Chain cleaning: nifty tool or vat of cleaner?
So say we all.
Bikes: Gary Fischer Wahoo, upgraded Specialized Allez
Searched through the threads and haven't found this topic yet.
I'm a huge newbie when it comes to bike mech -- to the point that, to my shame, I've had yet to clean/lube the chain! The threads point to the park tool site that has a nifty chain cleaner (they call it a CM-5). Anybody use one of these, or does everybody pop the chain off and soak in a vat of stuff?
I'm using this thread for reference: https://www.bikeforums.net/bicycle-mechanics/77327-general-maintenance-mountain-bike-used-commuting.html
Thanks!
Thanks!
la vache fantôme
Well if you dont have a SRAM powerlink (golden colored masterlink) i would go ahead and buy that machine, i've heard it doesnt clean as well as a soaking and can be messy but it works. If you've got a powerlink i would just soak it, its cheaper and it works better.
Quoted: 114 Post(s)
Liked 119 Times
... Anybody use one of these, or does everybody pop the chain off and soak in a vat of stuff?
Thanks!
Thanks!
I believe the only way to give a thorough cleaning is by removing the chain, soaking it and rinsing it well. Personally, I use Simple Green (low cost, somewhat environmentally friendly compared to petroleum based solvents). While it is soaking, I'll also brush it and agitate the chain while in the solution. I follow that with multiple rinsings with hot tap water. The hot tap water heats the chain and helps it dry off.
I like to lube it before I install it on the bike. Sometimes, I'll place the clean, dry chain into a sandwich bag, squirt in some lube (my personal fav is Progold, a "dry" lube) and shake the bag around. Sometimes, I lay the chain out and place a drop of lube at all pivot points.
Also, I use a SRAM chain, which has a tool-less, reuseable "Powerlink". The chain can be disassembled in a matter of seconds using your fingers. Assembly takes half the time.
Bikes: Tour Easy recumbent, Giant Boulder SE with an Xtracycle attachment
I soak the chain into a pan of hot, soapy water (dishwashing liquid), use a used tooth brush for the stubborn gunk, and rinse in HOT water. As MudPie says, a hot chain dries faster.
Retrogrouch in Training
Your removable link may not be a different color (if you have one at all). My KMCs have removable links but you have to look for the retaining clip to know which one to attack.
Anyhow, I'm a big fan of the bottle-o-cleaner method. I like Finish Line citrus degreaser. It's biogradeable and acts as an emulsifier, so I feed in the chain (a Gatorade bottle has a nice wide mouth for this), dump in a little bit of degreaser, shake it all over to coat the chain, then pour in a bunch of water which activates the emulsifiers and really gets the grease moving. Shake it a bunch more, dump the water. Repeate the water step until it comes out clean. Hang dry, put back on the bike, and lube.
Recovering Retro-grouch
Location: Some call it God's country. I call it Acton, Maine
Bikes: Too Many - 7 or 8
Grunge Brush
Shimano Certified
Since I rarely have a shop around when I have time (like vacations or races) I carry a big spray can of Brakleen. Pop the chain off(Sram of course) rinse it all off with that stuff(be ware it is a little volatile) if you wish to collect the junk have a cup or pan or whatever but it evaporates so fast its hardly a concern. Let it sit a few mins(thats all it takes to air dry) then do whatever you wish for relube.
So say we all.
Thanks!
I'm just amazed at how much random maintenance crud is associated with my new road bike. Today something in the rear assembly just started clicking! I only hear it when I'm not pedaling, just freewheeling, clicks once for every chain link that comes off the rear gear. When I pedal backwards it sounds like I've just cast a fishing line.
It's a good thing cycling is fun . . .
Bikes: columbus italian racing frame
so cleaning the chain amounts to cleaner, tooth brush, and hot water. What is the recommended lubricant? Regards, Henry
la vache fantôme
lol yea i dont road bike i have an mtb bike but i must say it is a lot of maintenance. I do find with high quality components its less maintenance.
Chairman of the Bored
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
I remove and soak my chain a few times a year, but other than that I use a cloth and turn the cranks, running the chain in the oil-lubed cloth. At the least it gets a pretty good amount of hte grit, as well as the largest pieces, out.
Bikes: Guru Geneo, Specialized Roubaix Pro, Guru chron 'alu, Specialized Sequoia
I'm using this thread for reference: https://www.bikeforums.net/showthread.php?t=77327
Thanks!
Thanks!
Shimano Certified
To answer the headline question:
What mechanic wouldn't if able, buy a new tool?
Quoted: 114 Post(s)
Liked 119 Times
...Thanks!
...Thanks!
I'm a firm believer in a quiet, smooth chain.
So say we all.
Ok, gonna totally clean and lube the chain tomorrow and clean the cogs, but yuck! My chain's a Shimano CN-HG53, which means I have to use one of their wacky replacement links. If there is a bike shop open here tomorrow (yay Mississippi), hopefully they'll stock one of these.
Thanks all!
Thanks all!
Shimano Certified
Don't remove it unless you have to. It adds a liability every time you pop a shimano so far as im concerned. They say the links are fine but nothing is as solid as a master link(like a Powerlink) or a virgin unpunched link. Cases like that ill just use a heavy drip of a self cleaner lube like White lightning or Krytech, then follow it with something else. The cleaning comes in the use of a clean rag to wipe as you go. IF you really want to be thorough, albeit a little more messy, take a can of Brakleen(brake parts cleaner) and it has a straw like wd 40. Spray the links as you go and have a big towel or rag behind it to catch the junk and overspray. The stuff dries like it was never there, then use your lube of choice.
Bikes: 84 Trek 660 Suntour Superbe; 87 Giant Rincon Shimano XT; 07 Mercian Vincitore Campy Veloce
I've cleaned chains for years without a chain cleaning tool until two years ago when I decided to buy the Finish Line Cleaning Machine; and now I doubt if I will ever have the need to remove another chain!...well at least not on the road bike.
When I use to remove the chain I really did not like doing it because it was time consuming so I would wait until the chain had about 1,000 to 1,200 miles on it before I would give good cleaning job. Now with the Finish Line tool I clean the chain every time I relube which is about every 150 miles, thus the chain stays cleaner with the more frequent cleanings, and it only takes maybe 10 minutes.
So do I like the cleaning tool? Yes, it's big time saver and the chain remains cleaner, and it's far less messer. Finish Line also sells a biodegradeable cleaner (a small bottle usually comes with the cleaning machine), that works very well. On MTB's if you get things to gunked up on a ride you have no choice but to remove the chain.
Word of caution; according to other people I spoke to and on various forums, the other cleaning machines are fragile, and the Park maybe the worst due to the weird handle on the side breaks off; and the Finish Line was rated best at cleaning.
I remove the chain. It's not a big deal (once you've been shown or RTFM), even for OEM chains.
I'm lucky to have access to an ultrasonic cleaner. I remove the big chunks with a wire brush first of course!
I DO use a different method for lubrication Paraffin.
I bought a 1# brick of paraffin (available at any supermarket/dept store, look near the canning section) years ago.
Clean the chain in the ultrasonic cleaner using your favorite solvent as the liquid.
(BTW, you can buy WD-40 by the jug)
Dry completely (compressed air helps).
Wrap loosely in foil and bake in the oven to remove any trace of solvent.
(If your wife/SO objects, use the grille)
Melt the paraffin on the stove (melt, not ignite; if it smokes, turn down the heat).
Drop (gently, no splashing) the clean chain into the paraffin.
Swish around with tongs, making sure to bend the chain side-to-side.
Remove from heat, let cool.
When the paraffin hardens, chip out the chain from the paraffin.
Use the wire brush again to remove any paraffin chunks/hunks.
VOILA! your chain is dry lubricated, for my use (road touring) for the entire season.
Hint: You have to get the wax really hot, just below smoking, to allow it to flow into the links.
If it starts to smoke, back off on the heat.
BTW, you can remelt the wax and pour it back in the same box just reinforce the corners to prevent leaks, and prop the box up so that the sides don't balloon out while the paraffin hardens.
Works for me.
It's probably not an OSHA approved method, but I never even singed my eyebrows.
Works for me.
Halocon
Bikes: Orbea Onix (105)
i use a chain cleaning tool from performance bike. i got it for 10 bucks. it has 52 spinning brushes and i also got a bottle of their bio-degradable degreaser. it seems to work fine for me. i have a road bike.
Bikes: Bigshot, Airbourne,2006 QR Caliente, bianchi, Gt grade.
The best thing i found to clean the chain is a tooth brush and some white gas. My method is not to earth friendly but oh well.
Morlok, You have WAAAAAY too much time on your hands . I clean vigorously in a tupperware container with Finishline citrus, rinse thoroughly in hot water, dry thoroughly on radiator, drip of Finishline Wet on each link.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Personally a Coke bottle with some degreaser and a toothbrush serves me quite well.
Originally Posted by Raiyn
An ultrasonic cleaner uh huh sure. What institution is crazy enough to allow this?
Anyway, FWIW, I use a chain cleaner, a park model. It works pretty well, and isn't much hassle. I've tried the soaking method, and I've found that method doesn't take off a lot of the crap that cakes onto the chain. I have to scrub a bunch to get it all off.
