Office chair-like Seatposts
Hi,
I'm 6'5 and 185lb. I'm not that heavy, but I am tall and have to stick my saddle pretty far back in the post to have it fit(usually as far as the safety marks allow..used to slide it further). I also haven't had a saddle last more than a year. I've tried various brands, but they all bust within 2-12months. Also, I bust saddles whether it's road or mtb riding, it' sucks
I've broken rails, but usually it's the contact between the saddle and rails that fails.
Having said that, I found a fun looking post at https://pricepoint.com/detail/16675-2...r-Seatpost.htm and I'm wondering if any of the other riders with lots of force on the saddle have tried these(or something similar)? I'm used to the saddles busting, but I've never busted a post(tho cf ones bend noticably under me). Do you think this post would be safe for me to ride?
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
Well, the suspension aspect of the seatpost would be a turnoff to me, right off the bat. Extra weight and loss of pedaling efficiency from the movement of the post, but then again, I probably do a completely different style of riding. Not that any one style or purpose of riding is wrong, to each their own
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Quoted: 766 Post(s)
Liked 1,737 Times
Interesting, but if it works like most chairs, the suspension will be shot pretty quick. Welcome to the forum toolong.
Sensible shoes.
Bikes: A few.
Consider this:
A set back post may solve the issue of pushing the saddle back so far and allow for proper weight distribution. A quality steel rail saddle should last years.
Gorntastic!
I don't think that's a suspension post.
It looks like it is designed to allow you to make adjustments on the fly with that lever, with the aid of a pneumatic spring. Help me see the appeal here.
My honest take is that this is a gimmicky piece of junk that you should not be riding, especially if you are crushing saddles.
There are suspension seat posts out there but that's not a very good solution to your problem either.
What kind of saddles are you breaking?
Setback
Hi, thanks for the comments,
Re: setback.
I ended up buying a post with the most setback I could find for my road bike. The saddle still busted after 2 months(but it was used 8 months on my prior post with less setback). Hopefully subsequent saddles will last longer. Still the post is further back than I would like.
I'm primarily looking to get this post for mtb fun. It will be nice to switch from descents to climbing with a comfortable post height.
On the mtb bike I run the biggest Leader frame avail with a 350mm post that's about 2-3 cm deeper than the safety mark. I'm wondering if the fact that this is a 2-piece post will make it more likely to snap.
Re: setback.
I know 185 isn't much, but when it's hanging on the far end of the rails, it is also doing more damage than 185 in the middle of the rails. Also, on the road bike I don't hit any bumps. The saddles just flex when I pedal.
I've broken a 3-4 no-name saddles and the Terry Fly Gel was the latest victim. The terry is also the most comfortable saddle I've ever tried and last the best, so I'm on my 2nd terry '07 now.
Sorry for so many posts in a row. I've also considered switching to the i-beam post/saddle system since it eliminates the rails, but the reviews on that didn't look too good. Anybody have experience with those?
Quoted: 9 Post(s)
Liked 22 Times
Re: setback.
Re: setback.
Sensible shoes.
Bikes: A few.
Look fella, you're breaking stuff and adding complexity and moving parts to that stuff is NOT going to help the problem. OK?
I pretty damn certain you're not fitted to the bike properly and that may well be a substantial part of the problem. Talk to a good shop about this point. The few bucks it costs are cheaper than new bits every few months. Discuss your technique as well. I've got 30 pounds on you, am really hard on equipment, and am not breaking far more delicate parts. Sometimes even King Kong needs a little finesse.
Lastly, the Terry Fly Gel comes in two versions: Ti rails and cr-mo. You want the cr-mo (steel) model. Put one of those on the Thomson ($68 HERE, nice folks) and tell us it broke. I dare ya.
Support JDRF
Bikes: Specialized Sirrus, Specialized Roubaix Elite
Quoted: 52 Post(s)
If you are having to move the seat that much, I bet the frame size is even off for you. You are too light to be having that problem even with a cheap seat.
I'm not sure how the Thomson post is going to help. It looks like a solid post, but it doesn't have any setback, so the rails are still going to be getting too much strain on them.
Here is an illustration:
That's with a 150mm stem & 350mm post, so I maximize my effective bike length and not have the air dynamics of a wall. However even with 25in top tube(21" frame), it still doesn't feel long enough so the saddle has to go far back.
Thanks for the tip on cr-mo rails, I suspected that ti ones aren't any stronger.
Saddle in the pic is the forte $25 mtb. It's two months old, but I think it's already showing some unhealthy flex.
Anyways, I haven't had any posts break ever. I was just wondering if anyone heard of these silly pneumatic ones busting. But since you guys might know about strong saddles, what is a racing-type saddle with the strongest rails out there?
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Wow, that's some mean nose tilt on the saddle. I would think being so tall, you'd have it tilted back.
Perma-Clyde
Bikes: Trek Hybrid 7200
+1 on the Thomson. I'm longer and much heavier than you. I have 8" of seatpost out of the frame. Yes, I have busted a cheap seatpost in the past, but that was after nearly a year and 4,000 miles of use. Something else must be a factor...Are you taking it off jumps?
Amateur stunt driver
ditto i'm 6' 6" and 255# and have never broke a saddle rail. There is something we're missing. You must have a very long torso. my road bike is a trek 1500 63 cm it has a ~ 24" top tube and I run a 130 stem and i feel pretty stretched out on it. My inseam (pants) is a bit over 34" (35.5 cycling) so I have a fairly long torso. you're on a bike with a 25" TT and you running a 150 mm stem -- thats nearly 2" longer than my bike setup and you're 1" shorter.
Last edited by D0ugB; 10-26-07 at 05:30 AM. Reason: missed reading post on geometry
Gravity Is Yer Friend
Location: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
Your saddle is breaking because of how you are setting it. You say you have it moved all the way back which means the back half or even 3/4's of the saddle is taking most of the forces AND has no support under it.
With that set up you will continue to ruin your saddles. I am 285 at the moment and I ride XC, DH, freeride and a part time roadie and the only time I break saddles is when I crash.
My recommendation would be to get the Thompson setback post, keep the saddles centered or a bit rearward on it and then get a longer stem to help even things out and give you more room in the cockpit.
If you can not get the fit correct that way then you may want to look into a custom ride or look into a race oriented ride. They tend to have a longer toptube then other styles of road or mountain bikes. Then just swap out the bars and stem to give you a more upright position if that is what you want.
The Thompson has two versions, there is a straoght post and a set back. If you look at the previous post with the pic in it you will see the set back and where it bend on the post. It moves the position of the seat back an inch.
DBD
DBD
Alright, alright, I just read your last post, shoulda done it sooner.
Anyways, I would not increase that stem length since you already have a 150 on there. As cast iron said, the bike does not fit you. As for "getting fitted", that does not mean you will be getting a custom ride, all it does it let you know what frames/bikes will suit you the best according to how you fit the bike and the geometry of the bike.
Also, is that a Leader frame? To my knowledge there are no Leader dealers (as in a local shop) anywhere so you would have done the mail order thing and you could not have tried the bike out for size first unless you knew someone with the EXACT same frame. A 21" frame from one company will have a different geometry then a 21" frame form someone else. Also, two 21" leader frames will have different geometries if the models are different. judging by the pic the toptube does look a bit on the shorter side like it was designed for a more upright riding position.
From what you are describing you will need a new frame unless there is a way to increase the cockpit more then it is but it sounds as though you tried the standard ways and you do not want to be out beyond the front axle. If you do not want to do the "fitting" then go try out as many brands as you can. Also, try on mountain bikes, hybrids, cyclocross and road bikes. Try and stay with a standard geometry because a compact will not work with a long torso.
As far as seats go, it sounds like they are coming apart where the rails join the saddle. If that is the case then stronger rails wont help. Try looking into a saddles that has a solid, one piece frame and rail system. I know someone made one but I can not recall who it was. If I find the info I will post it up.
DBD
DBD
Titec El Norte
Get this one and stop worrying:
Titec El Norte
good for Clydes and lots of setback. I am using it for similar problems.
https://www.bikemannetwork.com/biking/p/ST2361
Titec El Norte
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
Sounds like you should be shopping for saddles not posts. Also, that saddle tilt is crazy and you must have an incredibly long set of legs or an incredibly short torso/arms. The bike looks too small to me the way it is set up in that picture, with all of that seatpost exposed.
Gorntastic!
Yeah, that frame looks too small for you. My first recommendation would be to find a frame with a longer top tube.
If that is not an option, I'd invest in the thomson. I've ridden one for almost nine years now. Worth every penny.
Lastly, it is cheaper to buy a well-constructed $75 saddle once than to buy a new $25 saddle every other month. Get out the credit card and buy yourself a decent saddle. When I bought my Specialized toupe, my LBS promised to warranty any failures.
Here is a pic with me on the bike. I think I'll invest into the titec post as it has 35mm setback. Which is the most setback I've seen in common post. Oval concepts has one with up 50mm, but that is only available in expensive cf format.
Perineal Pressurized
The fact that the saddle is tilted to such an extreme tell me there's more to this problem.
I'd look at a fitting. You also might want to be counter-intuitive and pull the saddle forward and raise it a bit more.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Bikes: 2001 Giant OCR w/105-10spd, Schwinn High-Plains Built for Commute plus 3 Others in Various Stages of Rebuild/Repair
Go and get a fitting. It might cost you 50 bucks, but it will be worth it if it keeps you from spending 50 bucks every few months to buy a new saddle. In the picture of you on the bike that frame looks small, so unfortunately you might find out that you will need a new frame, but that will likely make you a better rider as well.
