The real poop on Ergomo.
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
OK. I am an email away from dropping some coin on an Ergomo set-up (Pro with crankset). I needed some new hardware and ruled out PT and can't get a deal on SRM so it's Ergomo or nothing right now.
I would be getting the system at a great price and know I would get support so this is not an issue. My concern is about the reliability of the product itself. I live in the tropics so water is an issue. I know they have redone their computer and it has been improved.
Any advice, suggestions or anecdotal experiences from OWNERS of Ergomo systems would be greatly appreciated.
Bikes: Ridley Noah-Scott Addict-Orbea Ordu
Now here are the pro's and cons of owning an ergomo.
Pro's: accuracy (ignore the post about pedaling with one leg he knows not of what he speaks) i've tested this thing back to back with SRM's and it's within +/- 5w. Cost, compared to an SRM it's a pretty good deal. Altitude and gradient, you don't get that with an SRM.
Cons: Well it's really a ***** to move from one bike to the next. You can't use and external bearing BB with one. The new distributer Fit Multisport has not returned any phone calls or emails I've sent them. However ergomo Germany has been very helpful.
Personally I like it much more than my PT and for the money it's a better buy than an SRM.
wavylines
The literature doesn't agree, or at least, gives very mixed reviews. Even if we accept that the Ergomo is properly installed and accurately measuring torque in the bottom bracket, it still assumes that the ratio of power between the left and right legs is constant. Studies show that, in fact, that ratio varies with intensity, fatigue and riding position.
Pretty sure the SRM does not measure just one leg like the Ergomo and since all things are not equal (for our legs) left leg power x 2 may give odd results though I admit it might not be an issue.
Another con to using Egromo is you are limited to the cranks you can use.
wavylines
SRMs really measure torque in the chain. Both legs contribute to that. Ergomos only measure torque from the left side and assume that total torque is twice that.
Certifiable Bike "Expert"
More reading for you but you may help w your decision...
https://www.cyclingforums.com/t443031.html
https://www.cyclingforums.com/t422842.html
Race to train
Shouldn't since the ergomo is optical and not strain measuring device.
I think EDR and RacerEx can give you non-bias reviews since they have both used multiple power meters. From what I have read the ergomo accuracy is very sensitive to proper installation. As far as the device measuring only one leg, well it really depends on what you are trying to achieve. If you want to directly measure your readings to your friend PT or SRM it may be off but if you are using it to log and train then it doesn't matter if you device read 100w high as long as it is consistent in that reading.
My only gripe with the ergomo is the ugly head unit.
wavylines
Check out the second link in LT Intolerant's post. There's also some stuff on biketechreview.com, but Kraig just redid the forum and I can't find the links. I'll post back if I can round them up.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
The due diligence is helpful, but seems heavily biased. For the record though, Ride magazine did a comparative review over several issues. They found it read higher in the higher (800+) wattages than the SRM or PT if memory serves.
I would ask if you've owned one? OP's not asking for a librarian or a human Goggle, but rather first hand user data, which you can't provide if you haven't lived with the units.
I did for nearly two years.
I no longer own one, I don't have any emotional attachment or financial interest. Here's my opinion:
I liked the computer on the Ergomo better than anything I've seen (I did paint it black though). TSS/IF, altitude, gradient, and cumulative feet climbed in an easy to use interface with big numbers for us elderly folks. I never had a weatherproofing problem but I never tested it as harshly as I have my SRM's. That said it saw sub zero and 100 plus temps, some water, snow and sleet. Never had an issue.
While absolute accuracy might be better with other units, compared to my SRM's I didn't see any wide discrepancies. Very good relative consistency, which is what you need in a meter that you'll be using as a training device. The one leg issue didn't manifest itself in any way, and given that I'm heavily left handed and footed, I'm not a bad test pilot.
The one thing to remember is that if you pedal backwards, you can make it read 8000 watts or so. Great for impressing BFer's, but it does throw your CP numbers off a bit.
It's also very light and gives you a choice of cranksets.
Installation is critical though. I do 99% of my own work, so I took time to make sure it was installed really well, and to the exact specs and orientation called for. A number of the problems people have had are a direct result of improper installation.
I ended up selling the units because I dropped the big bucks on a Dura style SRM (and later an FSA unit). I've got a number of bikes and the external BB bearing setup allows me to swap the SRM unit quickly and easily. I've got several bikes wired up and ready to go, something the Ergomo couldn't do.
Given my experience and needs I'd go with the Ergomo over any other powermeter except the SRM, as long as you are confident you can get it serviced. I had zero issues with either of my units.
Mr. Dopolina
Quoted: 149 Post(s)
Liked 117 Times
Thanks all for the input and the links. Big help.
Service won't be an issue as I am dealing with the Big Cheese from Germany (industry connection).
I run a Service Center, which is fully equipped, so I have the tools and the skill to install the unit correctly (at least I hope I do!).
+/- 5w is no biggie as long as it is consistent.
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
I'll echo RacerEx's comments 100%, sans the fact that I still own my Ergomo.
Pro Tip: I ended up putting teflon tape on the threads of my unit because the BB started squeaking.
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
100 kW :)
Bikes: '08 Specialized Tarmac SL2
What about intervals (laps) feature on Ergomo? I read somewhere that it's not available on Ergomo and intervals should be separated from each other using software.
Cat-O-Meter: where do I get mine?
Carpe Diem
Intervals are 100% present on the Ergomo headunit.
Mid-ride, hold down the bottom button for a couple seconds and it puts you in interval mode. Top button starts the interval, press again and it stops the interval, press again and it moves to the next interval.
The best thing is that in between intervals, you can use the bottom button to review average power/cadence/HR/speed from previous intervals.
Burning Matches.
Quoted: 4077 Post(s)
Liked 1,002 Times
You mean you review them the same way you can on a Powertap?
ElJamoquio didn't hate the world, per se; he was just constantly disappointed by humanity.
Quarq shill
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
Then you are misunderstanding how the ergomo interpolates the data. I had a Power Tap Pro for two years, looking at the data from the PT and the ergomo I've found no differences. I've done tests with both the PT and the ergomo on the bike and the data within a few watts of being the same. I've also done back to back tests with SRM's and egromos and found the same results. Racer X has had both (ergomo and SRM) and he has had the same results.
Although it would be nice to be able to use the race wheels without buying a new hub, a la PT.
https://www.saris.com/scienceofpower/...tionErgomo.pdf
Carpe Diem
In terms of basic functionality, yes, both units display data from previous intervals in the same way.
The Ergomo, on the other hand, allows you to exit "Interval Mode". The Powertap, by my experience, doesn't. Once you start an interval, you can't stop. You also can't stop one interval without immediately starting the next (i.e. on the PT, when you hold down both buttons to stop Interval1, Interval2 starts immediately). With the Ergomo, you can stop Interval1, recover, then start Interval2 at a later time.
No, it really does just double the power measured by the left leg. The bb doesn't twist on the right side, so it has to make the assumption that your right leg is putting out the same power as the left. Again, probably fine for repeatability, but can be off due to leg imbalances.
I've done one legged drills and the watts are consistent on both legs. I had a PT wireless and did a complete workout with both the PT and ergomo attached. The two units were within +/- 5w. I really think everyone is making way too much out of the 'one side' thing.
Burning Matches.
Liked 1,002 Times
