Numbness and tingling- how irritating.
superArti
Bikes: 2007 Fuji Professional 2.0, 2009 GTw Avalanche 2.0
After even a short ride I'm having numbness and tingling in my left index finger, that lasts for days (and is probably re-aggrivated after only a day or two of rest). What a trip going to work, and trying to type all day. Cycling gloves fit well, have tried a couple different positions, and making sure I'm not gripping too tight.
Also, my toes (from the outside to the inside) go numb, only my right foot (which is millimeters bigger than my left)- cleat forward or backward?
Any suggestions?
Any suggestions?
Mmmmm Donuts!
Bikes: 1998 IF Crown Jewel
try GEL bar tape.
Make sure the pedal spindle is centered on the ball of the foot. Adjust the clete appropraitely. You may need someone to help you with this. Your right and left feet will be different. You should also check to see if you pronate your feet when pedalling. You may need shims to correct it.
John
'09 Cannondale CAAD9 - Team Latitude/ABRT Special.
'04 Lemond Victorie Ti
'98 IF Crown Jewel (dead)
'92 Trek2100 (TT)
'50 something Gino Bartali (fixer)
'02 Ducati ST4s (Moto-Ref mount)
My Blog
John
'92 Trek2100 (TT)
My Blog
Bikes: an amazing Fuji Newest 3.0!
When I first started cycling I had problems with my left hand going numb after about a half hour of riding. I tried gel gloves and that didn't work. It wasn't until I started getting really serious about riding that I started adjusting my fit on the bike. As soon as I raised and moved my seat forward the numbness disappeared. I understand that you have tried different fits, but maybe you haven't found the right one yet. Do you adjust your fit in small increments?
No cud for foil.
I'm no doctor, but pressure on your nerves is probably to blame, as you probably already figured. What kind of gloves are you using? I find that some people who have trouble with numbness use very thinly padded gloves. My hands don't have too much meat on them, and I use Louis Garneau Ergo-Airs as my short-finger gloves. Their padding is very well-placed, I find, and it's very firm, so it actually does what it's supposed to do, that is, protect your hands' nerves.
As for shoes, if your cleat is way far back, I could see that as presenting a problem. Just remember the pedal axle should roughly bisect the ball of your foot. That said, foot issues are much weirder, I find, so I'll keep my two cents limited to just that.
superArti
Hm, good tip on the gloves. I assumed more padding was better. And, the padding isn't too firm.
superArti
Bike Fun Fanatic
Bikes: 2020 Trek Checkpoint ALR5, 2012 Surly Disc Trucker
Quoted: 8 Post(s)
Liked 16 Times
I had this problem pretty bad when I first started riding a road bike last year. I found a pair of Adidas gloves with minimal padding were best, but the biggest difference came when I swapped out my stem for a higher-rise version. My saddle is not even an inch higher than my handlebars, which is a more comfort-oriented setup.
Also, make a point of regularly letting your left arm hang down and shake out your hand, say every 15-20 minutes while on a ride.
Good luck,
Scott
Good luck,
Scott
Recreational Commuter
Bikes: One brand-less build-up, and a Connondale Synapse Carbon Ultegra Disc. A nicer bike than I need, but it was a good deal, so... ;-)
Quoted: 7 Post(s)
Liked 5 Times
The fit with everything else on my bike is good, with the exception of the left hand. I'm hesitant to adjust anything for fear of causing another issue. I did tweak the handlebars a bit yesterday, and think i'll give myself a day for the numbness to go away completely before I get back on. 5 days on in a row, I haven't given it a chance to dissipate yet.
