Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
Hub Slayer
Old 10-05-07, 11:35 PM
circus bear
ban guzzi's Avatar
Bikes: 97(?) GT Richochet, 00 Schwinn SuperSport
Hub Slayer
..and not happy!
The LBS has had my commuter Giant Yukon rear wheel for a week now! I heard a pop and then when free wheeling (which I don't do often if it makes a difference?) a clunk/pop and hitch was felt from my rear wheel. Not good! I turned around and went home and swapped out for the car (suck-0!!).
Long and short of it is, the rear hub is so locked up they haven't even been able to disasemble it! The cassette is fine, the wheel is fine but it still went DOA. The kicker is that I've had this bike for less than two months and have a hair under 600 miles on it. It looks to be covered by the factory warranty (thankfully) but still!! I'm not overly rough but I do my best to always crank and I've found some potholes at 430am on my way to work. I didn't do anything out of the ordinary. I mearly stood up on the cranks to get across a four lane as fast as I could when my light turned.
I'm bumming hard! The ol' Chicago Schwinn just isn't cutting commuter duty.
Anyone else have this happen to them?
One week down and prolly another till I get it back....
any advice for me here? Any MTB hubs recommended for an Uber Clyde? Im at a loss here...
ban guzzi is offline
Old 10-06-07, 12:20 AM
Gorntastic!
v1k1ng1001's Avatar
Talk to the mechanic and see what he thinks went wrong. If its a defect, give the replacement hub a try.
If it just failed under your weight, I would suggest having a new rear wheel built so that your bike isn't in the shop two weeks out of every season.
I don't have any specific recommendations on hubs, but you can easily find something better than the rear hub on that Yukon. Back when I ran a shop I used to put uber clydes on downhill wheels if they could afford it. If you're just using the bike for commuting, that might be overkill.
v1k1ng1001 is offline
Old 10-06-07, 12:53 AM
circus bear
ban guzzi's Avatar
thanks! I'll look into it. I know the component set on this bike is, to be polite, 'entry level'...I just had hoped to get away with not busting anything a bit longer...
off to search downhill wheel sets...
Old 10-06-07, 01:47 AM
Gorntastic!
v1k1ng1001's Avatar
I don't think you need to go with a downhill wheelset just for commuting. You can probably find a higher end hub and pair it with a downhill rim. Downhill specific hubs can be expensive and I'm not even sure if they'd work on your bike. It's been a long time since I worked at a bike shop.
Old 10-06-07, 02:39 AM
circus bear
ban guzzi's Avatar
Yah...Upgraded hub with downhill rim, heavy gauge spokes...After looking at things a bit, thats what I'll do. For now the new hub will be covered by warranty while I gather the upgades needed for a new rear wheel.
Thanks for the input, I appreciate it..!
Old 10-06-07, 07:00 AM
Squirrel
solveg's Avatar
Bikes: Borthwick Touring bike, 83 Schwinn Peloton, 94 Scott Cheyenne, ?? Bianchi Torino
How are downhill rims and hubs different than normal?
solveg is offline
Old 10-06-07, 10:30 AM
Downhill rims are generally really wide to accomodate tires up to 3 inches wide and the rim often has a heavier build as being able to pedal a downhill specific bike is not really that important. The plus to running a really wide rim is that when you are running "normal" tire widths (i.e. 2 inch slicks) the sidewall of the tire is not bulged out, I have found this helps with preventing sidewall damage on my tires.
A downhill oriented rear hub is usually built a bit heavier as well, often with a bolt on axle rather than quick release and the pricier units have more engagement points in the freehub so they are in theory less likely to slip. The front hubs use a 20mm through axle for added strength/stiffness.
For commuting these sorts of wheels are usually overkill and the additional rotational weight is not appreciated when trying to get up to speed.
andymac is offline
Old 10-06-07, 12:45 PM
Gorntastic!
v1k1ng1001's Avatar
I had this guy working under me who was an athletic 270 lbs. He destroyed everything until we found him a downhill frame and wheels. We modified these for cross country riding and he never had a problem.
Old 10-08-07, 02:18 PM
nmanhipot's Avatar
Bikes: 2006 Specialized Langster Comp, 2005 Schwinn DBX Super Sport, 2004 Trek 5900 Superlight
Liked 2 Times in 1 Post
Chris Kings maybe? They're good for 800 ft-lbs. I'm thinking about going this route myself since I have broken about 10 wheels in the last couple of years.
nmanhipot is offline
Old 10-09-07, 07:43 AM
Gravity Is Yer Friend
dirtbikedude's Avatar
Location: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
Sounds like the prawls in the hub went out but without seeing the hub I could not tell ya for sure. I have seen and also destroyed many my self.
Good hub recommendations, ChrisKing, Hadley, WOOdman all make a nice strong rear hubs. There are others but those are the ones I use on my DH and XC bikes and they have not let me down in ohhhh 8 years or so.
Hazz
dirtbikedude is offline
Old 10-09-07, 10:41 AM
Back after a long absence
joelpalmer's Avatar
Bikes: 1974 Schwinn Speedster 3-speed, Raleigh Super Course
Hmm, something I'll need to keep in mind. I'm getting a touring bike built and a friend gave me the specs for wheels he had built specifically to tour on, but he's a little guy (135 lbs) and I'm not (~250 lbs). Add to my mass the bags etc from loaded touring...
joelpalmer is offline
Old 10-23-07, 07:27 AM
Air
Destroyer of Wheels
Air's Avatar
Bikes: Surly LHT, Dahon folding bike. RIP Nishiki Sport, Downtube IXNS, 1950's MMB3 Russian Folding Bike, MTB
Liked 7 Times in 5 Posts
Ran across this thread and wanted to cross post for anyone else searching for information about hubs:
https://bikeforums.net/showthread.php?t=355761
According to Sheldon Brown Shimanos are the best and the strength of a mtb hub comes from the spacing more than from the construction.
Any other problems - sounds like it was a defect.
The Almighty Clyde FAQ || Northeast Index
eTrex Vista References || Road Reference
It's the year of the enema!
Air is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
