Addiction addicts: Continue here...
#3127
So it is
Liked 4,934 Times
#3128
Still can't climb
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
#3131
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,047 Times
Hmmm. No.
However, after getting into the Cadbury Flake commercials that were in the related videos I was mildly aroused and have put a visit to the local limey food store on my to-do list.
Will I be wasting my money on a Cadbury Flake, coasting?
#3132
Still can't climb
I apologize in advance for far exceeding the one-line (sometimes one-word) average of Addiction.
Last month a friend of mine complained that she kept getting flats. I had her drop her bike off, did a thorough inspection of the rims, tires and tubes, gave it a quick tune-up, and then gave it back to her, mentioning that she should be riding between 90 - 100 psi.
Yesterday, we had our first opportunity to ride together. I rode to her house and when I arrived, asked if she had enough air in the tires. Her response was "Yep! Plenty! They're still full from when you pumped 'em up!" She even did the old thumb-squeeze on the tube and declared them hard...to which I responded "That's because you're pushing the tire all the way to the rim!". I put on the floor pump, which read "20" in each tire, and got them up to pressure for her. Surprisingly...no flats on the ride!
As an aside, my ride was 41 miles but because I rode 25 of it with her, most of it at a much slower pace than normal, I was able to fly on the final 8 miles after dropping her off. Typically the last 8 of that ride is when I suffer the most.
#3133
VFL For Life
Bikes: Velo Volmobile
Liked 1,950 Times
Don't delete my posts, moderators. I've embedded a virus in them which will blow up the entire forum if you do.
#3134
So it is
Liked 4,934 Times
Cadburry Flakes are the best.
#3136
So it is
Liked 4,934 Times
#3137
Hint - When you're finally dialed in, make sure you either measure or mark all your settings before shipping your bike. For instance, you know where your clip-ons attach to your bar? I took a silver sharpie and outlined the little plastic thingies that clasp the bar. Kind of like outlining your tools on the pegboard...only one right way for them to be put back on. I did the same for my seatpost.
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
#3138
Why do I go back and forth as you as a poster?
Largely it's a function of your writing. You tend to use byzantine sentence constructions that come across oddly and are often difficult to understand. But now and then you post something that is clear and on point.
Is English a second language for you?
This is the questionable statement I asked you to explain. I find this interesting and would be very curious to know what you are referring to. Enquiring minds want to know.
#3139
Riding
Bikes: Motobecane Fantom Cross Pro; Motobecane Nemesis Pro
For me, not eating after 8 and eating a light, clean breakfast are the two major keys for weight control/loss.
#3149
Are you using the Reynolds pads?
#3150
No, I have the Shimano DA pads. My Assaults didn't come with pads, so I ended up with these from the LBS. They turn the wheel the same color as the pad.
