ISO and for trade thread part 5
Likes For Insidious C.:
#4128
Liked 930 Times
I don't think you're going to be able to find one easily without purchasing a derailleur that has one. I have fixed two of these using either a ball bearing or JB Weld in my Victory derailleurs. Hopefully you kept the broken piece and you can do some metalwork to get it back together.
Cheers
Likes For RustyJames:
#4130
Bikes: 1971 Gitane TDF, 1974 Gitane Interclub, 2001 Serotta Rapid Tour CS3, 1986 Bruce Gordon touring bike, 1972 Gitane Super Corsa, 1978 Michal Johnson, 1972 Lambert Professional Grand Prix, 1983 Vitus (resto project), 1972 Raleigh Professional (resto)
Liked 34 Times
Badly Gouged My Simplex Super LJ Inner Cage!
On a gravel ride last summer, I broke the Sugino chain ring off the drive-side crank which threw my beloved Super LJ rear derailleur into the freewheel! I had been using this faithful rd since 1984 and after this awful accident, I vowed that I would somehow, someway restore it back to working condition. I have scoured Simplex Super LJ parts on eBay and other sites since then without any success. Hopefully somebody on the BF either has a replacement part (inner cage) or maybe an older Super LJ rd (5500 CP/SP) carcass that could be cannibalized. Please see photos below.
Of course, happy to reimburse and pay for shipping or if you are looking for a part to swap, I could check my stash.
Thanks in advance!
Thanks in advance!
#4131
Old fart
Liked 3,484 Times
If you can bear the indignity, I suspect cage pieces from lesser Simplex mechs could be swapped in to replace the damaged piece.
Likes For JohnDThompson:
#4132
Liked 930 Times
Thanks. Finally got a decent internet connection and was able to order these today.
https://www.ebay.com/itm/29241962440...oAAOSwf15aZgKz
Cheers
Cheers
#4133
Prince of the Royal City
Cheers
Cheers
#4134
Liked 930 Times
Anyone here need/want the six cogs from a Regina ORO freewheel? It's the type with the two recess for a freewheel removal tool. Unfortunately, mine sheared when I went to remove it from the wheel. Therefore I took the freewheel apart to get it off the wheel. The locking ring was cracked at one of the dimples too and on of t he four pawls is missing along with whatever was used as springs for the pawls. The teeth of the cogs look to be in good shape.
Cheers
Cheers
#4135
Re: Regina cogs.
You might check with pastorbobnlnh
He has use of them. I would defer to him.
If he does not want them I will most certainly be interested.
#4136
Flying G -
Try Wayne Bingham at Velo Classique : veloclassique@gmail.com He has Simplex parts available, hopefully, including an inner cage. [MENTION=136325]surfer[/MENTION] Rosa's JB weld idea is certainly good. Alternatively, try this which dries metallic grey and is sandable: https://www.amazon.com/Hy-Poxy-H-450...8974762&sr=8-3
#4137
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Liked 108 Times
ISO a pair of Mafac Racer brake shoes (pad condition doesn't matter)
#4139
Liked 34 Times
#4140
Liked 34 Times
Good idea! Never worked with JB Weld before but this could be a solution if I can’t find a replacement piece.
#4142
Liked 34 Times
Flying G -
#4143
Old fart
Liked 3,484 Times
#4144
Flying G -
If Wayne cannot supply an alloy cage plate, I have a chrome steel one off of an LJ 1000 which is identical to the 5500 in configuration. Let me know and I will post it to you. (I checked it against my own LJ 5500 and it's a perfect match.)
#4145
Bikes: A few too many
Liked 2,194 Times
If you are doing the repair for cosmetic purposes the JB will work....strength wise, perhaps a better solution would be a new cage, you don't need to drop the chain into the wheel.
JM2c's, Ben
Voltaire
Voltaire
#4146
Continuing the rd cage follies…
ISO: Suntour GT rd cage compatible with a first gen Cyclone unit. The upper pulley and circular nut would be helpful too, but I think I can make do without them.
HAVE: Lots o’ bike junk, dry goods, karma…
#4147
Liked 2,267 Times
[MENTION=377727]Miele Man[/MENTION] - did you find a solution? There are a number of Victory RDs on the bay with the same part, IIRC.
#4148
Liked 2,267 Times
ISO 9v Chorus or Record right Ergo. Don't really care about condition as I have an a complete 10v that just needs the part for 9v.
I have nearly everything else to complete the upgrade except a lock washer for the cassette. Oh I need that too but don't know which one, if there is a difference, for the TI cassette hub.
PM me or @ me so I know there is a response, please!
#4150
Liked 3,798 Times
ISO:
Problem Solvers Cable Doubler BR3342: 2:1 Two Levers for One Brake
or
JTEK Double Control Brake Cable Splitter (Short Pull)
or
