Swift folders
#3801
Bikes: Rodriguez Phinney Ridge, Rodriguez fillet brazed tandem, rotating cast of projects
Broken Rear Derailleur Hanger
So my beloved Xootr Swift has suffered a broken rear derailleur hanger. Tried to fix it but I'm out of luck- its not repairable.
Unfortunately, it looks like this is one of the few customized parts and Xootr dont seem to list them anymore (I wrote to them so hoping they have a few left over).
Does anyone have any suggestions on alternatives- I am hoping that there is a similar design somewhere out there I can use?
If I cant get a replacement hanger then I think my only alternatives are to switch to a single speed, go for an IGH or retire the bike- and I am really hoping that is not the case!
#3803
#3804
#3805
If by some chance Xootr doesn't have one you can also contact Swift Folders and see if they have something for you.
swiftfolders@gmail.com
I have emailed Peter Reich about another matter and he responded quickly and was helpful.
Also if that doesn't work, check out this website and look for a match. It may take awhile.
https://derailleurhanger.com/shop/?pageloop=5000
Also possibly Xootr could recommend a match from that website.
Joseph
Joseph
#3806
![](https://www.xootr.com/graphics/swift/partsAccessories/replacementParts/derailleurHangerMobile.jpg)
#3807
To follow up on the derailleur hanger question - Xootr confirmed that they no longer have them and Peter Reich wrote to say he had a few spares which can be had for $9.50 (Design Mobility, Inc., 280 Nevins St., Brooklyn, NY 11217).
#3808
Bikes: 84 Trek 720, 86 Univega Gran Sprint, 65 Rudge De-luxe, 90s Schwinn Le Tour
New build for black aluminum frame
Here is the build I’m considering. I like James Black’s bikes and want a similar take but with the addition of three speeds.
I’ll be riding it around town and for light weekend trips.
Please weigh in if anything jumps out as problematic, or a missed opportunity.
Comes with frame:
Shimano cartridge BB
Aluminum seatpost
Aluminum steerer tube
To buy (through Peter if he can source it):
Sugino single crankset 170 mm
Sugino chain ring 42t
Shimano Nexus 3-speed hub
Sturmey Archer SLS30 index thumb shifter
Sun CR-18 36 hole rims, satin
DT stainless spokes
Deore front hub, silver
Sugino cantilever brakes, silver
Sugino mountain brake levers, black/silver
Aheadset, silver
Black cable housing
Panaracer HP406 20 x1.75 black/gum tires
MKS AR2 quick release pedals, black
Parts I have and might recycle:
Raleigh "North Road" or GB Maes bars both 25.4
(drops would require road levers)
GB 110mm or Nitto Technomic 130mm stem
Avocet touring saddle
Comes with frame:
Aluminum seatpost
DT stainless spokes
Aheadset, silver
Black cable housing
#3809
Questions for my new build
1. What do you do for a lighting generator?
Peter cautioned against a dynohub to maintain easy front wheel removal for packing.
2. How do I choose gearing for a new internal 3-speed hub and cog combinations on a bike I’ve never ridden? I have a Rudge w Sturmey Archer 3-speed and love the spread.
#3810
I would use Sheldon Browns gear inch calculator. For example with a 52 tooth chainring, and a 13 tooth sprocket you get 56, 74.7 and 99.6 gear inches.plug in what you like and adjust the ride for your locale, i.e. hills, your strength, distance ridden and headwinds for example. I would stick with v-brakes because they are light and work very well. I like bullhorns because they are light and give me the the handshake position I find most confortable. I like to be able to rotate the bars, or bullhorns with the bar ends up so the bike rests on the saddle and bar tips when upside down because I have found it m!uch easier to remove and install the rear wheel when the bike is upside down. Drop bars are good too if that is your preference. Stturmey Archer makes a very nice bar end shifter, BTW. I replaced my QRs on seatpost and stem with bolts because I don't fold the bike very often. If you read the this thread you will find that with aluminum Swifts the chainstays and seatpost arrangement is where they can fail.
#3811
So V brakes are really that great? I’ve never used them. All my bikes are CV and they stop okay. But I believe you!
Anyone have a strong opinion about diacompe / tektro / cane creek drop bar levers for V brakes? I’ve read mediocre reviews.
Unfortunate, about the frame failure related to QR for folding.
#3812
V brakes work well for me, and they're easy to set up and adjust. The nice thing about them is that they don't stick out far past the frame. If you're talking to Peter, I'd be curious to know what his experience with cantilevers has been.
I've had a set of the Tektro long pull road levers on a Xootr Swift I ride through the winter; I haven't had any problems, and they've held up well. I like the comfort of the SRAM levers on my other bike better, but the Tektro's aren't bad.
#3813
I don't see how Trocadile got that much of an ergon grip on the right handlebar with the grip shift and brake. Are those cut down or are they the grip shift model?
#3814
yes, a saw was involved (so it really doesn't matter if you use the grip shift model since either version would need to be cut with the stock shifter and handlebars)
#3815
Bikes: Santana Sovereign Tandem, Five Rings Carbon, Lemond Alpe d'Huez, Miele Latina, Hercules Tourist, Mercian Super Tourist Tandem, Birdy BD-1, Duell Solo, Jack Taylor Marathon Tandem, Raleigh RSW-16, DL-1, and Superbe
Liked 244 Times
Love, love, love this bike. The stiff aluminum frame is a huge plus when towing a trailer... especially when that trailer is loaded up with a heavy load of freshly brewed beer, straight from the brewery!
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1024x768/42449872022_d4c492a56d_b_b5ead6a9385730fc3ac7d4d162e44999f8f6d8ad.jpg)
#3816
Bikes: Brompton & Thorn Sherpa Mk3
Does anyone have a front derailleur adapter that you woudl be willing to part from? Or willing to trace it on a piece of paper and send me a picture and I'll make my own.
And picture on how my Xootr looked for many years.
https://imgur.com/a/KaUpv0o
Fixed gear when I was younger. Now it has drop bars and gears. Getting older I think I could use a front derailleur as well.
#3817
I am curious to see how my fellow swifties are doing.
I am thinking of buying a stock seatpost, stock stem, ditching my rack, and getting a friction shifter.
And other suggestions?
#3818
I’m using the stock seatpost and longer stem, no rack (use a bar bag) and replaced the grip shifter with a SRAM trigger shifter so I could use longer grips. Works fo me.
#3820
Just hit 2k miles for the yr and 9k for 2 yrs.
I've owned lot's of bikes and this is one of my all time favorites.
#3821
Swift: Electric mid-drive, it will work but just affect the fold?
Hello, I believe I've read most if not all of this thread! Somewhere in here I saw mention like "too bad it can't take a mid-drive"... [Swift]. I'm a few months into owning a used Xootr Swift [loving it], looking and thinking things over it would seem the bike could take a mid-drive you'd just lose some of the folding range? I've never messed with an e-bike of any kind but have done a lot of reading/looking/planning. From what I can tell, this would seem to be the case, am I missing something?
The full fold is great for tucking in the back corner of my minivan but in general all I ask of a folder [as far as collapsing goes] is to have 20" wheels, handlebars that can quick release turn sideways, and folding pedals. Looking ahead, thinking maybe having 2 Xootr Swifts, keep one in the back of my van and a second with a mid-drive could easily be kept in my apartment unfolded.
thanks
thanks
#3823
You can get the titanium version from Titan Cycles TITANcycles | custom titanium bike frames, forks and parts
Jur arranged for them to make some Swift design frames from titanium and they are still selling them. Peter Reich gave permission for a few frame runs... I’m not sure if they still have his blessing to be doing so but they still are at any rate. It’ll be expensive.
A Bike Friday stem may work. They make a custom stem riser for there folding bikes which also use a standard sized fork steerer tube so might fit. I can’t say for sure.
Someone posted a Swift that had a aluminum stem riser a little while back. It was listed as a Bacchetta riser which is a recumbent bicycle brand. Looks like they are available here https://www.bacchettabikes.com/produ...ce-system-swb/ for $40.
I have wondered before if a Bike Friday or Dahon riser would work on a Swift to give it a folding riser that would stay attached instead of coming off and just dangling.
Last edited by iamdougsbike; 09-03-18 at 08:02 PM. Reason: Found aluminum version...
#3824
The front wheel has standard 100mm spacing like a road bike, the rear is 130mm I believe but also will take 135mm hubs so maybe it’s 132.5mm...
I bought a Clix Quick Release Front Skewer from https://www.clearybikes.com/collecti...e-front-skewer and it’s a huge improvement on making it easier to remove the wheel. Kind of the opposite of what your going for though.
#3825
