Deep Vs 1,000 miles in
Bikes: Firefly custom Road, Ira Ryan custom road bike, Ira Ryan custom fixed gear
Quoted: 9 Post(s)
Thought I'd share, as many of us have talked about wheel challenges...and I've been through my share.
By way of background, I'm around 6'4 / 230, and often use the bike to commute (38 miles round trip). So, between me, 2 water bottles, the bike and a bag that includes the laptop, weights can push 270. I'm pretty strong, and have been known to pop wheels out of true when standing to climb, which I do a lot. Bike is a kona JTS, and I have the deep vs as summer / distance wheels. I go through chains every 800 miles, and have in the past broken several spokes, a rim,bent a chaingring and destroyed 2 bottom brackets.
The wheels were handbuilt by SpinLite, and I'm running 36h in the back and 28 in the front, on Ultegra hubs. I clean them when I clean the rest of the bike, and have ridden them in the rain and on dirt trails (hey, it's a cross bike). I'm running 700x28 conti ultra gatorskins. Other than that, I've got reflective tape on the V section to make me more visible at night. I did not have them re-tensioned after 100 miles, as they didn't need it. They are also the first new wheels I've ever had that didn't "pop" when i first rode them.
After 1,000 miles, I figured I'd put the stock wheels back on the bike (wanted more grip on the wet leaves that the 38s on there afford) and bring the wheels to a local wheel builder who has a great reputation. I went by to pick them up last night. His assessment -- perfectly true, in great shape. He upped the tension on the front a little, but that was it.
Getting these has in a way "saved" cycling for me. I used to be tentative, and always look back after a bump or a climb to see how my wheels were. It was no fun, and it actually led me to not ride at times.
These are the stiffest and strongest wheels I've ever ridden, and I've stopped worrying about them. They are heavy, but I kind of like the way they carry momentum. I can't overstate the difference this has made, and the value of a quality hand-build using good parts (rims, spokes, nipples and hubs).
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Great and may I say. "told you so!" I have been prechin' Deep V for years to all my clyde friends. If even only on the rear. Some ave given up cycling as a result of failing wheels. But for some silly reason, they aren't willing to try the V. I can't understand why heavy guys insist on the cool looking lite stuff. I'm out to ride rather than to flash the cool factor.
I'm glad you took them to a good rep wheel dude that retensioned them for you. 100 miles is early, I've always done it at 400 or so, 1000 is great! One of the biggest problems is that riders don't take them back for a retension, glad you did. I have about 10,000 on the wheel I built with ZERO problems now and I run 23 Continentals.
Isn't it heaven to ride your bike without the thought of sucky wheels in the back of your mind?
Bikes: Cannondale Synapse
I am glad to hear this as I have ordered Deep Vs with ultegra hubs for my Cannondale. I cant wait! Especially, since I have broken two spokes so far.....
Man, Myth, Legend,Bigfoot
Bikes: 09` Motobecane Cx - 07` Dawes LT1000 - 82` Trek 412
100+ on the Deep V's ..I ordered mine after popping spokes constantly and
they have been a dream ever since. I followed Mr.Beans advice too..haha
Bikes: Roubaix S-Works SL2, Redline Conquest
I've also been eyeing a pair of Velocity Deep V's on Ultegra hubs from a local wheel builder. I've also heard the the DT Swiss 1.1 is as strong as the Velocity Deep V, but just a little lighter. I don't usually worry too much about saving weight, except for possibly rotating wieght. Any thoughts?
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
Well, the rotational weight, on a long steady pace ride is actually an advantage. Flywheel effect.....less energy required to maintain the pace. As to the sprint? A Clyde can generate a tremendous amount of torque and the few grams saved have little effect.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
OK, so after coming up to speed the extra rotational weight is an advantage? Good point. What about climbing? Advantage, disadvantage or negligable?
Quoted: 9 Post(s)
Liked 22 Times
Negligible.
Quoted: 9 Post(s)
Like everyhting, it's a trade-off.
I did a lot of research, and had open pros for a while...which i couldn't keep trued.
Deep Vs have been really quite extraordinary so far (no tension needed on the rears after 1,000 miles), and there seem to be plenty here with the same experience. I think the DT Swiss is simply much rarer, so there's not much experience with them. But I can tell you that a wheel you don't worry about is a truly great thing.
OK, help a novice here.
Are deep v's a brand or the name of a type/design, that spans different manufacturers? And if the later, which of the brands of rims seem best? Appreciate your patience here with a possibly stupid question.
Quoted: 9 Post(s)
Liked 22 Times
Deep V's are a type and a Brand, from Velocity. There are other names for the type of rim, but the Velocity seems to be the best for the $$.
Destroyer of Wheels
Glad to hear it - I'm pulling the trigger on those soon too
The Almighty Clyde FAQ || Northeast Index
eTrex Vista References || Road Reference
It's the year of the enema!
Gorntastic!
I have an old set of ultegra/mavic cxp30s that are deep section rims. Unfortunately they're 9spd or I'd be riding them because they're way better than the Bontrager Race wheels that came with my Lemond, the rear failing at 6000 miles.
At any rate, Trek finally sent me a new rear wheel, replaced the chain and cassette, and I can ride again.
Cannondale also sent me a replacement frameset (see below) after about a year of bickering with them.
It feels like Christmas. Except that it is about to snow up here in North Dakota and that means no more riding for me.
But I will be down in Texas after Christmas so I will be back on the bike soon!
Quoted: 9 Post(s)
Liked 22 Times
Are they 10 speed compatible? Have you looked into conversion?
Ride it like you stole it
Tom, I know you asked this already knowing the answer. All 9 speed hubs will accept a 10 speed cluster with the addition of the 1mm spacer. Its 10 speed specific hubs that will not accept a 9 speed cassette because the splines are taller.
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
Did anyone buy them prebuilt online (say, with an Ultegra hub)? I'm thinking of taking advantage of the Cnd. dollar and maybe investing, but need a good source.
Quoted: 9 Post(s)
Liked 22 Times
Since that's the case, Viking, why not convert them
Hip to the Game.
Bikes: Kona Lava Dome, Kapu 853
Good to hear these are durable rims.
FWIW, I had a set of old (late '90's?) Mavic Cosmic Expert (the all-silver version), 18-hole front and 20-hole rear.
My riding weight varied from 210 lbs to 240+ during the time I had these wheels. Never once did I have the slightest problem or hiccup from the wheels. Then I ran over them following a groggy early-morning ride...
I thought I could get a similar product from a Ritchey 20-spoke hub/rim, but the rim just isn't strong enough. I was having to true them after nearly every ride. Those will now go to the wife. She's half my size.
I'm now on a set of Zipp/Velocity Deep-V's (20F/28R) and I'm very happy after my first few rides. The hubs are smooooooooooooooooooooooth as buttah, and no rim stength issues at all.
Gorntastic!
If I did, I wouldn't have a nine speed wheelset for my commuter, otherwise I'd gladly swap them for the time being.
My plan is to destroy this new Bontrager wheel (it should last me season) and then upgrade once I have more money. Right now funds are pretty tight.
Gorntastic!
Quoted: 761 Post(s)
Liked 1,720 Times
How long did SpinLite take to get them built and to you?
Quoted: 9 Post(s)
Quoted: 761 Post(s)
Liked 1,720 Times
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
I love my deep V's but have been a little more love for my DT Swiss RR 1.1's. They have the same lateral and overall stiffness as the deep V's but weigh 100 grams less per rim.. Coupled with my american Class rear hub and Chris King Front hub at 36h, make for a great wheelset..
The new AC hubs only go up to 32 hole, but the high flange makes for a solid build and they are very lightweight.. https://www.amclassic.com/rd_205_s.html
I also have a handful of Open Pro's and the Deep V's and DT Swiss have a more solid feel on the road..
I wanted a strong wheelset so I got the Velocity Fusions withe 32/36 spokes. Lighter than the Deep Vs, but extremely strong!
