Spoke Tension Values
Anyone have a link to recommended values for spoke tension in various wheels? Specificlaly, Mavic? I've been to their website and can find nothing. I've searched BF and found only two threads but didn't get anything out of them.
I'd like to build some of my own wheels and utilize a spoke tensiometer, but that won't help if I don't know how tight to make them
Making a kilometer blurry
This is the only table I've seen.
In the past, I've had good response from Velocity with email (same day reply).
Yeah, I found that on Park's website too. Doesn't list Mavic CXP33's that I own that I'd like to check the tension first with.
Phone Mavic.
I would say 120kgf, but that's a guess.
I did find this post that says 110kgf - 125kgf: https://forums.roadbikereview.com/sho...55#post1013555
Quoted: 140 Post(s)
Liked 162 Times
Slightly OT, but what effect does the number of spokes have on max. recommended tension? Say, for example, would you use more spoke tension for a 32 spoke wheel than a 36 spoke, given that the rims were otherwise the same?........Btw, I'd also love to know Mavic's recommended tension for some of their rims, such as the A719, X517, and Module E's. The X517's have been replaced in the Mavic lineup by the 717, and the Module E's are quite old.
Over the hill
Quoted: 996 Post(s)
Liked 1,203 Times
Mark, you can always use the values of a similar rim (similar weight, profile, eyelets, etc.) but as mentioned above, Mavic should be able to give you the values. Also keep in mind that this is like horseshoes and hand grenades where close is fine.
It's like riding a bicycle
I always use the value given on the Park sheet. It comes with the tensionmeter with instructions on how to measure different types of spokes. For these wheels I would call Mavic and see what you get. If they don't answer I would just buy the tool and use the Park worksheet.
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Quoted: 8 Post(s)
Thanks for the link. I have been looking for some information like this. I build my own wheels as I have for the last 35 years. Today I use mainly Mavic OpenPro and CPX 33 or DT Swiss RR 1.1 rims. I prefer rims with double eyelets as I am a larger rider and like to take my road bike on dirt roads. I had used the information from Gerd Schraner and I prefer running my tension up to the high side. Again Thanks.
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
I have seen that table before. I pretty much default to 115 - 120 kgf if I do not know the spec on a particular rim. It is within the range of all but the specialty rims.
Quoted: 140 Post(s)
Liked 162 Times
The Mavic rims on that chart are "specialty" rims, at least they're all rims that are on Mavic proprietary factory wheelsets. The rims that you'd use to build up your own wheels aren't on there. The few places I've seen recommended tension for those rims (Open Pro, etc) was more like 100kgf to 110 kgf, but it was just someone's opinion, I don't know if it's what Mavic says. Anyone know Mavic's phone number for tech help? I called them about something years ago, but I don't know where I got the phone number. I don't see it on the website-
Liked 7 Times
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
Mavic doesn't list phone numbers on any of their web sites but state that
all queries go to your LBS.
edt: remove the comment about previous post, honest mistake.
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Tension also depends upon the number of spokes. Low spoke-count wheels have a lot more tension to account for fewer spokes.
Soma Lover
Bikes: one bike for every day of the week
I've always taken about 3500 and divided by the lowest number of spokes an eyeletted rim is typically drilled for to get a ball park maximum kgf for the drive side rear. I'll lower it by 10% if the rim I'm working with isn't eyeletted and go a little lower still if it's single wall.
This gives 110kgf for rims that only come drilled for 32 and 36 spokes, 125kgf for 28 spoke Open Pros. It furthermore gives 145kgf for deeper section rims that are regularly sold drilled for 24 spokes and as much as 175 kgf for my "boutique" 20 spoke Ksyrium Elites. I will aim for this number or a little lower when tensioning the matching front wheel. Gerd Schraner's book indicates the DT Champion and Competition Spokes I generally use can handle as much as 200 kgf.
I'm sure there are better ways to do it but after building about 15 wheels and rebuilding or retensioning about a half dozen more, I have yet to have a failure and all my wheels have stayed true. Although I tend to be pretty abusive, I don't know of anybody over about 175 lbs. riding any of them either.
Does anybody know of any specific manufacturer's tension recommendations that run counter to this?
A little North of Hell
Quoted: 71 Post(s)
wrong number? sorry!
off the mavic site.
Oops! Guess I need reading glasses? 888-466-2842
https://www.tech-mavic.com/tech-mavic...themes/2_4.pdf
Quoted: 140 Post(s)
Liked 162 Times
off the mavic site.
Quoted: 15 Post(s)
Liked 9 Times
Soil Sampler,
Sorry for the comment above given it was an honest mistake,
I offer my humble apology.
Also editing my post.
Marty
Marty
Quoted: 140 Post(s)
Liked 162 Times
I removed my posts as well regarding the mistaken phone number. And thanks to Soil Sampler supplying the Mavic phone number, I've got a little info relating to the thread. Mavic was very helpful and provided the following:
Mavic CXP33 rim, Open Pro rim, and A719 rim:
recommended rear drive side tension: 105-110 kgf
Spoke count not critical in regard to tension with these rims, just the keep the average tension around 105-110 kgf per spoke on the rear drive side.
ERD
CXP33: 595mm
Open Pro: 602mm
A719: 599mm
ERD
CXP33: 595mm
Open Pro: 602mm
A719: 599mm
Good info, thanks. That's lower than I expected, but not much. Velocity told me 120kgf DS rear on a 36h Deep V.
Quoted: 71 Post(s)
no harm, no foul.
ERD
CXP33: 595mm
Open Pro: 602mm
A719: 599mm
Be careful, Mavic uses Spoke Support Diameter, not ERD.
Google Mavic Effective Rim Diameter and you will find most recommend SSD+3mm
PS. You guys are buying the next round of beers!
CXP33: 595mm
Open Pro: 602mm
A719: 599mm
Yeah, you guys are awesome.
Now, ERD would be useful in calculating the necessary length of spokes? Or is it for something else?
Also, since the rear drive side tension is about 105--110, non-drive side and front should be about half that? This sounds too low to me. (And front wheel?)
I'd put the front at that 105-110 number too. NDS rear is what it is, depending on flange dimensions and lacing pattern.
Oh...I see. Little dense this am.
