Tubular flatted after 2 days
Old 08-12-07, 07:23 PM
I just got the bike and i've only ridden it twice one time heavy riding and i just got a flat, i wasnt even sure if there was a flat on my ride home, i didnt even feel it. but in the morning the rear wheel is deflated. The only possible reasoning is a puncture. well i have no idea how to fix a tubular so i need to remove the rear wheel however i cant realyl take it off. How do i derail chain from the cog? Iro made the chain tension pretty tight
any help?
Allanbinho is offline
Old 08-12-07, 07:28 PM
Señor Member
bboysubhuman's Avatar
Just push the wheel forward so the chain can come off the cog, then take the wheel off. To patch a tubular, you have to cut the stitching in the tire and pull the tube out a few inches. Patch it, put it back in and sew it up.
bboysubhuman is offline
Old 08-12-07, 07:29 PM
it wont go any further
Old 08-12-07, 07:42 PM
Hello.
crushkilldstroy's Avatar
You got tubulars from IRO? I didn't even know that was an option.
If the wheel won't go any further forward you'll have to walk the chain off of the chainring. Just push it off to the side while cranking forward, making sure not to lose a finger in the process.
crushkilldstroy is offline
Old 08-12-07, 07:45 PM
All around nice guy
BRANDUNE's Avatar
Bikes: THE KIND WITH TWO WHEELS AND ONE GEAR
Why would you opt for tubulars if you cant even get your wheel off your bike, let alone fix a flat tire?
BRANDUNE is offline
Old 08-12-07, 07:48 PM
i didnt opt for it, that was what was given, its got a presta valve so... and i couldnt roll off the rim
Old 08-12-07, 07:49 PM
and i took off the rear wheel so OP is answered by myself thanks anyways
:jarckass:
deathhare's Avatar
its not tubular im sure
deathhare is offline
Old 08-12-07, 07:51 PM
then what the hell is it.
i cant seem to roll the tire off the rim and its got a presta valve.
either that or im pansy and ********
not something i would count out
enlighten me someone.
Old 08-12-07, 07:53 PM
:jarckass:
deathhare's Avatar
clincher
they have presta valves
yes and yes
why not?
iro doesnt sell tubulars
Old 08-12-07, 07:55 PM
thomas masini lives
did you try rolling it off the rim on the edge opposite of the valve
you got to take it one bead at a time brotha
doofo is offline
Old 08-12-07, 07:57 PM
tire irons?
skanking biker is offline
Old 08-12-07, 08:01 PM
i can roll it so i can see the inside of the rim, but it wont roll off, then i can go from the other side and do the same, roll it until i see the inside of the rim but it wont come off.
i need a pryer huh?
Old 08-12-07, 08:03 PM
:jarckass:
deathhare's Avatar
yes
Old 08-12-07, 08:06 PM
i need a pryer huh?
Yes. don't be cheap and use a spoon either. you can get some cheap tire levers from any lbs.
k problem solved then. Do i have to pry it back on?
Old 08-12-07, 08:07 PM
thomas masini lives
try a tire lever for all your prying needs
edit: read this or search for changing a bike tire and find something that makes sense to you
doofo is offline
Old 08-12-07, 08:09 PM
so i could've done this w/o actually removing the wheel itself huh?
Old 08-12-07, 08:12 PM
All around nice guy
BRANDUNE's Avatar
It depends, if you are just patching the tube than yes, if you are replacing it, no.
BRANDUNE is offline
thanks, i hope the wheel is still okay, i didnt even know i had a flat until the morning so it's possible for me to be riding with one (not sober)
it looks true but is there other ways to tell a wheel if its in shape?
Old 08-12-07, 08:13 PM
wish i was, read it somehwere on BF there that you can. soo..
Old 08-12-07, 08:14 PM
:jarckass:
deathhare's Avatar
youre helpless arent you?
Old 08-12-07, 08:16 PM
Hello.
you are doomed.
also, don't drink and ride.
Old 08-12-07, 08:18 PM
death hare and crush, both of you hit it on the nail. Im hopeless
Old 08-12-07, 08:20 PM
thomas masini lives
spend the next year preparing for this
doofo is offline
