Steel Bikes Under 20 lbs
Bikes: mid 1980s De Rosa SL, 1985 Tommasini Super Prestige all Campy SR, 1992 Paramount PDG Series 7, 1997 Lemond Zurich, 1998 Trek Y-foil, 2006 Schwinn Super Sport GS, 2006 Specialized Hardrock Sport
My Lemond Zurich, which is made of Reynolds 853 with a CF fork and is 53.5cm size, and has an Ideale 80 saddle, weighs 20.5 lbs with a good clincher wheel set and not much else in the way of ultra-light components (It's all Shimano 600 tricolor). If I replaced the stem, bars, and seatpost with CF, and put a lighter saddle and lighter pedals and lighter tires on it, I could knock nearly two pounds off of it and get it under 19 lbs pretty easily - but I don't think that would be worth the money, and I prefer the leather saddle for comfort.
Disco Infiltrator
Liked 2,118 Times
Reading the article, these were very much weight-weenie bikes, every component cut away to its bare functional minimum. The middle of the pedal body between the bearings was cut off, the inside and outside held together by the cage! Jeez. Check out the weird brake levers, too.
Genesis 49:16-17
Genesis 49:16-17
Liked 5,454 Times
Liked 2,646 Times
I'm pretty sure [MENTION=63590]jyl[/MENTION] has at least one.
I have had enough grief making my old and older Cannondales to weigh 20 lb. or less with clinchers. I can also make my 20 lb. '99 CAAD3 triple lighter if I move the wheel set from the 3.0 onto it, but then neither bike is built as I want.
Brad
IMO weight should include pedals and all normal running gear except accessories (water bottles, pumps, racks, etc.) Bottle cages I could go either way on, but they don't weigh much. However, the standard these days seems to be not to include pedals, presumably because bikes don't come with pedals anymore and customers choose their own. It's also a good way for the manufacturers to make their bikes seem lighter...
Anyhow, 20 pound steel bike was about normal for a good racing bike frankly. My Masi with race wheels was just over 20 lbs with no weight weenie parts. Subtract one pound for pedals and that makes it around 19.5 ish lbs by modern standards. It was a special edition with Columbus SL instead of 531 so perhaps it was a bit lighter than some. As normally ridden with 350g training rims it was/is ~21 lb.
I once had an 18.5 lb Mondia, including pedals! It was made up entirely with 70's tech. Frame was that superlight paper thin Reynolds 531. Jubilee derailleurs. The rest of it was 2nd generation Dura Ace. I wasn't trying for a super light bike and none of the components were particularly weight weenie. It just sort of happened. Tubular wheels of course. It was kind of whippy for me but worked well for the smaller person I sold it to.
As someone who rides a 64 cm bike (and whose weight requires more than minimalist tubing), I doubt my ass will ever grace the saddle of a sub 20 lb steel bike.
Liked 2,646 Times
I like [MENTION=190364]lostarchitect[/MENTION]'s criterion for weighing a bike. It should be ready to ride (with pedals, bottle cages, etc) but with nothing on it that's not bolted on, so it excludes bags that strap on and bottles that insert into cages.
Decrepit Member
61cm 953 frame, 531 fork blades, one water bottle cage, 20.28 pounds.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Liked 33 Times
My method is everything to make it a rider except bottles, pump, and seat bag. My touring bikes do have the rear rack installed.
Brad
Brad
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Liked 8 Times
One question I have, are tubular wheels still significantly lighter than clinchers? I had thought with modern materials and different manufacturing techniques now that they weighed pretty close to each other. Or is that not true?
Oh and are sew-ups still used extensively - for instance are the Tour De France riders all on them?
Liked 2,646 Times
Liked 8 Times
Yeah I've noticed that, on CL it seems like you can buy nice older tubular wheel sets pretty cheap compared to nice clincher sets. I used to ride on them myself in the late 70's but have no desire to anymore, lol. I'd probably pick up a nice set though as a 2nd set for riding if I ran into some amazing deal.
At least that seems to be the majority way to do it. Off topic but on the other hand, and probably best for another thread.... I have Italian frames marked CTC of top tube, I have American marked CTT (of seat tube). But I am pretty sure I also see some that seem quote CTT being the top of top tube. And many state size without clarifying which they are referring to.
Señor Member
Liked 1,146 Times
Scooper's bike's saddle makes me think of, "The Wizard of Oz" :haha:
I haven't weighed it, but I'm pretty sure my Bob Jackson weighs a shade under 20 pounds. The Team Pro did when I had it built as a fixed-gear, but that isn't in the cards for that machine.
RE Bob Griffin
Here is my 1985 Bob Griffin weighs in at around 19lbs though I have had it just under 19lbs
Small handbuilt Time Trial Frame Reynolds 531 Pro about 52/53 CM fairly short wheelbase
Mavic GL330 rims with lightish tubs on and Campag Record Hubs
Rest of Groupset Campagnolo GS or Record, what really helps with the weight is the alloy 13-18 Maillard block.
Lack of Chrome and small frame really keeps the weight down, have some lighter tubs to go on it which should save 100+ gramms !!
I've had one steel bike under 20, my Strawberry custom. What I've discovered, though, is a pound or 4 here or there has no impact on how well a bike rides, how light it feels on the road or how well it climbs, so I stopped worrying about it. I've had light bikes that felt dead and slow and heavy ones that felt quick and light. About the only time I can tell the difference in weight is when carrying a bike up the stairs. Other than that weight has become my last priority. If you want to do it as a fun project, go for it, though. Weight weenie parts tend to look cool, anyway.
1949 Viscontea Pista - 18.9
Viscontea 001 by iabisdb, on Flickr
2009 Cinelli XCR - 15.5
_MG_8967 by iabisdb, on Flickr
My Merckx is 19.9lbs ready to ride. Columbus SL. I got there with modern components. I have alloy Athena, if I went carbon I could be even lighter. I'll be buying a 0 degree Thompson stem soon. This is all I had at the time and -17 degrees didn't work for me so it's ugly for now
My Ironman is 21.8 with the frame pump and all. If I cared I could get it under 20 pretty easily.
Liked 5,454 Times
So, I was curious. Just got home and put the Giordana XL Super on the scale. 20 lbs 8 ozs without any attempt (yet) at weight reduction. Excel Podium steel frame with a steel Excel Eco fork, heavy Miche hubbed wheels laced at 32 spokes to Open Pro rims and mounted with GP 4000s II tires. Basic Look Keo pedals, Origin 8 pump, two bottle cages, garmin computer mount, and two garmin sensors. The only thing not on it from how I ride it is the kit bag and bottles. This thing will easily be under 20 lbs when the Campagnolo Shamal wheels ever show up (Probikekit is so slow to get product from compared to Merlins).
Pretty much just like this with the Garmin stuff and pump added and the saddle bag gone.
Built with a 11 speed Campagnolo Athena Groupset. 56 CM bike
A total joy to ride as you see it.
By comparision this is the "more modern" steel bike with a wheelset about a pound lighter than the Giordana's and a carbon fiber fork instead of steel. The frame is a 53 cm made from Reynolds 853 in the main triangle and something else in the rest. This too weighed with pedals, saddle, pump, bottle cages, sensors, etc. This is a mismatch of Dura Ace/Ultegra 9 speed stuff with a Wickwerks 53/34 (yeah that's right 53/34 and it shifts like a dream!!) chain ring setup.
19 lbs 14 ozs
19 lbs 14 ozs
Steel is real...and comfy.
Liked 5,454 Times
That's crazy cool for such a large frame!
