Potential fuji conversion; questions about this potential purchase
Hello,
This will be my 2nd fixie (first was a 2006 Langster, which my GF has 'borrowed' indefinitely).
I have *NOT* purchased it yet, but am (hopefully) going to look at it tonight. My questions for you guys.
Thanks in advance..
- It looks like the cranks are those "welded onto chainring" kinds, so I'll probably need new cranks. Will the bottom bracket give me problems to get a standard "track" chainline(43mm)??
- If I wanted to replace the BB on this, are they readily available? (and easily made to 43mm chainline)
- Do you have any info relating to the "Fuji Berkeley"?
Thanks in advance..
Stinky McStinkface
Bikes: Clemente Custom(not built-up), TI Raleigh Record SS, VitaSprint Mixte SS, IRO S.E.(coming) Ibex Trophy Pro
I read here just today that Fuji's are great for conversions. People here really like them. VALite tubing is supposed to be decent. Looks like you got a nice from there... nice color too.
I think a standard BB will do fine. Chainline depends on what cranks you use. The way the spider is made determines the length of the spindle. Some BB's are adjustable.
If you are using the orignal cranks you have to measure from the center of the seat tube to the crank tooth to determine chainline. The general concensus is that 1mm off is not going to be noticeable. Unless you are anal about that sort of thing, as I am
From the distance those 'rings look riveted. If they are, you won't be able to remove the big one unless you cut it with a disc grinder.
Because, yeah... uh huh! Umm, yeah!
Boston did not sob
You didn't mention how much it would cost?
Maybe you want to do a conversion, because that's what you're into, and that's cool. However, if low cost is your deal, may I suggest the BD Windsor Hour? I just got one, and I am totally jazzed on it. It's the same frame as Fuji makes (not so pretty TIG welded, so not stylie like the bike you're looking at above).
Anyhow, just something else to consider
Stinky McStinkface
They want $90 for this bike, plus a rear wheel, new tires, brake pads, cables, cranks, etc, it'd probably come out to about the same as the bikesdirect windsor.
It makes sense to just get a crate bike, but I really want a conversion!!
jerk store
Bikes: '80s Chimo Garbage fixed 36/14, Centurion fixed 42/17
Do it. It looks like the bike is in great condition, and it has forged dropouts. I think it will turn out really well.
https://bikeforums.net/showthread.php...62#post5014362
Bikes: Guru new steel Lotus converted fixed Jamis sputnik
i had a fuji convert just to check it out. i kept the original crank esc but got deep v's ended up buying the sputnik and swapping out the wheels. T he ride is much more confortable
