking for ways to make them fast.
No real purpose for a triple any more.
The more expensive solution
12sp Campy Chorus 48/32 with an 11/34 cassette. If you're touring you never really needed the 53, racing sure, but getting a touring bike to the speed a 53/11 would give you just doesn't seem safe loaded down. While the 32/34 will math an old 30/28 or even 30/30 if that's what you had. Not too expensive if doing rim brakes, disc is affordable if you buy form Europe.
The cheap solution
You can buy individual microshift shifters.
so Microshift 110 right shifter, works with 11sp Shimano mtb rear derailleurs
pick any microshift double or triple, personally I'd go double,
FSA, Shimano GRX or While Industries sub-compact crank and go 48/32, let your budget decide.
Shimano GRX front derailleur
Shimano 11sp 11/34 cassette
For brakes I'd go trp hy/rd if disc since microshift doesn't offer hydraulic.
If you're really worried about gearing with the cheap option you could do a 46/30 or with the cheap option you can go 36t
The cheap solution
A 32x34 or 25.4 gear inches is often not a low enough gear for most mere mortals when fully loaded and having to deal with sharp inclines. You've either not toured under those conditions or you are an exceptionally strong rider. I'll presume the latter.
Liked 1,508 Times
If I tried to pedal with your suggested gearing up some of the shallower hills that I have often encountered on tours, my knees would hurt for months afterwards. Some of us carry our camping gear on our bikes, cooking gear, food, etc. This is the touring board.
I did a two week tour in Southern Florida, the only hills were approaches to bridges, that gearing would certainly work in much of Florida.
I toured Prince Edward Island with this gearing and while the trail wasn't too hard the hills off of it were rough but I was also towing a trailer since the 3 kids pack their own clothes, sleeping bags and eating equipment.
This year we're planning on doing the Erie canal with them but the two older can carry their own gear. The wife and I are also planning a cross Vermont gravel ride we found and I will be using that gearing for it. 4-5 days loaded. Plenty of climbing but I think my gearing should be sufficient for the task. Thankfully the in-laws will watch the kids since they haven't seen them in so long and the wife and I get some much needed alone time.
The OP is swapping from a campy triple. I don't believe in the past they offered a taller cog then a 28t, coupled with the small ring which was a 30? A 32/34 would be easier by a decent amount. The cheaper option did offer the possibilities of a 36, 38 and supposedly a 40. My current set-up is a 32/34.
I fully realize that until you've toured in very hilly or mountainous areas over many days, and or over many years, that you won't believe the thing about lower gears. The age thing is probably a factor, although to be frank, I figured out 30 years ago that the gearing that you have wasn't working for me. I'm sure if you tried touring in the Gaspe, or really anywhere with lots of either short, constant steep up and downs (the Pacific Coast lets say) or long long reasonably steep hills, you might acknowledge that 25 gear inches is too high.
and you know, the bottom line is that having lower gears has no downside, it doesnt affect or change your average speed, it doesnt change how fast you go downhills, and in fact it does help you overall day because you arent lugging your legs at times, so your legs and knees are fresher. And yes, it is possible to upshift....
really, it comes down to the whole "roadie view" and "take" of what is acceptable gearing, and the associated htfu view. Campy has such a road heritage that for years, even on their Tourismo or whatever it is model for years, they put road triples on them, ie 50/39/30
the whole "overgeared" thing is not new, and so many gravel bikes out there are overgeared too, so the issue hasn't changed that much over the years.
in the end, if your bike works for you and what you do, great. I would only suggest trying to look objectively at your gearing and wondering how it could be different to make your bike touring more enjoyable.
oh, and a big shout out to in-laws and taking kids off your hands for a bit. Super important isn't it. We certainly appreciated all those times that allowed us time to do stuff on our own.
Liked 1,508 Times
I have two touring bikes with Campy triples, the ones I have are the old square taper ones with a 74mm BCD for the granny gear. I fitted 24T granny gears to both. I also swapped out the 52T big ring for a 46T instead. On the second photo, the silver color granny gear makes it hard to see unless you look for it.
Both bikes have a 11/32 eight speed cassette in back, first bike is a 26 inch wheel, lowest gear is 19.2 gear inches with a 40mm wide tire, second bike is 700c, lowest gear is 20.7 gear inches with a 37mm wide tire.
RR, a 25 gear inch low that you have will show itself up to be not low enough as soon as you do some touring in hilly areas carrying a typical or average touring load, or even a lighter touring load.
The way I read it was that the OP in the past used Campy triples, but due to absurd prices does not want to buy another Campy triple. And I have observed how high the prices have shot for Campy triples, since I also have a preference for Campy triples.
I also enjoyed the Confederation Trail system on PEI, but that was pretty flat, low gearing not really needed. I had my Rohloff bike on that trip, not one of my derailleur bikes.
I've never run into a campy crank set up like yours, my old tandem has a similar setup but haven't seen that on a Campy touring bike which have been largely nonexistent since i started working in shops in the late 90s. Plenty of racing triples but that's all I was aware that was made. I was basing my options on what I presumed he must have a 30 chainring and usually a 28t max cog. If he's got lower like yours I haven't seen where he's said. In which case I'd still go the microshift option with mtb crank which could still be set up with a 44/28 and up to a 40t in the back. Although I wouldn't be happy to be limited to a 44, loaded its only on the downhills I would use a 44/11 and even then I limit myself to 30mph loaded anyways.
