Quick Release
Quick Release
Old 11-14-07, 02:54 PM
Quick Release
I just built a commuter RB and the rear wheel I'm using is approx 5mm short of reaching the dropouts. The quick release takes up the slack nicely when tightened and the axle is then thouroughly recessed in drop outs. So far, I've put around 500 miles on it and I absolutely love this bike.
1. Is it okay to take up the 5mm slack with the quick release?
2. Is there any brand that's better than others or stronger material?
Thx
linx is offline
Old 11-14-07, 04:34 PM
Pleasurable Pain
greyghost_6's Avatar
Bikes: Voodoo Rada, KHS Alite 4000, Smith & Wesson Tactical, Diamondback Response
If the frame is steel you are fine. If the frame is aluminum you are OK. If the bike is steel look up what Sheldon Brown says about "Cold Setting" maybe you woudl benifit from that. Personally I ran a 130mm hub in a 126mm aluminum frame for 2000+ miles (spread the frame a bit). Any brand of what thats better? Quick releases? I have heard that XTR makes the best. Hope that helps a little.
greyghost_6 is offline
Old 11-14-07, 08:42 PM
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
This sounds like a 126 mm hub in a 130 mm frame or a 130 mm hub in a 135 mm frame. Compressing the frame should do no harm but you can change the axle for a longer one, add spacers on the non-drive side and reduce the wheel dish as a more elegant fix.
HillRider is offline
Old 11-14-07, 09:07 PM
Gone, but not forgotten
Sheldon Brown's Avatar
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times in 5 Posts
That's correct, except the part about needing a new axle.
In most cases, widening the spacing of a quick release hub does not require installing a longer axle.
Typical quick-release hubs are supplied with axles 11 mm longer than the designed spacing, so there's 5.5 mm of protrusion on each side. That is WAY more protrusion than is actually needed.*
When adding spacers to a multispeed hub, the spacers should always go on the left side, between the cone and the locknut. You should re-adjust the position of the right cone and locknut so that the protrusion will be similar on both sides.
You will then need to re-dish the wheel, most likely by tightening all of the spokes on the left side a bit. This is actually a Good Thing, because it results in a _stronger_ wheel!
*Having _some_ protrusion is helpful for aligning the wheel, but in fact you don't _need_ any protrusion at all! I rode for quite a while on a hub that I had set up with the axles flush with the dropouts, with no problems. (This was for a fixed-gear conversion of a frame with vertical dropouts. Cutting the axle short gave me a bit of chain tension adjustability, as only the skewer shaft was running through the dropouts.)
Note that reducing the dishing will result in making your rear wheel significantly stronger. Do it!
Sheldon "Wider Is Better" Brown
Code:
|  To stay young requires unceasing cultivation   |
|    of the ability to unlearn old falsehoods.    |
|                          --Robert A. Heinlein   |
Sheldon Brown is offline
Old 11-15-07, 12:08 AM
greyghost_6
I just ordered a rear XTR QR and presume it should fit.
HillRider
Yes, I think it's a 130 mm hub in a 135 mm frame and the QR tightens it down firmly.
Sheldon Brown
Thanks, I'll look into a longer axle down the line. For now compressing the drop outs seems to be working well. I just wanted to make sure I have a strong QR that's well made. Are the titanium ones better than the regular steel ones, anyone know?
linx is offline
Old 11-15-07, 07:07 AM
Right and I don't know why I didn't think to say that too. I've respaced a rear wheel myself from 126 to 130 mm and retained the same axle, just sacrificing part of the axle protrusion in doing so. Every thing worked well.
This is fine for "one size" change (126 to 130 or 130 to 135). I don't think I'd do it from 126 to 135. That would leave only 1.5 mm protruding on each end and, while the qr does provide the needed wheel stability and you've used the technique successfully, I rather have a bit more for alignment and support purposes.
Old 11-15-07, 10:14 AM
Quoted: 24 Post(s)
Originally Posted by linx
Sheldon Brown
There's no reason to replace the axle.
There are no good titanium skewers that I know of.
See: https://sheldonbrown.com/qr for the skinny on skewer quality.
Sheldon "Enclosed Cam" Brown
Old 11-15-07, 11:27 AM
Joshua A.C. New's Avatar
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
Ah! This 100% answers my question over here!
Joshua A.C. New is offline
Old 11-24-07, 12:08 AM
Thanks for the link Sheldon. I ended up purchasing two NOS XTR skewers with the enclosed cams and they are much better than the ones I got rid of, which were non-enclosed and sometimes spun around when I tightened them. These XTRs really grip the dropouts and don't spin around.
linx is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
