Old dutch/belgian Kimt/Schotte/Maes/Steenbergen handlebars?
Old 11-23-07 | 01:41 AM
jeffieh's Avatar
South Seas Correspondent
More curiosities hanging in the shed. I would appreciate any info on these bars. They were off an old Joco frame found at the local dump. They're narrow - around 38cm. The engraving seems to be four names: M Kimt/A Schotte/S Maes/V Steenbergen. What's the story? Your insight will be much appreciated. Thanks - Jeff.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
jeffieh is offline
Reply
Old 11-23-07 | 08:40 AM
stronglight's Avatar
Old Skeptic
Bikes: 19 road bikes & 1 Track bike
Those were names of famous Belgian Pro racers from the 1930s and 1940s. I believe Marcel Kint, Rik van Steenbergen and Alberic "Brick" Schotte all held World Champion titles between the late 1930s and 1950 [Schotte in both 1948 & 50]. And, Sylvere Maes was the winner of the Tour de France in 1936 and 1939, [Schotte came in 2nd in 1948].
That handlebar was made by the Belgian company "TITAN", perhaps some time between the 1950s and early 70s. But, they were manufacturing bars and stems since the late 1930s. The heavy collar surrounding the stem clamp area was a fairly uncommon feature back then. It was not decorative, it was designed to ensure a strong and stiff alloy bar - very much a professional quality bar, and famous for being among the first early Dural alloy handlebars with no flex.
They were made in 25 mm diameter but also in a much larger diameter as well. If you measure the diameter near the clamp area I would not be surprised to find it is uncommonly large, around 27 mm. diameter. At that time a Cinelli bar measured 26.4 mm at the center, a standard British or US clamp was 25.4 mm (1 inch) and French bars had a clamp diameter of only 25.0 mm. So, this was a very serious racing component. It also required a TITAN stem - since they were the only company making one with a 27.0 mm. clamp diameter.
By the 1960s the Titan alloy bars were made with an unusual anodizing process which actually gave them a PINK color. This really did not strengthen them any further, it was really just to prevent corrosion - and to keep the hands and gloves from turning black (as they would from contact with any non-anodized aluminum).
The bend of many road racing handlebars were frequently copied from this original shape and would soon be referred to with the generic term "Maes bend" - after Sylvere Maes who may have helped to promote this particular curve.
Back in its day, 38 cm. was not at all considered a narrow bar width, it was as common as a 42 or 44 cm. road bar today. The Titan bars were available in widths from 35 to 42 cm. Titan was also famous for it's fine chromed steel bars and stems too. Many Track racers loved their steel track racing line, but even the alloy track bars were strong enough for sprinters to use, and this was very unusual for early aluminum alloy technology.
If you still have the stem you should probably save that as well.
stronglight is offline
Reply
Old 11-23-07 | 09:06 AM
Uff Da!
20 Anniversary
Great info there from "stronglight"
I would like to add that this is the bar and stem that came on the early sixties Schwinn Paramount.
I am surprised to hear that they came in a 42cm width. I've never seen one that wide. If someone has one of these in width wider than 38cm(c-c where the brake levers mount), I would be interested in buying it for my '62 Paramount. I am also interested in buying the corresponding Titan stem with the 27mm clamp in 9cm or shorter length.
Sierra is offline
Reply
Old 11-23-07 | 12:55 PM
jeffieh's Avatar
Wow. Fantastically informative, thank you. Bikeforums.net leaves everything else for dead! Titan bars eh? They're certainly narrow by today's standards. I don't have the stem sadly. Someone had turfed it and replaced it with a modern MTB stem before chucking the whoole thing in the dump. It did come with a set of NR derailleurs which I've recycled onto other ppet bikes. It also had one original changer - a big wide circumference thing cast out of steel I think.
jeffieh is offline
Reply
Old 11-23-07 | 06:30 PM
cyclotoine's Avatar
20 Anniversary
I have a set of these bars and a short titan luxe stem. I will check the width of the bars but I am pretty sure they are 38s based solely on visible inspection. I am guessing the stem to be 80mm.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
cyclotoine is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
