Tension Meters
The Legitimiser
Bikes: Gazelle Trim Trophy, EG Bates Track Bike, HR Bates Cantiflex bike, Nigel Dean fixed gear conversion, Raleigh Royal, Falcon Westminster.
Liked 5 Times
Tension Meters
I've been searching both here and online generally, and the only tension meter I'm finding is the Park TM-1. People here refer to it as a $50 tool, but in the UK, it's a £50 tool, more like $100. I'm already going to have to spring £65 for a Minoura wheelbuilding rig, is there a cheaper option for a tension meter?
Making a kilometer blurry
Nope, that's the cheapest one currently on the market. I would say to get the cheapest truing stand you can find or use your frame. The TM-1 is worth every penny.
Liked 7 Times
I also think the Park Tension meter is a good one, I think they're usually about $55 plus shipping in the U.S. There is a trick to using it though. You need to release the tool gently onto the spoke. A quick release causes an elastic rebound and an inaccurate measurement.
Al
Al
Quoted: 140 Post(s)
Liked 162 Times
+1 on the Park TM-1. But I got mine from Nashbar with a 20% coupon (net $48), I wouldn't be happy about spending nearly $100 for it either. As for the tool itself, it sure is nice and useful to be able to put a meaninful number to spoke tension. Musical pitch and feel are okay, I did that for years, but my TM-1 has enlightened me.
The Legitimiser
Liked 5 Times
As a musician, I'm tempted to go with the Ping! Pong! method. As a fairly skilled amateur bike mechanic, my brain is telling me not to. As a young lad, I used to check my tire pressure with my thumb, but since I've had a track pump with a gauge, I wonder how I didn't destroy more tubes. I suspect this is the same deal......
Plucking is great for relative tension, but absolute tension needs to be measured. Some people measure one spoke, pluck it for reference, and level tension from there. I actually use the TM-1 on every spoke because it's so easy to use, and if multiple adjustments are made, I don't have to worry about my reference spoke changing at all.
My last 5 wheels have ended up better than +/- 5% of target and average tension on every spoke, and that's a good feeling.
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
The Legitimiser
Liked 5 Times
How would that work? A tension meter doesn't measure the torque on the spoke nipples, but the deflection on the spokes. Measuring it at the nipple would introduce the potential for corrosion to affect the torque, plus you can't put a socket on a spoke nipple. They're tiny, and you need an open sided wrench anyway (a spoke key), or a sort of screwdriver for driving the end of the nipple. And that's why!
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
Yes, you'd be right.
Healthy and active
Bikes: mid-60's Dunelt 10-speed, Specialized Allez Sport Tripple, Trek 7.2 FX
If you have fairly good mechanical ability, you might want to try making your own version of a tension meter. Park has an exploded diagram of theirs for ordering parts. It is not very complicated. There are two posts connected to a frame, an "L" shaped lever on a pivot with a third post, a stiff spring, and a dial. Calibrate it by reading a spoke properly tensioned. It is tempting to make one. I have not tried it. yet. I do not build wheels and the wheels on my bikes do not need a lot of truing.
I did make my own torque wrench, chain whip, and cone wrench (adjustable). Those all worked well, were a lot of fun, and saved a bunch of money.
Pro wheelbuilder UK
Got to admit I use a DT Tensiometer daily in my work now but had loads of fun with a cheap keyboard, relating spoke tension to notes on the keyboard. F# on the drive side of an average MTB wheel does it for me. This gives a tension of about 1300Nm with DT Comp DB spokes. It created a stir in the workshop with me plonking in a tiny keyboard every now and again!!
In the days before tensiometers were available or horrrrrribly expensive (Hosan), I used to tension a wheel to the point of it turning into a potato crisp shape, then backing off the tension by a half turn. That gave a perfect wheel tension for that rim/spoke type. I then related this tension to pitch and used a kids xylophone (found in jumble sale) to match the note given by my spoke to the tension of the spoke
( drive side only on rear). This worked well for years.
Buy a Park tensiometer if you like but have a go with the kids keyboard first, you will learn a lot about relative spoke tension and amuse all and sundry!!!
The Legitimiser
Liked 5 Times
Hmmmm. I certainly have plenty of ways of finding F# about my person. I could do it with a keyboard one day, a flute the next, and perhaps my electronic tuner at the weekends!
James
Bikes: 2005 S-Works Roubaix Ultegra
Common, the US dollar is in the dumps, you should be able to find a decent deal
Pro wheelbuilder UK
Maybe not - as the customer is having a £900 wheel built I think the Tensiometer will have to come out of its case after all. No sense in using him as an experimental test bed.
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Quoted: 8 Post(s)
Quoted: 8 Post(s)
Also at the tensions used, torque at the nipple has a significant of thread-friction. As a result, the true stretch of the spoke (tension) can't be accurately measured using torque.
I wonder how well a cylinder head-like torquing sequence would work on a wheel. You'd need a very low-torque torque wrench to use so "set" the nipple, then add a specific number of turns to each nipple (you'd need to do some calculations using the recommend tension to figure this out) to load the spokes, adding turns in small increments while going in a star shaped pattern on the wheel. It would be an interesting experiment at least.
Bikes: Raleigh Glacier MTB/Commuter. Cannondale CAAD5, Windsor Timeline fixed gear
Would it be possible for you to paypal a BF member in the US the money so he could but it and then ship it to you? It might take alot of time but could possibly save you $40US or so.
Personally, I never thought a torque wrench on an engine was going to produce outstanding results. I'd like to see a pressure gauge in a washer under the bolt heads sometime...
The Legitimiser
Liked 5 Times
I've done similar things for people over there, and I'm sure I could find someone to help, yes.
Quoted: 16 Post(s)
Liked 24 Times
https://harriscyclery.net/page.cfm?PageID=49&action=list&Category=339&Brand=291&type=T
Mine's worth every penny to me, but I build a lot of wheels. If you're building a 48h 406, balancing tension isn't too important. Awfully easy to make a truing stand. I made one with 2 dial indicators for $20. With Sun rims it's not hard to build a wheel to +/- 0.004".
