2021 Post your Single Speed and Fixed Gear Thread
#326
Beausage is Beautiful
Bikes: Nabiis Alchemy
Liked 13 Times
The adapter clamps onto the chainstays and lets you mount a direct-mount brake there. I don’t have it set up all that well yet, as this is my first time dealing with this kind of brake, but it’s already better than my old brake and the bike looks cleaner now. I don’t use the back brake much at all, but both brakes are required by law here, so I figure if I have to have it, might as well make it a good one.
Yo. Everything I’m doing is linked on What’s up with Dave? but most of note currently is Somewhere in Japan.
#327
Sure thing!
#328
Liked 13 Times
Made locally in Nagano, they make a number of adapters and things like that, including a few brake mounts specifically for track bikes.
Likes For Edward1066:
#330
It's the little things
Bikes: Too many, yet not enough
Liked 335 Times
Done!
Will get final weight. Will be in the 21.5ish rate I think with Brooks. With higher end/lighter tires and tubes could probably shave a couple hundred grams.
One time owned by Martin Copland who was a Scottish grass path (track) racer of some clout. From my internet sleuthing, was able to determine it came to Chicago area about 15 years ago. Passed some hands, got to me. Not 💯 period correct, but is 100% functional, rideable, and perfect for me. Just sharing what I have info wise, for future reference and documentation. Frame repaired at some point near seat post binder. Has support bands which make max seatpost 26.7, originally would have been 27.2.
- 1969(?) Carlton Flyer RT model (drilled for front brake) this is purely speculation on year and model. Frame bare is approx 2180 grams, fork approx 790 grams. 60 c-t seat tube x 57 c-c top tube.
- Tange headset- campy bottom bracket (114mm iso, perfect chain line)
- GB bars (map) and stem- generic seatpost and saddle clamp
- Stronglight 49d crankset
- TA chainring (looking for criterium/track adaptor for all you hoarders who have one)
- Brooks swallow
- Milwaukee Bicycle Co hubs laced to mavic open elite (I know, but close enough from 10 feet)
- Continental Grand Prix classic 700x25
- VO cotton bar tape, over Fizik 2mm gel pads- Velox wood plugs, Velox classic (washer) didn't fit, will replace when I get washer solution figured out- Weinmann 500 caliper (NOS)
- Weinmann lever w/Carlton hood
- MKS Sylvan touring pedals and cages w/custom toe straps
I think that's it. Will post better pics when I'm out and about with DSLR. Nursing a separation of the AC joint, so no riding for now.
Riding impressions: fairly light, tracks well. Some BB/stay flex when climbing, but I'm also a large man. Relaxed enough for 30 mile FG rides. Could probably fit smaller measuring 28mm in front, maybe 30mm in rear. Too much into it money wise, but happy where it is.
- Brooks swallow
Likes For Senrab62:
Likes For nel e nel:
#332
Made a few changes to the Trek build - a pair of silver A23/Formulas, proper cable clamps, and some grips that better matched the Brooks. Also swapped out the black chain ring to keep the all silver component theme going. Just have to install the new brakes when they arrive next week, then the VO headset I've been too lazy to bother with, and I think I might be done. At least for a while.
I love what you did with the Trek. I just purchased a mostly stock 1980 Peugeot Competition PKN10E in hopes of converting to a SS city errand cruiser, and this really resonates with the look I'm going for. May I ask what bar-stem combo you went with, and how wide you were able to go on the 700s?
Likes For JJ Mango:
#333
Dedicated Detritus Dodger
Bikes: Some mighty fine ones at that!
Liked 611 Times
Just got back from a 32 mile shake down ride and I had a blast! I can foresee SS becoming my weekend go-to. It's a 'french fit', to be sure, but it rides so smooth and silent. Very stoked on what turned out to be pretty much a parts bin build.
The deets, for those who care about such things (I know I would):
1980/1 (?) Centurion Super Le Mans, 23"
Sturmey Archer HBT30 32h track hubs with flip flop rear laced to Sun CR18 700c rims. Rear is spaced to 130. 18t Shimano freewheel/16T Redline track cog.
Panaracer Pasela Tour Guard 700 x 28
Sugino LP 170 crank arms with Sugino 48t chainring and Origin8 track chainring bolts.
Shimano UN55 cartridge bottom bracket.
Some off-brand vintage bmx pedals that are kinda thrashed.
Weinmann 610 centerpull brakes
Tektro brake levers
Tange Levin headset
Nitto Technomic stem
? 26.4 seatpost
Vetta SL saddle
Soma Portola handlebars with cheapo cork tape.
Tektro brake levers
Tange Levin headset
? 26.4 seatpost
Vetta SL saddle
Likes For bargo68:
Likes For Swampthing:
#335
This one may be the, then, most frugal single speed here. Bought it new about seven years ago. I'm now a 67 year old cancer survivor with one blown knee. Two years of cancer treatment took away much of my strength and stamina. But, I'm back on the bike again. I ride it as a single speed, not a fixie. Paid $75 for it new. I use it on a daily 2.5 mile route with enough hills to make it a workout, and time each day to compare. Have not been able to ride standing up due to the knee, so, it's a bit of a challenge. The bike weighs about 31 pounds with an added seat stem rack and water bottle cage. It uses 700C tires. I"d guess about 29 lbs without those items. I've just done basic maintenance on it. Replaced both tires, one set of brakes, cleaned, inspected front and rear hub bearings, and repacked with grease. Hoping that riding will improve the knee, give me back some of that strength and stamina that was taken from me, and that I may then be able to ride farther and longer like I used to.
Not my bike, but it's just like this one.
Likes For birdmove:
#336
Old and rusty
Bikes: 1983 Lotus, 1989 Haro Escape, Quax muni, KHS?, Nishiki Olympic 12
Liked 115 Times
Cool bike
price means little. I paid more for my used rack than I paid for my bike.
congrats on surviving.
Cancer sucks. That’s all there is to it.
Knees are another design flaw.
I hope when I am 67 I can still ride every day.
#337
Bikes: A couple old Schwinn Cross bikes , couple Specialized , a few Cruisers
Liked 3,140 Times
I’ve owned my Specialized Hardrock for several years and always wondered how I would like it’s a single speed, but because of the vertical dropouts, never gave it try , until now .
I’m 70 and looking at making a bike that that’s easy pedaling , to “spin” my way around the neighborhood.
I just finished it up today and I’m thinking I’m going to enjoy this one .
With a 30 tooth single chainring and a 21 tooth rear cog , I spin out around 9.5 mph. That’s fast enough for me and it allows me to spin up the hills around here .
Likes For OldCruiser:
#338
Old and rusty
Liked 115 Times
Nice
Im just about done building up something similar on an unknown frame (curb find) for messing around on the dirt trails. No hills around here, but we have levee banks, soft sand and wind so I can pretend.
#339
Super-duper Genius
I say good for you!
Your bike may not be as fancy or lightweight as many of the ones people show here, but the important thing is it gets used. Few things are stupider than a really nice bike that's a garage queen. And if you're riding yours every day, it has probably given more value than many of the nice ones photographed and shown off, in terms of hours of enjoyment per dollar spent. I have too many bikes. I ride all of them, but some have not yet given a value anywhere near one hour per dollar. You've probably got me beat by a long shot!*
I hope your strength continues to build and your knee improves, so you can enjoy riding your bike for many more years.
I assume on your own bike the brake levers are positioned at a comfortable angle. That's the one thing that looks really wonky in the example picture you posted.
* You've also certainly beaten some guys who spend upwards of $10k on a flagship model from Specialized, Colnago, Pinarello, or the like, and ride it a few times a month. I mean, I'm sure those ultralight carbon fiber machines look really pretty hanging up in a sparkling clean garage, next to a Porsche or Range Rover. To me, they look even better out on the road, getting dirty with sweat dripped from above and road grit flung up from below.
Likes For Broctoon:
#340
I say good for you!
Yeah, I've got the brake handles adjusted well well me. I still like this very basic single speed bike. I did an extra four miles on yesterday just for fun. Not ready to ride it to Hilo and back yet, but optimistic I'll get there.
And, thanks for your comments!!
Likes For birdmove:
Likes For Broctoon:
#342
Catastrophe Merchant
Bikes: Keirin and a Steamroller
Liked 218 Times
NBD: 2018 Rinsei Lab Keirin
Yay! I received the frame and built it up this morning, and then gave it an inaugural 70km ride this afternoon. I am kinda excited about this bicycle—more than I have been in quite a while when it comes to a bike. The oversized downtube changes the ride noticeably in terms of stiffness—a subtle but quantifiably different feel than the other keirin bikes... Super dope. And the paint is insane... Rinsei-san is certainly an artist in all meaningful ways when it comes to making a frame.
Likes For ethet:
#343
Liked 335 Times
What tires are those?
Likes For Senrab62:
#344
Liked 218 Times
The tires are nothing special: They're the Panaracer Pasela at 25mm... If I am honest, I don't like having such a costly tire at the rear when riding brakeless... I'd much rather a $20USD RiBMo or Rando back there. However, when building this thing up, I kinda got stoked on the look of skin walls front and back and decided to just go with it. As soon as I shred the rear Pasela, I'll be returning to something more economically consumable—guaranteed
#345
You could ride over, what we call, Saddle Road, which goes over to the Kona side, where they do the Ironman competition annually. That's about an 85 mile ride. Unbelievably tough ride, but I see people doing it.
#346
Built this around an old Bianchi Pista frame about 20 years ago, including the wheels, still ride it til this day. I did the LA Wheelmen Grand Tour 200mi highland route on this bike a few years back.
Likes For roadfix:
#347
I know Saddle Road very well. When I was stationed in Oahu in the army we trained up in Pohakuloa often. I spent a week there once on detail with a rental car and drove it multiple times. I was never able to bring my bike but I always dreamed of riding it. If I lived on that island I'd probably have tree trunk legs.
#348
I'm using this bike as my everyday, everywhere rider ATM and wasn't feeling not having flat-fixing-stuff with us. Too much?
Likes For IAmSam:
#349
Liked 218 Times
The pink saddle bag is insanely dope... It just balances out the entire color scheme that we have going on here. It almost makes the bike feel more 'planted', in that the brightness front and back makes the whole thing more balanced. Methinks it is a benefit, not a detriment.
Though I have to type: It always makes me smile and feel hopeful when I see this bike pop up here...
#350
Live not by lies.
I actually wonder why anyone in FL has a derailleur. Headwinds?
