Is my sleeping bag not good enough?
Bikes: Yes
Liked 1,692 Times
IF you go buy a new bag you'll notice they are all rated using the European 'EN" rating system. The mftrs usually like to give you the lower threshold rating, and a comfort rating; the lower threshold should be interpreted as a 'survivability' rating as you'll still be cold in those lower temps, so use the more-conservative 'comfort' rating. Personaly I'd add 10 degrees more to the comfort rating since I believe todays' mftrs are not above cheating on ratings.
Also look at a bag's girth at the shoulders/hips/and feet. A lot of mftr make /minimalist' bags today, and one of the ways they cut weight is to make them skinnier. If you're don't have a 'beanpole' body, but something a little bulkier, you'll just crush the insulation. Get a bag that's as wide as you, maybe even a little wider so you can wear clothes inside if the temps get a little too cold.
Foods to eat. When I was mountain climbing it usually proved advantageous to mix pepper, curry, or other hot-spicy condiments into meals to keep the body warm at night.
Good bags are expensive, but that up-front expense usually means you get a quality bag that'll last many years with the right care.
Occam's Rotor
Four layers for "lounging" around camp; two long sleeve Ts, light fleece and lightweight insulated jacket
My wife dressed for working on her Journal in the evening. Point is: bring some warm clothes, and hope you don't need them.
It is a great ride!
Good luck.
If you put it in a compression sack why would they give you a swap for something you did? Is your sleeping bag synthetic or down?
Compression sacks. The black bag and the blue bag are my sleeping bags in compression sacks the green bag is the tent in a compression sack.
I doubt it's ruined, but if it is, why would you ask them for a refund/swap if you broke it? ...Anyway, my guess is your sleep pad is the problem. You want something insulated if sleeping in that temp range. It'll make a huge difference. I went from being cold at 40 degrees F on a cheap thing pad, to being OK at 32 degrees F on my Klymit insulated Static V with wearing less clothes.
