7 speed cassette on 8/9 speed hub?
Old 10-10-07, 11:14 AM
Dirty old man in training
Bikes: 2007 Novara Randonee, 1991 Raleigh Olympian, 1988 Nishiki Ariel
Can you mount a 7 speed hyperglide cassette on an 8/9 speed freehub?
I have a older road bike that came stock with 14 speed Shimano SIS and cheap wheels. I have broken several spokes on the rear wheel and am debating about rebuilding it or replacing it with a new wheel. I have a 7 speed freehub so I believe the frame spacing is 126mm OLD. The frame is a Raleigh technium frame (Al main tubes, steel fork and rear stays), so I think I would be OK installing a modern rear wheel with 130mm OLD.
What I don't know is if I can mount my old cassette on an 8/9 speed freehub, and if so do I need some kind of spacer?
Chuck G is offline
Old 10-10-07, 11:20 AM
Steev's Avatar
Yes, you can do it, yes, you need a spacer. I think its 4mm, but don't quote me on that.
Steev is offline
Old 10-10-07, 11:29 AM
vpiuva's Avatar
Originally Posted by sheldonbrown.com
7-speed cassettes fit fine on 8- and 9-speed (and some 10-speed) hubs if you put a 4.5 mm spacer onto the body before the cassette
from the source
vpiuva is offline
Old 10-10-07, 01:52 PM
Liked 7 Times in 6 Posts
Late 7-speed hubs were built on 130mm dropout spacing.
Al1943 is offline
Old 10-10-07, 02:23 PM
Perineal Pressurized
dobber's Avatar
Meaning what? The modern road bike is 130mm, the MTB is 135. This has nothing to do with the freehub body dimension though. The 7 speed body was shorter than that now used for 8/9 speeds.
You can get a low end (Altus?) 7 speed hub spec'd as an 130 or 135mm.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
dobber is offline
Old 10-10-07, 03:49 PM
Originally Posted by dobber
Meaning what?
The OP said he believed his frame spacing is 126 because the cassette is 7-speed. I was simply pointing out that not all 7-speeds have 126 spacing. An 8, 9, or 10-speed hub might slip right in.
Al1943 is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
