Post your TT bike
#451
Resident Alien
Yep. Tube stock bent on a hydraulic bender...I made several sets with different bends to run in the tunnel. Also did a set for my pursuit bike where I flattened/ovalized the area around the hand grips to make things narrow while still allowing a full circle grip. Couldn't do that on these because of the shifters.
#452
#454
Resident Alien
#458
![Roll Eyes (Sarcastic)](https://www.bikeforums.net/images/smilies/rolleyes.gif)
So...where did you order the 6061-T(4?) from? Aircraft Spruce or something? Did you re-heat treat it after bending?
#459
Resident Alien
Fixed.
Discount Steel. You can probably find a local source and save shipping, check out metal salvage places who do retail.
No heat treating, it's a bit of a dual edged sword for this application...if you could get a good mandrel bend it might be worth it, I'm trying to find a local source who can do those bends.
Corrosion at the fastener interface is a bit more of a concern given the amount of sweat that pours off in a summer Texas TT...I've tried to minimize direct contact and designed some bits to both stiffen the bars and act as (hopefully) a poor man's sacrificial anode.
#461
Resident Alien
#462
Quarq shill
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
New build. I needed something different, and this frameset came up for extremely cheap, so I picked it up. Seems decent enough for now.
![](https://i5.photobucket.com/albums/y163/cslone/DSCF1379.jpg)
#465
Ninja don't wear flipflop
Bikes: Specialized S-Works Roubaix SL3, BMC TM01...if it every ships
Fixed.
#468
Resident Alien
#470
Old & Getting Older Racer
Bikes: Bicycle Transportation: 2022 Hyundai Kona Electric, 2019 Kia Niro Plug-In Hybrid
Liked 11 Times
Hi,
Another update to my TT bike:
![](https://www.pbase.com/cleavel/image/134929686/original.jpg)
Derailleurs and brakes are now Record (taken off of my Serotta) instead of Chorus and the crank is now Record Ultra Torque (from ebay). Bars are now 3:1 legal (Easton Attack) just in case I decide to go to Bend, OR this summer for Masters Nationals.
Upcoming goals are PR at District TT Championships and medal in TTT championships.
Thanks.
Cleave
"Real men still wear pink."
Visit my blog at https://cleavesblant.wordpress.com/
Lightning Velo Cycling Club: https://www.lightningvelo.org/
Learn about our Green Dream Home at https://www.lawville.org/
Thanks.
Cleave
#471
Moving to a setback position to fix some power problems. This bike had the biggest range of adjustment so it is my rig until I nail down my geometry.
![](https://i233.photobucket.com/albums/ee312/king-tony/slicebuildcomplete002.jpg)
My slightly narcissistic and rarely updated blog can be found here
#473
Are you with me
Bikes: Giant TCR Advanced SL, Blue T-14 TT bike
Love the Slice. Curious about your power problems. Were you too scrunched up and therefore getting a drop in expected power? Personally, I found that an extreme upturn in my aerobars was sapping power. I went to the upturn to close the gap between head and hands, but was shocked at how much more comfortable I was when I brought the aerobars back down to a more level position.
